Question about Microsoft Xbox 360 Console
Console with 3 red flashing lights
Hey my xbox like other people is turning up with the 3 red flashing lights every time I try to turn it on and I don't know what to do.Please Help!!!
Iv noticed that my xbox started flashing red and froze so i turned it off immeditly and felt the connections in the back were really hot and my xbox was really hot so iv moved it to an area where it could get good ventilation and keeps cool. havent had any more problems turning red it blows out alot of hot air out the back it needs to breath.
Posted on Dec 23, 2007
What is wrong with my xbox it says error 65?
Error 65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot.
Flashing red:
1.the av cable cannot be detected
Make sure that the AV cable is correctly connected to the Xbox 360 console.
Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
2.general hardware failure
Try restarting the console.
If restarting the console does not resolve the behavior, follow these steps:
Turn the console off.
Unplug all the power and AV cables from the console.
Unplug the power cord from the wall socket.
Firmly reconnect all the cables.
Turn on the console.
If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
Also examine the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the RoL flash red.
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
0001 power supply problem
0002 Network Interface problem
0003 Power problem could be the PSU could be the GPU/CPU, somehow the console isn't getting clean power from the power supply.
0010 over heating
0011 over heating - If you are receiving this error after disassembling your console make sure to all 8 of the heatsync screws are tightened securely to the board/heatsink holes.
0012 over heating
0013 over heating
0021 DVD Drive Time out - Can be caused by problems with a firmware flash. This is also speculated to sometime be caused by a problem with the southbridge chipset on the motherboard.
0022 GPU Error / GPU Overheating
Feb 08, 2010 | Microsoft Xbox Console
Tip
What to do if you have 3 flashing red lights on your Xbox 360 Console?
If you have the 3 rings of Death (3 Flashing Red Lights) on your xbox 360 console, all you need to do is to contact Xbox Support and report this issue with them. The Console has a 3 year warranty for the 3 flashing red lights. Just make sure you did the following first:
1. Power Cycle your Console (Turn it off, unplug the power adapter from the wall outlet, wait for 30 seconds, turn it back on)**This is the best solution and it usually works!!
2. If still persist, Turn it off, remove any accessories connected to it (Hard Drive, Controllers, etc.) turn it back on without those accessories. **These accessories sometimes causes the problem.
3. If removing these accessories removed the 3 flashing lights, attach the accessories one at a time, every time turning it off and attaching one and turning it back on checking each time if the red lights (any lights) appeared. It will tell you what is causing the error.
4. If all else fails, again CONTACT XBOX TECH SUPPORT on their Toll free number. Make sure that you tell the tech that you have done those things above so they can create a report for the issue. They love the 3 flashing red lights issue. I should know, I am formerly one of them. :)
on Jun 12, 2010 | Video Game Consoles & Games
I soldered ana chip & tightened gpu chip. after switching on the set green light appeared for 5/6 sec. changing to 2 red lights. 2nd time only red lights came . Now it's not turning on.
1. Let your Xbox 360 console cool. You may have to wait several hours for your Xbox 360 console to cool enough. Don't turn on your Xbox 360 console when the console is hot. 2. Verify that your Xbox 360 console has enough ventilation and that the fans are operating. For more information about ventilation, see the "More Information" section. 3. If the two lights continue to flash red after you try steps 1 and 2, contact Xbox Customer Support. For more information about how to contact Xbox Customer Support, please visit the Xbox Support (http://www.xbox.com/support/) Web site.
Mar 10, 2009 | Microsoft Xbox 360 Console
My xbox 360
Call Microsoft and send it back or go to www.llama.com to get the parts and instructions to fix it yourself.
Aug 22, 2008 | Microsoft Xbox 360 Console
Xbox 360 3 red bars
Hi Andrew Jones,
According to Microsoft Support 3 red bars flashing usually means you have an hardware failure. Here is a link to Microsoft Support that may help you out.
http://support.microsoft.com/kb/907534
I hope this helps.
Sincerely,
Agent Xiong
Apr 29, 2008 | Microsoft Xbox 360 Console
Sound works but no image
This means the AV cable is not detected, try one of these...
1. Make sure that the AV cable is correctly connected to the Xbox 360 console.
2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
3. If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
4. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
If this is helpful at all, please rate, thanks!
Nov 24, 2007 | Microsoft Xbox 360 Console
Xbox shuts down during a game 3 red lights
hey johnny you will have to call microsoft and get it fixed there is one thing you can do in the mean time to temp fix it.
what you need is two towels just normal bathroom towels take everything out of your xbox e.g harddrive,controlers etc only things to leave in is the av cable and power supply as you wanna turn on the xbox lie a towel flat on the ground and lie the xbox on its side ontop of the towel turn the xbox on, you will see the error message and the red lights flash. wrap the towel around your xbox covering the air vents and then the 2nd towel put over the top. leave it on in the towels for about 20 mins then after that take all the towels off turn off the console and leave to cool down for 15 mins. turn the xbox on and it should restart again fine but only lasts for a couple of days then you have to do it again. wont fix it but will let u play while microsoft gets it.
hope this helps please rate me
regards grant
Nov 23, 2007 | Microsoft Xbox 360 Console
3 flashing lights
3 Red Lights Flashing - is a general hardware failure
  • Unplug everything and let it sit for 20 min. Re-connect and try re-starting
  • If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
  • Check the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the console flash red.
For more things to try check here
My xbox no show no picture
Check here for more things to try
Oct 30, 2007 | Microsoft Xbox 360 Console
XBOX - Flashing Red Ring on console after startup,
I had the same problem & it turned out the plugs wernt all the way in so check & make sure thaey are in
Aug 01, 2007 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
62 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
