Question about Vacuums
Explain how to re-wire 16gal craftsman shopvac,switch wires are- 2 orange wires, one white, one black and one green(grd wire), I pulled them off and don't where each wire goes.
  • 8,404 Answers
Im not looking at a diagram of your machine.
Typically, in a switch circuit ... the green goes through; the white goes through; the black is broken by the switch.
The two orange wires you speak of ... those come from where? Are they from the motor? If yes, one connects to the white and one connects to the switch.
I hope this helps you
If I have misunderstood your question, please ask again.
a
Posted on Oct 05, 2009
Can't hook up power cord to main motor on Hoover model F5915100
You have a black and white and green wire. Green is ground white is neutral, black is hot . Should say on the motor either L1 = black wire. L2 = white wire , G = Green wire or it say H = black wire, N = white wire , G or the symbol for ground = green wire
Apr 11, 2014 | Hoover SteamVac F5914-900 SpinScrub...
I need to know how to hook the wires up to the start switch. There are two wires from the external cord and two wires from the internal cord.
white wire to neutral black wire to hot if you post colors I could help you red ,orange, black,pink, blue, or violet are usually hot guessing a striped wire is usually neutral please post colors
Apr 14, 2013 | Dyson DC14 All floors Bagless Upright...
Where do the wires go when i am wiring a garbage disposal using a tw o pole toggle switch
The garbage disposal shoud have three wires a green wire goes to ground,
the white wire is neutral, and the black wire is your hot. at the switch, the white
neutral wire feeds straight to the garbage disposal as does the ground, many
times the switch will either have two screws one gold and one silver and the
green is designated as ground. hot goes to the gold screw and the black wire
coming from your disposal goes to the other screw. make sure to turn off power
before working on electrical wires check with voltage meter, its not like working
on your car, if shocked it can be fatal, if unsure handle wires with insulated tools
or gloves. good luck!
Jun 26, 2011 | Vacuums
I am tiring to install a GE touch auto shut-off timer, I have 2 wires in the wall 1 black & 1 white, the switch has 4 wires (1 green[ground?], 1 blue, 1 black & 1 white) when I try to follow the...
You might not be able to use that switch in your configuration. It appears that the power was run to the light and only two wires were run back to the switch. The old switch only closes to connect those two wires completing the circuit at the lighting fixture, but you need a hot and a neutral to operate the electronic switch that you have.
Gary
Apr 18, 2011 | Vacuums
I am trying to install a ge digital timer (model 15086) for a porch light. I have one black wire and one white wire coming from the wall. The timer has a white, black, red and green wire. How do I procede?
I am commenting on things are here in the u/k not u/s which is not the same but i hope this is of some help.......From the wall black and white ,this is a switch wire which is on or off, i would link this to white to white , black to black or black to red with the rest left unconnected,,,,,Check to see if you have fitting instructions indicating what wire goes where....Good luck
Feb 19, 2011 | GE Vacuums
I am installing a ge #15070 basic timer and there are 3 wires. Which wire do I attach to the ground?
GE 15070 timer does not have ground wire.
I assume this timer is double insulated, just like some power tools and electronics only have two prong plug.
Leave bare ground wire attached to other bare grounds in the box, and shove grounds to back of box.
I have one of these timers installed.
Timer has red, black and white wires
http://waterheatertimer.org/GE-timers-and-manuals.html#15070
How to wire GE 15070 timer:
1) Switch has 2 insulated wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
3) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
4) Turn on electricity, and slide switch to ON-or-OFF. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
5) Add a comment for more free help.
6) Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 13, 2011 | GE Vacuums
Replaced Oreck power switch. 2 black leads and 1 white lead for switch. Posts marked 1, 2, and 3. 2 black wires to switch powers on. Connect white wire and breaker trips. Where does the white wire go?
Both black go to the switch. Power in - black to switch / white to white from motor.
From motor - black to switch / white to white from power cord
The black wire from the power hooks to the off end of the switch and the black wire from the motor hooks to the on end. Third post is not used. The two white wires are connected to each other with a small twist on wire nut.
Nov 01, 2010 | Vacuums
My Oreck XL has worked very well until the power cord was pulled out of it. I figured how to hook up the hot but can not figure out the neutral connection. any ideas?
if there are two wires it doesnt matter normally white 2 white and black 2 black if its 3 wire than green is ground and the other 2 dont matter thanks Don
Oct 31, 2009 | Oreck XL Ultra Bagged Upright Vacuum
REPAIRING A BISSEL GREEN MACHINE, REPLACING PUMP. DON'T KNOWWHICH WIRES GO WHERE ON PUMP
hi
if theres only three wires , green, black and white then the green wire is a ground which goes to an exposed metal exterior screw on the pump. It doesent matter which way the black and white go, it will work either way but if when you try to attatch the connectors theyre harder to attatch one than the other then switch it to the most easier way to attatch. Make sure to connect the green ground wire, it is very important and always try plug the shampooer into the bathroom where the ground fault plug is- its an added level of security in case theres a ground fault.
J
Jul 11, 2008 | Bissell Vacuums
Vacuums Logo
122 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
