Question about Gateway E-4200 Notebook
Help with connection
I have disconnected all my wires in my tower and need help reconnecting. If you can help me or send me manual or CD-ROM connection.
  • 383 Answers
Serial port and com port help In the illustration below you can notice several factors to help correctly identify the DB9 Serial connection. First, you will notice that the DB9 , pictures are included click read and follow instructions.
Good Luck, Please dont for get to Vote. Thank You.
Posted on Dec 23, 2007
My cd rom drive plays cds rips cds reads and does cd rom programs but will not let me burn cds any more..... i was able to burn cds just fine before???? please any help?
Have you tried reseating the CD rom;verify all the connectors are securely fastened. What type of Dell is this; a tower, desktop, or laptop? If you know how to open the case then proceed with reseating as follows:
First power down the system
After opening the case
locate the CDROM
If this is a new system it is probably connected using a SATA connector (black cable with a blue connector and power connector.)
At the back of the remove each connector then reconnect the cable
The SATA or Parrellel cable has a connector at both ends so trace the cable and re-seat the connector on the motherboard as well.
close the case
boot the system back up
test the cdrom
Aug 01, 2011 | Dell Computers & Internet
I have an hp 1030nr, after powering up, it goes to a blank screen and will not do anything else
Try doing a hard reset by disconnecting everything connected to the tower (including the power cable), once everything is disconnected press and hold the power button for around 15 seconds. Reconnected everything back then power the PC on. If this procedure doesn't work, you might need to reseat the computer's Memory Modules, the Hard Drive and the CD-ROM drive.
Hope this help. Goodluck!
Mar 28, 2011 | HP Pavilion a767c (82916052406) PC Desktop
I don't know how to put my tower together, or check parts
The minimum you will need is: Power supply, Motherboard, RAM, HDD, CDROM. The manual of the motherboard will tell you where to connect everything. If you don't have it, look online. They are nearly always available on the manufacturers website.
Jul 15, 2010 | Intel Computers & Internet
My hp laptops dvd rom is not shown and is not detecting any dvd
Have you used Device Manager and done a search for new hardware? If that has not helped, then you should try to open the laptop to check whether the wires are fully connected, if these are internal.
It is possible that the wires became disconnected, and need to be reconnected to work again.
Try that.
-a.
Apr 18, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Cd rom
First use the following steps:
Use the following link, scroll a little and click on Fix It
http://support.microsoft.com/kb/314060
Click Run in the File Download dialog box and follow the steps in the wizard
When completed restart the computer and check the CD/DVD drive
(you may need to run Fix It twice)
Mar 10, 2010 | HP Pavilion a305w (DM181AR) PC Desktop
New computer tower motherboard(Intel D945GCPE), Processor(Intel Celeron 430 LGA775), memory, hard-drive(ATA), & dvd-rom(ATA). Got it all installed in new tower(ATX,I have green light on the motherboard...
First try to clear CMOS
Turn off the system and disconnect power cables
Locate the CMOS battery on the motherboard and take out the battery
Wait for about 15 minutes
Reconnect battery and try to turn it on.
If it remain same, disconnect power cables
Disconnect hard drive and CD/DVD drives
Try to turn on again.
Also check if the front panel connectors (Power SW, Reset, HDD connector) are properly connected.
Mar 09, 2010 | Intel Computers & Internet
Need to install second cd driver in desktop computer
It would be much simpler to remove your current CD-ROM drive, and install a CD/DVD-reader-writer combination drive.
1. Turn the computer off, and disconnect the AC power-cord.
2. Remove the side-panels from the case.
3. Disconnect the "power" and "data" cables from the back of the CD-ROM.
4. Remove the screws holding the current CD-ROM in position.
5. Slide the CD-ROM out the "front" of the case.
6. Slide the new device into place, until the face is "flush" with the front of the case.
7. Screw the device into position.
8. Connect the data and power cables.
9. Reconnect the AC power.
Windows will "find new hardware", and will adapt itself.
Dec 10, 2009 | Acer Computers & Internet
I have brought a new computer that dosnt have a cd rom. I have tried putting in two different cd-roms but they wont show up on my computer. i have tried downloading drivers to help but it still wont work.
Hello !
Your CD-ROM should have at least two cables connected to it: a power cable and IDE cable that should also be connected to your motherboard. Disconnect and reconnect the cables and be certain that they are snug.
Some computers will also have a small third cable used to interface the CD-ROM with the sound card. If the audio for your CD audio CDs is not working properly verify that this cable is not disconnected from the back of the CD-ROM.
Hope this helps.
Sep 19, 2009 | Dell OptiPlex GX270 PC Desktop
Dvd/cd internal drive cable(s) connection
this isn,t a big task.
1:- cable 40 strand IDE Ribbon Cable to DVD Rom. If there is a secondary device such as hard-drive. view it,s jumper ( plastic Block) setting will be Master Or Slave. Setup your DVD To Opposite of Hard-Drive ( If applicable )
2:- 4 pin Molex plug power cable, Red-Blk-Blk-Yellow. Only goes in 1 way, usually yellow facing outside edge of case.
3:- turn on computer, drive should be detected, install device drivers via CD if requested by the system.
Mike @ compurepair.
Feb 17, 2008 | Computers & Internet
Computers & Internet Logo
65 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
