Question about Matrix Okidata Microline 320 Printer
After Print job the printer skips and goes to next tearoff
After Print job the printer skips a sheet and goes to next tear-off. I am using the rear feed and have the setting for "Skip Perforation" turned off. So I am confused why it would skip one. My data is far enough away from the bottom margin as to not push it to the next page.
My OS is XP, my only guess is that it is a software problem with the software vendor setup the tickets.
I am using 9.5' width X 7" continuous paper, we just switched over from 9.5 X 11" paper.
  • 95 Answers
Check you manual, set the printer back to default. or it might be with the program your trying to print with. try print a test page using your driver. if it still the same. uninstall and reinstall it back to your computer to restore it to its default value
Posted on Oct 05, 2009
We had a power failure and now our Lexmark 2391 dot matrix printer will not print from the top of the page. i need to know how to setup/reconfigure the top of the page? thank you
  1. Push the ALT button and then the PARK LOAD button to back the paper out.
  2. Push the PARK LOAD button to reload the paper. The Ready light should now be blinking.
  3. Use the MICRO up or down buttons to adjust as needed, making sure that the top of form is set on the very first page that enters the printer. Typically, the top edge of the first sheet of paper should be even with the ribbon.
  4. When the page is lined up properly, press the START/STOP button. The printer will record the current position as the top of form and then feed paper to the tear off position.
  5. Use the MICRO up and down buttons to place the top of the paper at the tear off bar.
  6. After the tear off is positioned properly, press the START/STOP button twice to save the tear off position.
  7. Test the positions with a sample print job. If the alignment is still off, follow this entire procedure from the beginning again as needed.
Aug 08, 2011 | Lexmark 2391 Plus Matrix Printer
Light is flashing on Resume on my HP Deskjet F2110 All-in-One printer scanner copier. What does that means?
Regular paper, envelopes, or specialty media may get stuck or jammed in the printer. Follow the instructions below to find and remove jammed paper (or other media) from the printer. If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not in the rear rollers, check the front door.
Step one: Check for and remove any paper stuck in the paper In tray
  1. Remove all loose paper from the paper In tray.
  2. Press the RESUME button.
    • If the paper jam is cleared, skip to Step Four
    • If the paper is still jammed, continue on to the next step below.
  • If more than one sheet is stuck in the printer, remove the paper, one sheet at a time by taking hold of a sheet in the middle of the stack and, with both hands and firm, even pressure, pull the sheet towards you. Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
  • After removing the paper, check to make sure no scraps of paper are stuck in the printer.
    • If the paper jam is cleared, skip to Step Four.
    • If the paper is still jammed, continue on to the next section.
  • Step two: Clearing a paper jam from the back of the printer
    If the paper jam is not accessible from the In tray, follow the instructions below to clear the paper from the back of the printer.
    1. Unplug the HP All-in-One.
    2. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. Figure 1: Removing the rear door
      CAUTION:If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all of the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Replace the rear door. Gently push the door forward until it snaps into place.
    3. Press Cancel to continue the current job.
    Step three: Lift the front cover and slowly remove any jammed paper
    1. Unplug the power cable.
    2. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door
      CAUTION:If the paper tears when while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Close the print cartridge door.
      Figure 3: Closing the print cartridge door
    1. Plug the power cable into the HP All-in-One.
    2. Turn the power on.
    3. Press Start Copy Black or Start Copy Color to continue the current job.
    Step four: Verify the print cartridge carriage can move freely
    2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step Five. Do not try to force it to move if it is hung up on something. [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="">
      NOTE:Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
      • If the carriage does not move, continue with the next step below.
  • Remove the print cartridges.
  • Step five: Reload and test the printer
    Once the jammed paper is removed, verify that the printer is still functioning properly.
    1. Reload the printer with plain paper.
    2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
    NOTE:Do not put more than 35 sheets of plain paper in the document feeder tray.
  • Gently move the print cartridge to the far right of the printer.
  • Remove the paper from the paper In tray, but do not remove the drawer.
  • Remove the rear access door.
  • With your fingers, rotate the rollers "up" three full rotations.
  • Push the rear access door back into the printer until it snaps firmly into place.
  • Replace the print cartridges.
  • Plug the power cable into the HP All-in-One.
  • Turn the power on.
  • Step six: Service the printer
    Perform all the steps mentioned above. If the problem continues, service the printer.
    Cause Paper jams can be caused by several factors. Follow these guidelines to prevent further paper jams.
    • Insert paper into the paper tray only until it meets resistance. Do not push it farther in.
    • Make sure that the paper is flat in the paper tray and that the guide is adjusted to the width of the paper.
    • Do not add paper while the product is printing.
    • Remove printed pages frequently.
    • Do not use paper that is too thin, too slick, or that stretches.
    • Do not use torn or creased paper. Used paper might cause jams.
    • Make sure that the rear access door is securely fastened.
    Jun 17, 2011 | HP Deskjet F2210 InkJet Printer
    I have an HP Photosmart Premiem printer, and it is not printing. I send items to printer and it goes through the motions but nothing is on the paper. I have the cartriges that came with unit. I have...
    Try checking the print queue and see if any print jobs is preventing you to print. This is usually a printer icon in the lower right corner of the desktop, next to the Date and Time. You can also run a Print Test to test your printer hardware.
    May 19, 2011 | HP Office Equipment & Supplies
    My Deskjet 5740 has Resume light blinking, all other lights off. Will not print. Won't let me cancel printer queue. If I push the Resume button, the printer feeds a sheet and halfway through the next...
    Sounds like it is expecting a different size paper than you have in it. In the item that you are trying to print confirm the page size. If it is a document that you download or someone sent you it could be in a different page size. To cancel it you will likely have to go into the printer settings and delete it from there then power off the printer and power it back on, this should clear the job. Windows will keep trying to print the job until it is successful or deleted. To see the print jobs double click on the printer icon then just highlight and delete it.
    Jan 19, 2010 | HP DeskJet 5740 InkJet Photo Printer
    When trying to take print in erp alwayas skip one page of 3 page print
    for this you have to change some settings of your printer ..... to get the all settings of your printer press font button and switch on the printer (before take setting make sure that you printer loaded with paper ) goes through the instruction printed in the paper to change the settings ........ change paper size to you using paper size and enable the tear off option and( if first settings are not working enable skip over perforation option ........ hope it solve your problem ..................
    Dec 19, 2009 | Epson LQ 1070+ Matrix Printer
    C6180 will not print labels as set out in the avery template. will bunch up as they go down sheet
    Step 1 : Change the print settings
    The print settings of the HP All-in-One can be customized to handle nearly any print task.
    Before changing the print settings, decide whether to change the settings for the current print job only, or to make the settings the default for all future print jobs. How print settings are displayed depends on whether to apply the change to all future print jobs or just to the current print job
    Change the print settings for all future jobs:
    In the HP Solution Center, click Settings , point to Print Settings , and then click Printer Settings .
    Make changes to the print settings and click OK . Change the print settings for the current job:
    On the File menu in the software program, click Print . Make sure that the HP All-in-One is the selected printer.
    Click the button that opens the Properties dialog box. Depending on the software program, this button might be called Properties , Options , PrinterSetup , or Printer .
    Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
    Click OK to close the Properties dialog box. Click Print or OK to begin printing.
    Step 2 : Print with 210 x 297 mm (8.5 x 11 inch) labels
    The HP All-in-One can be used with any software program designed for printing.
    This document contains basic information about using the HP All-in-One to print on labels using a software program. For additional information, such as printing a poster, printing multiple pages on a single sheet, and more, see the onscreen Help that came with the HP software.
    Follow these steps to print on labels:
    · Make sure to load labels in the input tray. Always use letter or A4 label sheets designed for use with HP inkjet devices (such as HP inkjet labels).
    · Make sure the labels are no more than two years old. Labels on older sheets might peel off when the paper is pulled through the HP All-in-One, causing paper jams.
    • Fan the stack of labels to make sure no pages are sticking together. Place a stack of label sheets on top of full-size sheet of plain paper in the paper tray, label side down. Do not insert labels one sheet at a time.
      1. On the File menu in the software program, click Print . Select the HP All-in-One as the printer. To change settings, click the button that opens the Properties dialog box.
      2. Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
      3. Click OK to close the Properties dialog box. Click Print or OK to begin printing.
    Aug 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
    Epson 3810 goes from printing perfect to characters/wingdings
    My Epson 3810 does not print proberly from the Internet. It prints but only prints out what appears to be the computer language being sent to it. All other applications print fine. Just items from Internet explorer are having the issues. Any suggestions?
    Apr 06, 2009 | Epson Stylus CX3810 All-In-One InkJet...
    Printronix P5210 line printer HOF problem
    If you are using a printer that has IGP enabled, you can set the printer to automatically go to the next TOF at the end of the print job. Only if you are using the Graphics portion (printing bar codes and graphics). The option is "Auto FF at ^PN" and you would Enable it.
    Dec 29, 2008 | Printronix Line Matrix P5210 Printer
    Oki microline 590 elite
    What driver are you using for this printer? Try loading a Epson LQ1050 driver and try again.
    Dezzi
    Dec 12, 2007 | OKI MICROLINE 520 Matrix Printer
    307 people viewed this question
    Top Matrix Office Equipment & Supplies Experts
    Dimitar Todorov
    ray gallant
    Tom Chichester
    Are you a Matrix Office Equipment and Supply Expert? Answer questions, earn points and help others
