I have 2 punch amps in my classic car Iwould like to know should I have a red light lite on amp? Ihave power on amp no sound I also have EQ BEFORE AMPS could that be the problem .car has been sitting in storage for about 5 years dont have any info on amps or eq system bought with car in 90s
The red indicator indicates that the amp is inoperable, check the power to the amp and make sure it is at least 12 volts, check the ground connections for excessive resistance, no more than 3 ohms, disconnect the speaker from the amplifier and see if the red light goes out, if so check speaker wiring for shorts to ground, if the red light comes on only when the speaker is connected and the wiring checks out then the voice coil of the speaker may be shorted, if all the tests above prove ok then the Amp is defective and as a shorted output circuit, contact this web link for more help getting the amp fixed or replaced
What settings should i have my 760 watt pioneer amp set at for amp gain and bass boost in order to...
(More)
What settings should i have my 760 watt pioneer amp set at for amp gain and bass boost in order to have the best sounding hit from the subs?
Hi there, I have rubicon 204 amp., it starts after 30 min when I turn on him and works erratic (1...
(More)
Hi there, I have rubicon 204 amp., it starts after 30 min when I turn on him and works erratic (1 sec works 2 sec doesn't work, etc...). Power led is on, as have to be. Sometimes works OK. So, where the problem is ?
ok....my amp had a couple parts that were fried...(a couple capacitors and two of those chip looking...
(More)
ok....my amp had a couple parts that were fried...(a couple capacitors and two of those chip looking things. i forgot what they r called.) anyways I was told by some tech that as long as the part num (ex. RFP50N06...which is the actual num.) are the same, the new chip would work. The amp still does not work. now the old chip has the serial num on top of another num...( H9 ) now the new chips i bought has the serial num (mentioned above RFP....etc)below another code that shows " F 1G23SF. now does that make a diff, n if it does...where can I buy the actual "chip" or resistor or whatever it is called
on my 2010bxi i accidentally touched the positive to the negative input for a split second and now...
(More)
on my 2010bxi i accidentally touched the positive to the negative input for a split second and now neither the power nor protect lights come on, but a faint blue on top does still come on. what exactly is wrong and how can i repair it?
