Question about Logitech Cordless USB Freedom 2.4GHz Wireless Joystick - 963283-0403
Wireless controller not working even when changed batteries. Red light flashes and no buttons work.
  • Anonymous May 31, 2008
    I have the same problem. It happened once, but miraculously started working again. Now, it doesn't seem to be coming back at all. Frustrating.
As another said, the batteries do not always contact the terminals. try rearranging the batteries. after you get it working stuff some paper in the battery compartment to keep the batteries from moving around.
Posted on Dec 25, 2008
OK I SOLVED THE PROBLEM,
ON THE USB RECIEVER, CLICK THE GREEN LIGHT, IT CLICKS, WHO KNEW, LOL ANYWAYS GOOD LUCK, PRODUCT HAS A PROBLEM ON THE THUMB KNOB BUT OVER ALL HARD TO BEAT
Posted on Jul 16, 2008
I too have this problem, and dont have the money for a new one, time too jerry rigg, the possitive contacts seem to not conduct properly im thinking in some cases, once i fixed it with aluminum foil, this time its not working, not to mention the top knob hassent worked since first week, crappy design, not made to last like a play station controller
2 Suggested Answers
jakeslimco
  • 56 Answers
SOURCE: my wireless cntroller will not flash its green center lights
sounds like.... the battery completely died on controller.. you charged it by plugging it in to system and never restarted the system to regain the wireless signal..
turn off 360... turn off controller.. boot system.. boot controller, if no signal is detected you have a hardware issue with controller (assuming other controllers work with system)
Posted on Aug 24, 2009
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Gamestop Edge PS2 Wireless controller wont work. New batteries and the square control (router) box just keeps blinking green. I pressed the button for reconnect and it still does nothing I need...
If the light on the controller is flashing then the batteries are still good. There is a small reset button on the receiver that came with the controller. use a needle to reset it while it is still in the ps2. make sure that the ps2 is turned on and the green light is flashing on it. it should blink a few times and then the light on the controller should turn red. once it does then press start and your good to go.
Hope this helps!
Nov 08, 2009 | Gamestop Edge Wireless Controller for Xbox...
My wireless cntroller will not flash its green center lights
Aug 24, 2009 | Microsoft Xbox 360 Controller
The controller won't sync with the PS3 system, even when I plug the USB connector into the USB port on the console. The red lights on top of the controller are supposed to flash when the controller is...
Putting batteries in controller
Turn on the PS3
Turn on controller
Press the sync button, the LEDs will flash rapidly
Insert the usb that comes with the controller, the LEDs flash slowly
Press the home button on the controller
READY.
Jul 12, 2009 | Intec PlayStation 3 Turbo Shock III...
Wireless Les Paul guitar light keeps flashing after I sync to 360
I had the excact same problem with a Microsoft wireless controller. It just showed it synced fine and the controller dropper off the rig right after, keeping blinking idly as always when unconnected.
Solution: When you power the console on with the X button on the controller, try pressing the connect button on the controller then, apparently the console looks for controllers when it's just opening the user interface. Had to try it twice but it synced fine just as I was giving up hope, and has been working ever since!
May 29, 2009 | Video Game Consoles & Games
Third LED lights up then, turns off and A button doesn't work
Change battery, or by new battery slot thingy and put it in.
Mar 28, 2009 | Microsoft Xbox 360 Controller
Remote contoller mode light flashing controller not working?
Hold down the connect button on the receiver and the mode button on the controller at the same time for approximately 10 seconds. This is a 2.4 GHz wireless transmitter and receiver (connection is somewhat like your WIFI router and laptop computer) and they need to reconnect sometimes.
Dec 31, 2008 | Logitech Cordless Action Controller for...
Guitar Hero Flashing Sensor Lights
Im guessing due to needing batteries that your Guitar is the Wireless type ?!
Have you correctly Synchronised your Xbox 360 with the Guitar controller ?
to do this, Turn on the Xbox and Guitar press the round "sync" button on the bottom of the guitar, next to its Ethernet port, and also press the small round sync button on the Xbox 360 (located to the left of the memory slots on the front face) at the same time, the rings of light on both the Xbox and the guitar will Turn in a clockwise motion letting you know they are synching, after that the Xbox will assign the guitar to a controller slot. then it should work.
If this doesn't work then im afraid your guitar may have a faulty wireless chip, which would require you to get a replacement.
hope it gets sorted !
Oct 28, 2008 | Activision Guitar Hero III: Legends of...
Keyboard not responding
Solution. My wireles keyboard stopped working except for the F-Lock key, the Media key and the sleep key. It wasn't batteries, even though I tried, communication was there because the above keys were working. Remove the batteries from your keyboard and let it sit for about 10 minutes. Press the red connect button a few times and other various keys every few minutes during that time. This may be the whole "capacitor discharge" trick, but I tired that with someone elses instructions and my keyboard did not work after 2 minutes of key pressing. I think it just needed more time to clear out the secure settings. Good luck, I was about to trash this keyboard until I tried again
Nov 26, 2007 | Elite Logitech Media Keyboard(KB9675590403
Logitech Cordless USB Freedom 2.4GHz Wireless Joystick - 963283-0403 Logo
335 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
