Question about Kenmore 64992 Electric Dryer
Kenmore, model#96589210, was running but not heating, tested thermastat, and heat coil, heat coil ok thermastats were bad, replaced thermastats, pluged dryer back in now doesn't run when you push start button
  • 82 Answers
You need chek door switch is conected.
Posted on Oct 06, 2009
Top thermastat has no voltage?
Are you getting 240v to the element ? If not it may be the timer , the centrifugal switch on the motor or a fuse . start by testing continuity in t he fuse then test timer .
GOOD LUCK
APPLIANCES R'EN
Dec 08, 2013 | Kenmore Dryers
Hi, I have a Kenmore Elite electric dryer model#
If your fuse is blown could be that your operating thermastat is not shuting off as soon as it should. Try replacing the fuse and the operating thermastat. The fuse would probaly blow before the hi limit.
Jul 16, 2010 | Kenmore 62802 Electric Dryer
I have a Kenmore gas dryer Model # 110.76962501 will not heat. Would glow when turned on but then would kick off, no heat. Have checked all thermastats and sensors, everything checked out ok. So bought 2...
if the ignitor was glowing you could have bad gas coils or a bad gas valve.check the coils with a meter to make sure they are good,also when you read out all the other parts did you remove at least one of the wires from the part,if not you'll get false readings.if the coils are good make sure the wires are pushed on tightly and check the metal connectors inside the plastic wire connector that slides onto the coils,i've found some that were messed up and not making a connection with the coil.also on one of the coils there's a metal sleeve, i think it's the coil with three prongs on it,check the old coil to see if it's stuck inside the old coil,if it is stick a screw driver in it,push it out and slide it back on the post and slide the coil back on the post,if everything checks ok you could have a bad gas valve,try wacking it with something to see if it will let the gas through.let me know what you find with the meter and how you make out,
Apr 10, 2010 | Kenmore Dryers
Cooling system
these are somethings that maybe causing it to over heat (1) not enough cooling in it.(2) water pump drivebelt (3) Radiator core blocked (4) Bad thermostat (5) fan blades broken or cracked (6)Radiator cap need to be replace (7) Ignition timing incorrect if all fails stop by your local library and get your hands on a Haynes auto repair Manual for your car wish you the best of luck Michigan Man
Dec 09, 2009 | 1995 Mercury Cougar
Dryer has no heat, not heating elament
Test the outlet for 240V. If that's ok, you've already replaced the element so remove the wires from the thermostats and test them for continuity (you might want to test the element for continuity just in case). If that's ok, there might be a problem with the timer. Depending on the model you may be able to open it to verify.
If you're still having problems, post your model number and I'll try to assist you further.
Apr 04, 2009 | Kenmore Dryers
Will not heat
Are you getting 220 at the heating element from one lead to the other
Mar 29, 2009 | Dryers
Kenmore dryer
check the heatingelement and the element high limit thermastat
the high limit thermastat is on the left side of the element housing and has two red wires connected to it
with a ohm meter the element and the thermastat will read contunity
i wuld start there
Apr 20, 2008 | Dryers
Kenmore Dryer
I am sorry to hear this, my name is Marc White, i am self employed and it seems as though you have a bad timer, bad timer will cause the timer not to go to the off position and blow your fuse......change your timer..
thanks
Apr 03, 2008 | Kenmore 73952 Gas Dryer
Kenmore 64992 Electric Dryer Logo
205 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
