Question about Kenmore Washing Machines
My kenmore model 110/23822100 wont spin? is it the belt? and if so how to i get access to it?
    President:
  • 1,937 Answers
This is a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine. It doesn't use belts.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23822100
You can also get basic operating manuals (PDF files) on this site.
Also see the Whirlpool / Kenmore PDF on how these washers work including a troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If it neither drains nor spins, the first thing to check is the Lid Switch. This prevents the machine from draining and spinning if the lid is open.
I assume that you cannot hear the motor trying to turn.
To bypass the switch, you only have to disconnect the power to the washer, remove the two plastic clips from the console, remove the two screws under the clips, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the washer still won't spin, but does agitate, the problem points to the transmission "neutral drain" assembly. The Whirlpool PDF shows how this works.
If the problem points to the transmission, you'll have to remove the transmission and get to the gears.
Following is a description of removing the transmission. You don't need to remove the agitators and drive tube assembly.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit (around $15.00), put everything back together carefully and the problem may be solved.
Following is a Whirlpool parts list for commercial washers although the consumer model used the same part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Posted on Oct 05, 2009
  • kril Nov 08, 2010
    The lid switch WAS defective.......What a great simple fix......Thanks, so much!
Kenmore 70 series wont spin
the belt broke,send the model number and i can tell you how to get at the belt and the part number.
Sep 30, 2011 | Kenmore Dryers
The belt came off of the washing machine so it will not spin. We have a kenmore 80 series the model # 110.29852991. I just need to know where it goes back on please. A diagram if possible. Thanks
this unit does not have a belt,,this model number is for a direct drive washer,,,you have a coupling thats in between motor and transmisson..it looks like the picture enclosed..if we are talking about some other part ,,repost...onthejob5130_5.jpg
Sep 11, 2011 | Kenmore Washing Machines
Kenmore model 22432100 wont spinn or release the water
Hi.
Check if there is drain blockage. That will result in cycle not advancing to spin. To check drain system, check first the drain hose at the back and then access the hose connected to the drain pump. The drain pump is accessed from the bottom of the appliance. Disconnect power first.
If there is no drain problem, check pressure switch and lid switch.
Here a general article containing more detail about the no-spin problem: If you have no spin ...
Regards.
Ginko
Apr 18, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer model # 92389200 wont spin, does this washer have a belt?
No, that machine does not have a belt it has a motor coupling that does the job that the belt would do.
Mar 25, 2011 | Washing Machines
I have a Kenmore Residential Dryer Model # 97273100 (11097273100?). The dryer starts but does not spin. I assume it is the belt, but how do I access it?
I smell gas and can't find where the door panel is on my Kenmore You : Model:97273100 serial: MB3313988
Jan 16, 2011 | Dryers
The washer drum wont spin.
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
Mar 29, 2010 | Kenmore HE2 Plus Front Load Washer
Washer will kick in spin cycle, but with any type of heavy load will not spin , most times will spin if helped to get going by hand,will spin good empty or with light load.
Good day,
Without the model number or make, makes it pretty hard to come up with a solution, but if it's not a Whirlpool, Kitchenaid, Roper, or Kenmore direct drive top loader,
Remove the front panel and check the belt and tensioner.
Also, on occasion, water, and or possibly oil from an oil leak out of the bottom seal of the transmission can get on the belt and cause slippage.
P.S. On older Whirlpool and Kenmore washers, they did use a belt and you accessed it from a panel on the rear.
Belt might need adjusted, or in some cases the clutch simply wore out. Not a practical repair.
Nov 18, 2009 | Washing Machines
Wont spin
worth repairing, can likely do yourself. check the lid switch, it is probably your problem. comes complete with wires that plug in. easy fix.
Nov 08, 2009 | Kenmore Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Dryer wont spin
Take the back off  of the drier after unplugging and the beklt goes from the motor pully all the way around outside of the the drum.You can't miss it. Most of the Kenmore drier belts are the same. WE have apliance repair parts stores locally.If you also do , go to the store with the old belt and match it up.
Dec 19, 2008 | Kenmore 63942 Dryer
Washing Machines Logo
1,189 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
