Question about Brute Group Office Equipment & Supplies
Hi I have a shredex Brute 400. The circuit board on the side is bad- it will only go in reverse. Can I get a new board?
3 Suggested Answers
emissionwiz
  • 76691 Answers
SOURCE: My shredex Brute 340 will
This is a paper sensor problem, that said I've searched every site I know of for parts and nothing shows fo this shredder make and model except bags and shredder drum teeth oil. I will assume then that this is an obsolete shredder parts wise, or considered a throw away item. Sorry.
Posted on Apr 22, 2011
claudeinmo
  • 9098 Answers
SOURCE: need wiring diagram for a Shredex brute 500 shredder, pulled cover off, wires pulled off switches and reset
shredex brute 400 diagram Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/shredex_brute_400_diagram... 400 diagram question. Get free help, tips & support from top experts on shredex brute 400 diagram related issues. ... Need wiring diagram for SHREDEX Model 400. Nov 17, 2011 ' ... SKETCH-500_0A.pdf. user-manual-2004... 2004 Holden ...
Posted on Aug 08, 2015
Our 400 Brute shredexx will not reverse anymore. the reverse switch seems loose and not feel the same as the regular shred switch.
Hi ! for a motorcycle switch, please visit the website below. If you need more information about a specific electrical issue you can reach me at motor@motorpartstore.com.
http://www.motorpartstore.com. good luck and have a nice day.
Apr 13, 2016 | ATVs
Need wiring diagram for a Shredex brute 500 shredder, pulled cover off, wires pulled off switches and reset
Aug 08, 2015 | Cars & Trucks
Reverse light dont work
Check for power,put shifter in reverse and check if there is power at the light ,check fuses using a test light ,check for power at the reverse light switch.
Jan 13, 2014 | 1992 GMC K2500 Truck Tail Light Circuit...
C440
Hi:
A c440 is a fuser error. Most likely the thermistor set is bad and would need to be replaced by a qualified tech.
May 28, 2011 | Toshiba e-studio 455 Copier
My shredex Brute 340 will reverse but will not shred. Can you help?
Hi, try this;
Move the power switch to AUTO (l) position and depress the manual forward button for five seconds to clear paper blockage.
Make sure the paper is engaging the sensor located in the center of the shredder opening.
Regards.
Apr 21, 2011 | Office Equipment & Supplies
I have a Motor Guide Brute 767, 67 lb thrust 24 volt trolling motor. It will only run at about half speed even with new batteries.
I believe you may have a bad low voltage circuit board problem. I do not think they make the board any longer but you may be able to convert it to work by bypassing the circuit board. I am working on one now.
Mar 22, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
I have a KitchenAid SxS model # KSRG25FTST01 with an icemaker problem. It stopped making ice, but the water still dispenses. It makes no noise and no water in the ice tray. I never hear it try to fill with...
If the thermostat behind the left side of the fill tray goes bad, the cycle will stop completely. Cost of thermostat is $20.00. Cost of new icemaker with new motor and everything including thermostat is $45.00, brand new, on EBay plus shipping. Cost for new icemaker from repair shop, $153.00 plus tax. Control board circuit panels each side of freezer compartment will go bad also stopping the ice maker cycle. these control boards come in pairs, one for each side of freezer compartment. Cost for new circuit panel control board from repair shop, $215.00. Cost from EBay brand new circuit control board $45.00 plus $8.00 shipping. Easy to install both, icemaker and control board circuit panels. Phillips screw driver and small socket set is all you need for removing and installing these items.
Jan 22, 2011 | KitchenAid KSRS25IL Side by Side...
I got a C440 error code sub code "7" with Toshiba E-Studio 352 copier. I tried to reset using 0/8- 400 but still the error code appears. what is the possible defective parts?
Hi how are you this is jack ...(jack_pak@hotmail.com)..
Dear follow the procedure
[C440] Fuser abnormality after abnormality judment.
When this code not cleat 08-400 then check these all thengs..
1.Check the thermistors
(1) Check if the connectors are disconnected.
(2) Check if the main and edge thermistors are in contact with the surface of the fuser roller properly?
(3) Check if the harnesses of the main and edge thermistors are open circuited.
2. Check the IH board and IH coil
(1) Check if the IH coil is broken.
(2) Check if the connector of the IH coil is disconnected.
(3) Check if the thermostat is blown.
(4) Check if the connectors on the IH board are disconnected (AC input connector and LGC I/F connector
CN455/456).
(5) Check if the IH board or the switching power supply unit are abnormal.
• Replace the IH control board.
3. Check the LGC board
(1) Check if the connectors CN316 are disconnected.
(2) Check if the conductor pattern on the LGC board is short circuited or open circuited.
(3) Replace the LGC board.
please vote me.
Thanks
Best Regards,
Jun 08, 2010 | Toshiba Office Equipment & Supplies
My e-studio 163 copier indicate code error c44 and how can i clear the code
Hi how are you this is jack (Jack_pak@hotmail.com)
your copier show error c44..
Dear you press 0 and 8 key simantenasly and On copier other hand.. copier panal show ..AJ.... after 1min AJ constand.. then you press 400 and Start key.. your copier show one value 5.or.6 or.7..every x.y.z ok.. Then you press 0 key and press intrept key.
COPIER REVERSE AJ MODE THEN OFF COPIER..
AND simple ON Copier.
DEAR PLEASE VOTE ME.
Thanks ,
Best Regards,
Jun 04, 2010 | Toshiba e-Studio163 Copier
Garage door does not reverse
Hi again, Thank you for getting back to me, this indicates that the main unit is OK and one or both of the sensors is bad. The basic principle of the safety circuit is that the circuit is complete or connected until broken by an object, There are several different types of sensors the most common is an led transmitter on one side and an optical receiver on the other, which shines a beam of light that requires the sensors to be aligned to "see" each other. The light on the sensor indicates that it sees the beam and if you wave your hand in front of it, it should go out indicating that it doesn't thus breaking the circuit. The light constantly on indicates something shorted in one of the sensors. You could probably hook them up one at a time to see which one might be at fault but then again you would want to replace them as a pair, and a new pair of sensors should put you back in working order. Good Luck, this should Fixsya!
Mar 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
522 people viewed this question
Top Brute Group Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Brute Group Office Equipment and Supply Expert? Answer questions, earn points and help others
