Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
What sould the fuel screw setting be aswell as the aircorrection screw
  • 8,404 Answers
Generally speaking ... the needle valve setting is 1 1/2 turns from closed. BE VERY CAREFUL WHEN CLOSING THE VALVE - DONT JAM IT INTO THE CARB - IT IS BEYONE FRAGINE - IT IS DELICATE!
Once you get it started and warmed up ... you may have to open or close the valve for optimal operation.
I hope this helps you
Posted on Oct 05, 2009
Replace the Fuel Pump
Hi, it is in the fuel tank, under the rear seat. if you lift the seat, remove the 3 philips head screw to take of the rhs cover then you will see the pump. carefully take the pipes off and the multiplug. remove the metal retaining ring. the pump can now be lifted out of the tank taking care not to damage the fuel guage sender and float rod. you will need to relace the seal aswell.
Jan 15, 2014 | 2012 Volkswagen Polo
I have a 1994 ford explorer sport the transmission in it the revers and the over drive works part time but most of the time they dont work at all 1st 2nd and drive work like they sould . could this be a...
I would check fluid condition and level. Wouldn't hurt to try and get it flushed and a no slip type additive added aswell . Lucas Oil products make a good one. However Ford transmissions in explorers are pretty common for failure.
Mar 18, 2011 | Ford Explorer Sport Cars & Trucks
Truck runs had to rise the idle screw, it soulds like a vaccum hose or a miss. no problem driving just when in any gear bad shacking at idle speed or rpm any i deals, also put new fuel filter ran a little...
Fuel injected or carburated? I would check the fuel pressure. Around 40 psi for fuel injection, 3-5 psi for carburated. Also check my tips for "Finding An Engine Electrical Miss", and "How To Find A Vacuum Leak"
Mar 12, 2010 | 1985 Dodge Ramcharger
How do find the memory slot on emaching 5118 laptop please
At the bottom of the machine there sould be covers with screws one of those sould contain the memory.
Oct 12, 2009 | E-Machines emachines (emachinees) CD-ROM...
Where is the idel adjustment screw/switch?
there sould be a nobe on the side of the bike mybe close to the fuel tank and carbs. Turn it clockwise to turn it up.
Sep 30, 2009 | 2006 Suzuki GSX 750 F (Katana)
I have a 1994 gmc diesel that will ran perfect yesturday and now i can't get it to start. i tryed putting a gas peddle init and that didn't seem to fix the problem.
check to see if there is fuel in the filter if there is none then it sould be the prime fuel pump that sould be on the frame just under the drivers seat...but on the frame of the truck!!!!
Sep 23, 2009 | 1994 GMC Sierra
I need to tune the carb on the Suzuki LT50 quad
start the mixture screw at around 1& 3/4 turns
the petcock will need a service!
aswell as flush the fuel tank & a new fuel filter!
as rust scale would be building up in the tank & going through the fuel system!!
Cheers Rob
Aug 16, 2009 | 1972 Suzuki T 350
My 2008 impala has a right rear brake grinding like metal
thhey may hhave worn the brake discs so may need machininig aswell
Cheers Rob
Aug 16, 2009 | 2008 Chevrolet Impala
Audi A6 door mirror
roll down the window. and take the interior panel off. on the inside of the door at the morror there is a plastick cover that clips out(remove it) there is foam on the iside remove that aswell. you sould see a bolt or a skrew once loose the mirror will come out. while loosening it hold the mirror in your free hand they some times just fall off.
Apr 03, 2009 | 2001 Audi A6
When i attatch the holder to the navman s series i cant plug the power cable into it, is this a design fault.
the power plug should go into the cradle first, before the device.. it sits just underneath in the plastic clip. once you slide the s-series unit down it clicks into the power cable aswell as the cradle and it sould all stay in place. It's designed so you can lift it up and out without unplugging the power.
Mar 30, 2008 | GPS
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
74 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
