Question about Dell Inspiron 1525 Laptop Jet Black
System is shutting down abruptly . i think its bcoz of heat .. can some one tell me any software to monitor my system temp which keeps a log when a sys is shutdown due high temp
  • 3,153 Answers
Only do this if you feel competent in doing so.
Pulling apart laptops is not for the faint of heart.
If you really must do it there are some
good guides here
An alternative is to get a can of compressed air used to clean computers. Put the nozzle on and spray it in every hole you can see without putting the nozzle itself inside the laptop.
Do this outside with glasses on.
Thats because there are hidden screws.
You also have to remove the hard drive and ROM drive.
Take a
peek here for more ideas of what is involved.
There are a few are tips for various things in there.
DON'T touch the CPU cooler unless you know what you are doing and have some thermal grease for CPUs to hand
Also if you dont already have one then invest in a good 3 fan laprop cooler pad preferably with its own power supply.
NEVER use a laptop on soft surfaces as this can cause premature failure.
Hope this was of help
Posted on Oct 05, 2009
  • 74 Answers
I thinks your system cpu fan is not working properly so thats why it gets hot very fast.
Gateway intermittent shutdown
I installed a new alternater th battery is new
Dec 27, 2013 | Gateway MD2614u Notebook
Over heating pentium D HELP
the heat sink needs to be mounted tight enough to make the heat transcend and out to prevent the failsafe mechanism from shutting the system down.
May 08, 2013 | Intel Pentium D 820 Smithfield 800MHz FSB...
Jandy LX250-L Burner shuts down and no errors
It is more likely the board on the LX.
If you have a volt meter check the IND connection on the Fenwal for 24volts while running and keep your meter on it until it shuts down. If the power is still present at the IND while shutting down then it would appear to be a Fenwal problem. It sounds like the temp circuit on the board or the temp sensor it self is bad. Try dipping the temp sensor in a glass of water with a confirmed temp to see if it is accurate.
Apr 03, 2017 | Pool & Spa
I HAVE AN ASUS MB WITH A DUAL CORE ATHLON PROCESSOR 4800+.SINCE THE PROCESSOR COOLING FAN WAS FIXED IN A BAD POSITION I REMOVED THE HEAT SINK, CLEANED IT, PUT HEAT SINK COMPOUND AND FIXED IT IN THE RIGHT...
Hi.
Even if a defective CPU may decide to overheat by itself the case would be quite unusual.The problem is usually caused by a defective fan or by a fan incorrectly installed. Be sure that the fan is starting and replace the fan.
As a first step try once again reinstalling the fan. This time measure the temperature using a software like SpeedFan.
If there is no change in temperature reading, try replacing the fan. A fan with damaged bearing may provide insufficient cooling resulting in overheating.
PS: be sure that problem is temperature and not system crashing. The temperature monitoring software will tell you.
Regards.
Ginko
Jul 08, 2011 | Computers & Internet
G60-120US high temp problem
Try cleaning the fan and exhaust area with a can of dust remover. If that doesn't work i can send you a email with some steps from hp. I had the same problem but i think the dust remover is what fixed mine.
May 15, 2010 | HP G60-120US Laptop
Laptop's temp should NEVER be higher than 60-70 C. Otherwise, windows or the CPU will shut it down (my laptop never goes over 75 C, even when running games for a short time)
A few tips:
1) Laptops are a really bad choice for games. They are not designed for that and they will overheat, some of them a lot, depending on the manufacturer.
2) Check if you BIOS has an option to turn "automatic fan control" OFF. This will keep the fan running at HIGH all the time, helping somewhat with the heat (most laptops do not have this control in the BIOS)
3) Clean up the fan. Turn the laptop off, disconenct the AC charger, remove the bottom cover and blow compressed air from a compressed air can. Be sure to remove all the dust and lint. Check that the fan moves easily. Replace the cover, plug the AC charger on and try again.
4) REMOVE SPEED FAN and install CPUID's Hardware Monitor from here:
http://www.cpuid.com/hwmonitor.php
It's much better and it gives you the temps of CPU, HD and video card and also speed of fan(s)
Mar 27, 2010 | HP G60-120US Laptop
Laptop shuts off after 30+ seconds.
try to reinstal lte opperating system if you made a restore disk use that your going to have to buy a new opperating system.
Jan 20, 2010 | Computers & Internet
My pc is shutting down what should i do to prevent it?
You haven't mentioned if it turns off abruptly or shuts down telling you that the PC is shutting down.
- When your PC turns off abruptly, its mostly the CPU which heats up. The reason may vary from the CPU fan stopped working to CPU gone bad.
- If its a proper shutdown, most probably there is a virus on the PC.
KIndly feel free to ask me if you need further clarification
regards
Sandeep
Oct 25, 2009 | Computers & Internet
My laptop keeps gettin shut in between
Well some times if your processor gets on heat, it might turn off,s o i will suggest you to keep you laptop on a glass table and than use it, and you an try in safe mode as well and check if it works fine there ot not, if it wrks fine there than that means there might be some virsues or something or some thrid oarty software conflict.
Yu can check event viewer there you can find the exact cause for your shut down.
Jul 27, 2009 | HP Compaq Presario CQ50-210US Notebook
Motherboard problem?
hi- i would say that it is a heat issue. check the temps of the cpu-also check some of the bios settings, my asrock board has some bios settings that are for safe overclocking-like bumping up voltage. set these to default.-one is called vccm, then vlink,then over vcore. vccm set-to high- vlink set to normal- over vcore -disable. but do check the cpu and if you have some heat sink compound- take the heatsink off and reinstall it with the new compound. make sure you clean the old compound off. if you need more help-reply good luck!
Jul 15, 2009 | Intel Motherboard
Dell Inspiron 1525 Laptop Jet Black  Logo
mukhtar21 shaikh
mukhtar21 shaikh
