Question about Jacuzzi - Bathtub - Alcove - Navona - R105917
Hot tub display says flo2 and doesn't respond
  • Jacuzzi Master
  • 717 Answers
That is a display error showing there is not enough water flow to activate the heater. Take the filter out of your tub and see if the error goes away. if it does then you need a clean filter. if it does not go away then you have probably have a bad pressure switch.
Posted on Sep 06, 2010
My jacuzzi J340 2002 is flashing the code FLO2. What happens if I continue to run the tub with this code displayed? Thanks to anyone that can help me.
flow switch error code, malfunctioning closed. do not use until you have rectified the error. use a jacuzzi authorized repairman/woman.
Jan 01, 2017 | Jacuzzi Home
The display panel on my hot tub shows a lock and none of the function keys respond when touched
didnt specify if you had a 4 8 or 10 button panel your unit is locked the only control that will work is temperature your owners manual has how to unlock it under side panel the following link is for an 8 button panel and the instructions are on page 6
http://qcaspas.com/media/pdf/Jewelp3-8Btn.pdf
Oct 28, 2015 | Qca Spas Jewel Series Topaz Plus Hot Tub
Hot tub doesn't heat
Steve- go to http://www.hottubworks.com/ and check out the heater trouble shooting guide. Pretty easy to narrow it down. Most common is filters being clogged (lack of flow) or heater element has burned out (easy to replace) there is a video how to do it.
Oct 02, 2012 | Master Heaters Master Hot Tub Filter
My hot tub doesn't heat up all the way even though it says it's ready
If a floating thermometer is more than 3-4 Degrees F off what the control panel display temperature then the temperature sensor has likely failed.
Jul 17, 2012 | Pool & Spa
My Apollo Rainier hot tub's heater doesn't seem to work - I get a FH message on the display. Please help!!!
HL generally stands for high limit fault which means a sensor is opening the heater circuit due to too high a heat reading. Common causes for such a fault start with poor water flow due to dirty filters which in turn allow the element to overheat. If necessary, replace the filter elements to restore proper flow.If flow issues are not the problem, try looking at the heater itself however you should probably call out a professional at this point as most remaining issues to check are within the controls and the heater and if you are not familiar with working on these components you should avoid trying to repair this yourself.
Oct 22, 2011 | Pool & Spa
The controll panel says flo2 and cool and wont turn on or heat up
Sorry for post before ment to hit the clarification. However, did some checking in general and the FLO2 display says this:
"Closed or shortened flow switch on system startup (system disabled). Flow switch in non-functional. This must only be repaired by a dealer or by a qualified service organization."
I hope this helps. Thanks for using FIXYA, good luck. Jeff
Apr 07, 2010 | Jacuzzi 8450-959 Tara Whirlpool Bath 5'-...
Heater pump does not turn on Jacuzzi hot tub 325
You should be getting error messages like flo or FLO2. check the voltage to the pump from the board if power is there the pump is bad and needs replacing
Jun 12, 2009 | Jacuzzi Amiga, Soaking Bathtub with...
Hot tub wiring
this has nothing to do with computer speakers. it is a hot tub wiring problem...
Jun 22, 2008 | Audio Players & Recorders
Jacuzzi - Bathtub - Alcove - Navona - R105917 Logo
1,277 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
