Question about Kenmore 24032\24036 Top Load Washer
Won't spin - makes a sound like plastic gears grinding
Still trying to open the machine....
  • 6,784 Answers
HI. the first action is to test the lid switch. The lid switch ensures that the lid is closed before enabling the machine to spin or agitate. This feature was added after serious injuries resulted from people reaching into an operating washing machine. For this reason, the lid switch should never be bypassed. Aside from electrical problems, the switch may suffer from a mechanical problem. The lid may have a striker which depresses the switch when the lid is closed. Make sure the striker is functioning and aligned with the hole over the switch. Inspect the switch and make sure the metal strip is not bent out of position (if present). If your switch uses a mercury switch, make sure the mercury envelops the internal contacts when it is in the closed lid position. Your design may differ, so inspect it for proper operation before proceeding to the electrical testing.There are two primary types of lid switches. One type on which you can directly test the terminals on the switch and another style where you have to test it at the wiring harness. In either case the method for testing the switch is the same. If a wiring harness is used, separate the two pieces of the harness and test the side of the harness that connects to the switch. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should display a reading of infinity. Depress the button on the lid switch and the reading should change from a reading of infinity to roughly zero. If it does not pass both of these tests, the switch should be replaced.
Some lid switches also have a fuse, you can visually inspect the fuse or test it for continuity with a multimeter. If the fuse is bad, replace it with one of the same rating.
If the lid switch is operational, i would move on to the next possible issue. This will be the motor coupler.
Washers with a direct drive motor have a motor coupler instead of a belt. The motor coupler consists of three plastic disks (or tri-stars) with interlocking tabs. Those tabs can wear and break which results in slippage. The slippage causes little or no power to be transferred to the transmission
. A worn motor coupling can result in weak or no movement of the agitator and spin basket. Inspecting the motor couplers requires removing the motor, which is fairly easy to do.
Remove the cabinet. Locate the motor. The pump is mounted to one side of the motor. You do not have to remove the hoses from the pump unless they prevent you from moving the pump out of your way. If you must remove the hoses, label where they connect first. To disconnect the hoses, pinch the wire clamps with pliers (or loosen the screw) and slide the clamp farther up the hose. Slide the hose off of the pump port.
There are two clips that secure the pump housing to the motor. Use a screwdriver to pry up the clips and remove the cover. Next, slide off the pump to reveal the motor. Disconnect the wiring harness from the motor, do not pull on the wires themselves. The motor typically is secured with retaining clips and bolts. Remove the bolts and use a screwdriver to pry up the clips (if present). Remove the motor.
Mounted on the shaft of the back of the motor you will find the motor coupler. Separate the three disks and inspect them for damage. If you find cracks or excessive wear, replace the coupler.
***(I would suggest to check the following while you are in the area for faults as well(((Clutch,motor,motor board,transmission))). inspect these areas thoroughly)
Ok, if all the above checks out ok and, there are no signs of damage to any of the above parts stated, this will confirm a timer control module malfunction. replace the control device(timer or control board) asap, if possible.
Posted on Oct 05, 2009
Paper jam
Does it sound like the motor is spinning? or does it sound like the motor is bound up? I ask because if it sounds like the motor is spinning, then chances are good you stripped a plastic gear somewhere in the drive system that feeds the steel shredder. I just pulled apart one of these and saw that the motor has a steel gear on it. that steel motor gear meets with a plastic gear, and then the plastic gear meets with steel gears attached to, and which spin the shredder. So if you ever bind the shredder with too much paper, the steel motor gear will grind the teeth right off the plastic gear and it won't spin anymore. If your motor sounds like it's bound, then the good news is that the gears aren't stripped. You'll have to take the shredder apart so you can remove the paper causing the problem. Of course unplug it first before opening it up. They are not overly complex but just remember where the screws goes so you put them back in the right holes.
Sep 01, 2014 | Office Equipment & Supplies
My Kenmore 80 series washer won't spin, and it just makes a loud gear grinding noise. What could this be, and how do I fix, in the simplest form please I'm chick... :)
rebecca it is probably the motor coupler. Move or slide ur machine over and if there is ruber filings under it then it is the coupler.
Apr 04, 2012 | Kenmore 24032\24036 Top Load Washer
Won' spin out and makes a loud noise like a grinding sound
The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
Jan 19, 2011 | Washing Machines
I have a whirlpool la5558xtw2 top load washer,it wont spin,or drain,there is a grinding noise,like gears grinding when trying to engage spin cycle.have tried different settings for wash,and load size,still...
This sounds exactly like a bad motor coupling, the coupling goes bad and won't engage the transmission. This is an easy fix and won't cost much. About $12.00 and a service call should do it. While your at it have them change the plastic tabs in the agitator, they wear out about as fast as the coupling and should only add another$ 10.00 to the deal. These are common problems with these machines.
Nov 13, 2010 | Whirlpool Washing Machines
Rock stuck in grinder. just spinning noise when it
It is not a healty sound,seems either the gear cogs slipped or the plastic base that holds the lower blade of the grinder is broken.
Jan 02, 2010 | Saeco Talea Giro Espresso Maker -...
Whirlpool stylemaster 4217141 REV A Agitator/spin cycle broken
I have exactly the same problem as Jonthan, what's the solution?
Dec 24, 2008 | Washing Machines
Loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Sep 24, 2006 | Admiral AAV7000A
Kenmore 24032\24036 Top Load Washer Logo
85 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
