I hit the on/off button and the camera powers on and then just as fast powers off. Battery is fully charged. I can veiw pictures by turning dial to favorites before powering on. LCD will then stay lit. But, it will not stay on long enough to register or to take pics in any other mode.
The reason it stays on in favorites mode is because the lens does not try to extend in review mode.
This
either means that something is jamming the lens , or that the lens
sensor is faulty. This is a very , if not the most common problem with
modern digital camera's.
Most of the time the problem is that
sand , dirt and grit gets lodged in the camera lens barrel thus keeping
it from extending properly but could also be caused by a drop or a hard
knock on the camera.
Firstly , the odds are not with you on a
DIY fix so don't be disappointed when the following steps do not
work.Nevertheless , some people have fixed their camera's using the
following steps.
Use these at own risk as it may further damage the camera.
Firstly try charging your batteries overnight and then try the camera again tomorrow. Try connecting your ac adapter or usb cable. Try holding the shutter button while switching on the camera.
These
3 options provide your camera with more power available to the
extension mechanism which could overcome some of the particles that are
lodged in there if there are any.
Try using compressed air (best
is a clean air can bought at a electronics store) and blow between the
lens and the casing. This should help dislodge some of the particles.
Look
at the lens , and if some of the lens 'circles' are misaligned or not
concentric then try wiggling it (while holding camera lens down) so
that some of the particles can escape. Also try moving the lens away
from the side with the biggest gap (also upside down)
Try gently
pushing or pulling the lens when it tries to extend but this is risky
as it may cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as
to not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
As a last resort if
you decide to replace the camera try hitting the camera near the lens
with increasing force with the palm of your hand. Between each hit ,
try using it again.
Other than that , I would take the camera to
a repair center for a evaluation to see if it would cost more to repair
than to replace the camera.If it is still under warranty I would
suggest you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy
about warranty repairs on camera's with non-brand accessories.
Hope the advise works. Good luck and don't hesitate to contact me if you need further assistance or information.
Regards Stephan
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Kodak EASYSHARE M763 Digital
my kodak m763 lens wont open. and when i turn on the camera it says kodak easyshare and it turn back...
(More)
my kodak m763 lens wont open. and when i turn on the camera it says kodak easyshare and it turn back of
my lcd screen has this really "white" look to it and it makes it very difficult to see...
(More)
my lcd screen has this really "white" look to it and it makes it very difficult to see what is on the display. How do I fix it back to normal...
Hello! EASYSHARE Model # M763 Digatal Camera.....The device does power on but only very briefly. The...
(More)
Hello! EASYSHARE Model # M763 Digatal Camera.....The device does power on but only very briefly. The back screen lights up briefly (1 second?) and flashes "Kodak EasyShare System" during this 1 second, the front telescoping lens extends out only about 1/16" and then retracts again. We are however able to view and scroll through favorite photos (the heart symbol on the top wheel switch) which works fine...(So I don't think its the battery) My 13 yr. old daughter Maria, who owns the camera, says the camera had not become wet or been dropped. Note: this camera was sent in for repair during the spring of this year as we were not able to turn it on at all and could not get anything to work at time. Thanks to you the camera was returned in working order. It was repaired and worked until late Sept. until developing the problem above.... The camera SN is KCGHL82810722 and registered to Dale Till 1550 Alta Pl. Dubuque, Iowa 52001. THX!
My Kodak Easyshare M7623 Digital camera will not come on. It is completely charged and the lens is...
(More)
My Kodak Easyshare M7623 Digital camera will not come on. It is completely charged and the lens is out. When i push the ON/OFF button the screen comes on and quickly goes of. The lens remains out the entire time. It also makes a clicking noise when on on/off button is pushed.
when i turn camera on the lens comes out as if ready to operate then closes back in again,ive...
(More)
when i turn camera on the lens comes out as if ready to operate then closes back in again,ive replaced the battery thinking this may have been the fault,but no luck,please help! thankyou David
