Question about Air Tools & Compressors
I have sears craftsman 22gal 5 hp air compressor not enough press
I have sears craftsman 22gal 5 hp air compressor my tank will fill up to 70 psi and that is it the motor will still run on my check valve air is always coming out the relief tube goes no ware it just blows air out i plug it up it still never goes above 70psi help thanks model 919.165220
    President:
  • 1,167 Answers
Hi buddy strip the end off the check valve out and inside is a rubber turn this rubber around and try this if it still downt work it sounds like the pressure switch faulty get back to me
Posted on Oct 05, 2009
Testimonial: "thanks i took out the check valve i see the rubber but the valve is 1 piece should i just get a new one"
  • ollie reece-jones
    ollie reece-jones Oct 05, 2009
    yes buddy best to really get it off ebay for cheap its a non return valve
Can I get 80 psi with dials set at 40 psi
this compressor should be able to fill your tires to 80 psi. Look for a pressure switch and adjust it so the motor shuts off at a higher pressure. Do not exceed 100 psi.
Sep 08, 2014 | Air Tools & Compressors
1 hp 3gal craftsman compressor will only build up to 20lbs pressure in tank. how much compression should single cyl have on compression stroke?
A piston in any engine should be around 100 psi I would guess. A Chevy 350 used to be around 150 psi. An air compressor that only pumps enough air to reach 20psi is obviously too low on compression. Nailers and the like need 80 or more psi. The intake valves may be shot, the unloader might be stuck or piston rings are worn.
Dec 08, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Can it be used to run spray can of psi 0f 70
you have to have a pressure regulator on it that drops the oulet pressure to 70 psi while the tank press is 120 psi or more. your can regulate the pressure you need up or down as needed.
Aug 31, 2010 | Dewalt 2 Hp 4 GAL Air Compressor
Craftsmen air compressor #919.155730-motor runs,pump moves, but doesn't build pressure. how long does it take? could I not be waiting long enough?
Your unit should fill within 5 min. Compressor may have worn cylinder or just leaking. Easy test. Spray soapy water on all connections/fittings including drain valve and regulator while compressor is running. Repair as needed. If no leaks, remove plug from outlet, remove cover and examing cylinder. Turn crank by hand till piston is all the way up into cylinder. Examing carefully the condition of the cylinder close to top. If the cylinder is scratched or worn then pressure is leaking between piston/cylinder and will not fill tank. Replace cylinder kit available at Sears, cost under $50. Good luck with your project.
Aug 06, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air compressor won't go over 40 psi?
my ace air compressor which is 26 gallon 5 hp will not get over 60psi what is wrong with it please?
Feb 14, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
I have a sears craftsman air compressor 5hp 22 gal tank single cyl oil free it gets up to 70 psi does not shut off but will go no higher i cant find any leaks just bought it used guy used it to paint i...
The regulator and emergency release valve need to be checked. It should shut off once the PSI hits the target pressure. If the motor is staying on and the pressure never raises above 70 lbs, then air is escaping, either the emergency prv or a seal has blown
Sep 24, 2009 | Air Tools & Compressors
My 5hp 22gal craftsman compressor wont go above 30lbs pressure
your presure guage sensor has gone a miss you can try adjusting it but I would replace it. if you get it wrong you can over pressure you tank and it can explode
Jun 10, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
473 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
