Question about Maxtor Personal Storage 3100 (M01B080) 80 GB Hard Drive
I hooked up the device and the green light came on, and the usb wire worked as well but for some reason when i hooked it up to a computer it didnt read it.
  • 3 Answers
This could be an issue with the circuit board.I am facing the same problem & shown it for repairing. They are facing issue in sourcing the IC. Seagate is giving support for maxtor after it has taken over. Data recovery is possible only if the circuit is working.
Posted on Jan 25, 2010
MY NH92 ADATA External HDD detected very bad and slow some times it doesnt setected i changed my windows and test it on anothers computers but didnt change in it working. please guide me what should i do?
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Jul 19, 2012 | Computers & Internet
Rocstor icon disappears from desktop and light is half orange/green
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps you
Mar 05, 2012 | Rocstor Storage Rocstor Rocpro 225 500 GB...
I have a Kodak Easyshare CD40. It use to work fine but, now I can not down load my pictures to the computer. As soon as I turn the camera on (while it is hooked up via usb to computer) the green "on
If your photos are stored on a memory card in the camera, then remove the memory card and insert it into an USB memory card reader. Then connect the USB card reader into the USB port on your computer, the computer will see this as an external storage device, you can then open the folders and photo on the memory card and copy them to your computer.
Nov 17, 2011 | Cameras
Pass and seymour ws 3000 Hooking up to basement I have a white, black and copper wire. On the switch I have a green read and black wire. Black to black. green to ground Red to ?
You're right, green goes to ground.
Black wire connects to Hot wire from breaker box
Red goes to Load (fan, light, motor)
Ok which wire on the switch goes to the Load?
And which goes to Hot from breaker box?
You can test or you can simply hook up the device. If it doesn't work, swap the two wires.
It just won't work until the 2 wires are correct.
Oct 23, 2010 | Pass & Seymour #DDH16PBK White Fan Control...
Sony xplod amp won't work it stopped for no reason
try hooking the amp up with 3 wires, the red power wire, the black ground wire, and the remote wire, do not hook up the speakers at this time
Apr 25, 2010 | Car Audio & Video
Green charge light on, power button will not switch it on
even though the green light is on, hook it up to the usb cable2_bing.gif to your computer for a few hours,(make sure the green power light on the front is on) then press and hold the power button for up to 15 seconds.
if that fails, let me know and we can try something else
bill
ALL That is necessary for the Triumph Of evil is That good men do nothing.
Dec 09, 2009 | Tomtom ONE GPS Receiver
The screen is black and green LED lights up - what
the battery is probably to low. very common problem with these and many other models...hook it up to your computer via the usb cable for a few hours to get a good charge on it. then press and hold the power button for up to ten seconds.
if that fails, let me know and we can try something else, but this usually works 99% of the time
bill
Nov 10, 2009 | Tomtom GO 920 GPS Receiver
S9 headset
I just hooked it up with a usb sync cable to my computer. It was installed and ready to use and the charging light came on. Seems like it is charging as the led went from red to yellow, and it does turn on now. However, it still does not work with the usb cable plugged into a wall charger. If this solution works for others having the same issue kindly post your results.
Sep 16, 2008 | Motorola Mobility S9 Headphones
No sound but powers light is green
You need to determine first if sound is getting to the amplifier. Then once you are sure of that you need to run a test to see if the audio is being sent to the first pre amp in the actual amplifier. Once this is done you can determine if the samplifier is actually the problem. If it is you will need a schematic to troubleshoot the device.
Sep 07, 2007 | Jl Audio 500/1 Car Audio Amplifier
Maxtor Personal Storage 3100 (M01B080) 80 GB Hard Drive Logo
47 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
