Question about Audiovox VD1400HT System
Overhead DVD player works, but DVD won't eject. My husband removed whole unit and got CD out with pliers. Put back together and remounted. He said the dvd tray was bent. Now the unit will come on, but won't accept cd at all. Want to replace DVD tray, but not sure if it is easy and where to find one? I can't seem to find another (cheaper) unit with the same dimensions to replace without mounting headaches! Help!
  • 752 Answers
SOURCE: Ejecting a dvd
It's a mechanical problem and the unit needs to be opened up and serviced by a repair shop.
Posted on Sep 22, 2007
SOURCE: audiovox DVD overhead Monitor
the power supply amperes might be too low try using car batt as your power source
Posted on Nov 09, 2008
SOURCE: avd300 car dvd player is not working
I have one on eBay if you still need one.
Posted on Dec 09, 2008
  • 105 Answers
SOURCE: DVD player wont eject
Try Turning the unit off and then back on. As soon as you turn it back on push eject .
Posted on Jul 25, 2009
SOURCE: Magnavox mwd 2206 dvd vcr player....shuts off with eject word across screen.
I have the same unit (Magnavox DVD/VCR MWD 2206). If the top cover was removed, the DVD player would work fine. But if the clear plastic sensor post on the VCR side is covered, the unit would shut off. I removed the screw holding the sensor post in place and cleaned the led light under it using a cotton swab with rubbing alcohol on it. Then I screwed the clear plastic sensor back in place and cleaned it the same way. The unit now works great!
Posted on Jan 09, 2012
2010 Jetta My daughter had a cd in and loaded another one. It is a single cd player. I don't know how it took it? It won't eject. How do I get them out??
If possible remove the unit from the dash, remove the top plate and push the cd out. If not I have removed stuck cd's with small flat nosed needle nose pliers.
Nov 01, 2012 | Volkswagen Cars & Trucks
DVD won!t EJect at all
The DVD might be stuck in the disc tray for whatever reason. To get it out, you could remove all the screws on the back and bottom. Slide out the cover to retrieve the DVD. Plug it in to see if it still works. If it still appears to be working, put it back together and hope that future DVDs won't get stuck.
Jul 27, 2011 | GoVideo Televison & Video
My Phillips DVD 3050V/75 will not eject a DVD - its very low use so can't be worn out. Is there a stick something in to manually eject the DVD trick?
You will need to remove the top cover of this DVD player to remove the disc from the Drive tray. Always unplug the unit before servicing. Be careful to not touch the sensitive electronics. Remove the disc and put the unit back together exactly how you took it apart. There should only be a few screws on the back and sides of unit, holding the case of the unit to the frame and front cover.
May 17, 2011 | Philips DVP3050V/37
CD will not eject disc error comes up
May have to open the unit up and manually remove the disk be very careful to put all parts back together the way it was do not force the disk out. Try it a few times before you put it back together, be careful not to touch anything and shock your self when plugged in. Only Qualified Tech should attempt this.
Apr 08, 2010 | Bose & Wave& Music System
Disc will not eject nor play on fisher studio 24 management system. It holds 24 cds. My husband is furious, says I loaded cds backwards. PLEASE give any possible solutions. Thanks. Tina Georgia
remove the screws to your cd player and take this apart and remove the disk by hand and put system back together. It should work after that. I am a former tv technician. just be careful how you take it apart to put it back together again. do not plug unit in untill it's all done to avoid eye damage from the UV rays.
Feb 24, 2009 | Fisher Audio Players & Recorders
Cannot eject DVD or turn off machine or anything
hold your power button down for 8 seconds and the machine will power down
Feb 19, 2009 | JVC DR-MV5S DVD Recorder/VCR
Eject tray belt broke
Opening the DVD player tray is not as hard as you would think.
1. Remove three black screws holding the outer cover on the unit (located on rear of unit)
2. Carefully remove front panel trim by gently prying six clips (3 on top, 3 on bottom) away from unit and pulling panel away from unit.
3. Locate opening at the front of the DVD player that houses a larger white gear.
4. Using a finger, gently move gear until DVD tray begins to move outward.
5. Continue until DVD is fully ejected.
6. Try plugging the unit back into AC outlet and attempt to Open/Close the tray using the provided button on the Front Panel Circuit Board.
7. Reverse steps above to put unit back together.
Nov 27, 2007 | Sony SLV-D350P DVD Player/VCR
DVDs presumed stuck and the player won't eject
Hi, If you feel comfortable opening the unit, then you may remove the top cover normally held by 2 - 4 screws. The tray should be visible and most units have a locking bar right at the center to hold the discs down. Removing this (2 screws normally, 1 at each end of the bar) would expose fully the tray with the 2 discs on top. Remove the discs and put the locking bar back with the screws. You can test the unit without the top cover. Please be reminded about safety precaution when working with active/live units and laser equipment. Power it up and check if the "mech err" still shows. If not you're set to cover it up, otherwise, your probably better off seeking the services of a qualified technician. This is a generic method which normally should apply to most CD/DVD units. Good luck and kind regards.
Aug 19, 2007 | Onkyo DV-CP702 DVD Player
Sony mv-900sds overhead dvd
probably you will need to disamble it and remove check button. But the way I need instructions to connect it, I dont have wiring harness to connect it , can you help me with this?
May 01, 2007 | Sony MV-900SDS Overhead DVD/ 9" LCD Car...
Audiovox VD1400HT System Logo
196 people viewed this question
Top Audiovox Audio Players & Recorders Experts
Chinmay Joshi
Chinmay Joshi
Computer Links
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
