Question about Olympus Stylus 710 Digital Camera
Blue screen with error Ef08, Ef02 Anyone know
Blue screen with error Ef08, Ef02 Anyone know what it means?
Sony ccd trv 308 had a error c 31:23 and c 31:22 , beeps when trying to play and record. Found the pinch roller jam inside , took it out and fixed it with heat shrink tube, error gone , camara runs good ,...
Did you possibly hook it up right to your tv? Where was the blue screen. How do you know it recorded anything if your not sure if it works right. Is the tape moving? Sometimes it may appear to be moving and really it's not. Hear isn't a good thing with a tape recording device. I know this might sound trivial, but I would read the directions if ya got them and make sure your not skipping a step. If you record on some machines you have to switch from record back to play mode. Where is the blue screen.
May 20, 2014 | Video Cameras
Dell inspiron blue screen error with any hard drive?
Have you checked the cable from the drive to the board? If it is loose or if a wire has cracked inside the harness it can cause this failure.
Also check the drive power supply. There is a chance that the drive is not getting the correct and constant voltage to run. It has enough to get started, but the supply dies after a moment, then resets itself.
Dec 01, 2013 | Computers & Internet
Blue light flashes 8 times no pic
This is an error indication of defects inside the TV and might need service.
Aug 28, 2012 | Pioneer PDP-4280HD 42 in. Plasma...
I have an acer that will go to a blue screen after I type in the password then it restarts itself over again the same thing!
Blue screen errors, or blue screen of death (BSOD) errors, are the most severe errors Windows can encounter. Since Windows can not recover from this kernel level error, a blue screen is displayed with the error details. The error details contain a STOP error code, which indicates the type of error.
There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.
How to analyze blue screen errors
The first thing to do to analyze a blue screen error is to check the meaning of the STOP error code. You need to stop Windows from rebooting when a STOP error is encountered. Once the blue screen of death is shown, you can check the meaning of the STOP error code. Together with the filename of the driver or module, this will give an indication of the error cause.
Another option to analyze the cause of the blue screen error is to look at the Windows system event log or to debug the memory dump (minidump) that Windows created when the error occurred. The event log can be viewed using the event viewer. Right-click Computer in the Start menu, and then select Manage. In the Computer Management window select Event Viewer. The information in the event log can be of great help to isolate the cause of the blue screen error.
Reading the minidump requires a bit more technical knowledge, but Microsoft has tools to read the minidump.
The most common cause of blue screen errors
In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.
So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This will ensure that all driver bugs are fixed and that all hardware has the correct driver.
If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name.
If you do not have the drivers for all devices, or are not comfortable updating your PC's drivers manually, you can use a driver update tool to find, download and update all device drivers for you. Such tools will accurately identify your computer hardware, including any device causing an error, and automatically install the latest drivers for it.
In most cases updating or reinstalling drivers will solve your blue screen errors.
Other causes of blue screen errors
However, if updating device drivers does not fix the blue screen error, there are a number of additional things to try:
Load the default BIOS values - resource conflicts and timing issues can be caused by incorrect BIOS settings.
Update the BIOS - especially after adding new hardware or installing a Windows service pack this can help fix issues.
Update Windows - missing updates, including service packs can be a source of stop errors.
Check your system - run a virus scan and spyware scan after updating your definition files.
Driver rollback - if you have recently updated a driver, you can use the driver rollback to revert back to the previous driver version.
hope it helps, if so rate the solution
Nov 29, 2010 | Acer Aspire 3690-2196 Notebook
How do you solve blue screen stop 7b in lattitude
blue screen errors are usually from a malfunction of the ram memory ...an fatal error of the system ...or a change of hardware without re-installation ...so ..if you know that your system its intact and has to work ...usually re-installation of the operating system ...I mean a brand new one ...not repair or upgrade...but one with formatting C partition ...will fix this problem ...also restore bios settings to the factory optimal defaults
Sep 05, 2009 | Computers & Internet
Laptop display a blue error screen and immediately shut off
Hi
Blue screen problem, unplug your memory use eraser for cleaning memory and for slot of memory use toothbrush & lacquer thinner to clean it. For best solutions barrow the working memory to your friends for testing. Bad OS can cause of blue screen display, backup your files and reformat to new operating system.Bad hard disk drive can cause of blue screen problem.
Aug 12, 2009 | Compaq Computers & Internet
Blue screen appears on start up and has no icons on screen cannot do anything does anyone know what this is
How many days you working in you laptop befor coming the blue screen? -- many days, 2 days. or 3 days, then comes blue screen?..
if the blue screen come few days working.. 1) check the programs anti virus.. maybe infected of virus or programs adware.. if yo always connected to the internet posseble happen this case.. or maybe you insert somthing in your system.. like usb flash, mmc. or any device.. be carefall sometime the computer making blue screen if some system error. even you didn't see error before... 2. try make restore system if can.. just go to Start, program., accessories, system tools then, system restor..
May 31, 2009 | Asus Eee Pc 701Sd Notebook
Blue screen
A blue screen means operating system error. Your operating system will have to be either repaired or reinstalled using your recovery disc or operating system disc. A blue screen can also occur with a hard drive failure/crash. It's about 50/50 between system error and hard drive failure. If you have any issues or problems during or after the repair/reload of the operating system, then it's the hard drive and it will need to be replaced.
Jul 07, 2008 | Dell Inspiron 8600 Notebook
Olympus Stylus 710 Digital Camera Logo
55 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
