Question about RIM BlackBerry Pearl 8100
My blackberry died, and wouldn't charge. I put a new fully charged battery in it and a picture of a battery with a red line through it came up. What is the problem?
  • 52 Answers
Ic problem on your mobile
Posted on Oct 05, 2009
My blackberry curve 8520 is at low battery and wont charge or show the charge lightning bolt
King, many times this happen, don't worry, put your device on charge 2 to 5hours it will solved, if problem persist, change battery, because this sounds me a only battery problem. there is one another way (if you are not sure don't try this) we call that direct charging
first take one charger who has light on head and then cut the charging connector of charger and then you will see two colours of wires separate the black and red wires (red wire is positive line and black is negative line) and then connect to current supply but make sure there wire are separated otherwise it will have a short circuit and then take battery and search + and - connector and then red wire connect on battery positive connector and black on negative connector if you connect properly you will see the charging light are getting dim. that mean it is charging, do direct charge for 10 min and then switch on your device with battery and put in charge normally. this will solve your problem. if my sugetion was helpful please rate it.
Jul 02, 2012 | RIM BlackBerry Curve 8520 Smartphone
My 8230 phone will not turn on put battery in and
A red light on a blackberry means the battery is flat. (Requires re-charging)
If you are confident your battery is FULLY charged and your charger is working then you may need to take your handset to a repair shop.
Try charging up the battery whilst in the handset. Let it charge for 30 mins then try and switch it on.
Remember...Blackberry handsets take longer than most to start up.
Jul 05, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
My blackberry 8310 died and wontt turn back on..i charge itt and the lcd red light just comes on
can u c the battery sign after the led light goes off with a red line or with a charging line?
Apr 25, 2010 | RIM BlackBerry Curve 8310 Smartphone
My blackberry pearl has a battery showing with a red line through it. I have charged the battery and put a brand new battery that is charged in it but the same signal keeps showing up.
There might be a problem with the USB cable. Kindly walk into the service center to get a new USB cable and try charging the Handheld.
Nov 12, 2009 | RIM BlackBerry Pearl 8100
BLACKBERRY BOLD HAS NO POWER,WILL NOT TURN ON. THE ONLY SIGN OF POWER IS THE RED INDICATOR LIGHT TOP RIGHT....ON SOLID. CARRRIED OUT REBOOT TAKING OUT SIM AND BATTERY. ANY ADVICE WOULD BE APRECIATED.
I have the same problem with my Blackberry 8120, died this morning, will not switch on, no red light, no charging light, completely dead... my computer does not recognise the blackberry at all so cant install any new software.. plus I need to recover all the information that is on the handheld... please help if you can....
Oct 15, 2009 | RIM BlackBerry Bold 9000 Smartphone
Hi in my blackberry pearl appear a battery with a red line in the screen and it does not function
it probably means that your charger isn't charging your phone fully. you need to consider getting a new battery and charger.
Oct 15, 2009 | Cell Phones
My Blackberry curve 8320 won't turn on it just has a battery icon with a red line through it on screen. The icon stays on with the backlight until the battery dies, A new battery was tried and problem...
This usually means the bb and battery got a little wet or has other issues. Try these solutions in order. They go from easisest to hardest. NOTE: If you have an insurance policy on the bb probably best just to take it in.
1. Remove the back cover. Remove the battery and the SIM card. Wait 30 seconds. Replace SIM, battery and back cover. Reboot. Plug in the bb and charge fully.
2. If that doesn't work, allow the bb to remain unplugged but ON for about 24 hours to drain the battery. Remove back cover and battery. Allow battery and opened bb to sit in a dry environment for 24 - 36 hours. Relace battery and cover. Reboot. Plug in the bb and charge fully.
3. If that fails, try another battery (a friends or one from your cellstore) to see if tat's the problem. If so, (a) retry step 2 but allow battery to FULLY drain then dry out again, (b) buy a new battery for $60 retail or (c) buy a new battery on ebay for a lot less.
4. Take in.
Jun 08, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
My NEW Blackberry 8310 won't charge! Red light flashes just once.
get a message saying my USB is not sufficient enough to charge phone ???? It works on other computers just not the one I need it to work on.
May 09, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Screen shows battery with a red line through it
3. If that fails retry step 2 but allow battery to FULLY drain then dry out again.
4. Take in.
Feb 16, 2009 | RIM BlackBerry 7130c Cell Phone
Blackberry 8310
4. Take in.
Aug 09, 2008 | AT&T BlackBerry Curve 8310 Cell Phone -...
RIM BlackBerry  Pearl  8100 Logo
252 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
