Question about Home
Dirty dishwater comes from the kitchen sink into the bath. What can I do? I have a saniflo.
  • 302 Answers
Try snaking it to check for blockage.I don't know your specific plumbing layout...it depends on the angles,grades,etc. In this case I would try snaking and if that does not help then you might need to call a plumber.
Posted on Oct 06, 2009
We have a basement bathroom. The bath drains away very slowly, but everything else seems fine - toilet and sink draining/flushing fine. Can we use a usual unblocker (eg sodium hydorchloride) to unblock?
I worked on a lot of Saniflo products, they do not recommend using any products that have bleach or chlorine. Make sure the flapper inside the side inlet where the bath drains, is not obstructed.
Dec 03, 2012 | Saniflo & Saniplus& Macerator Pump
I have a BOSCH 425N tanlkess hot water heater. In order to get hot water to flow to the sink taps, I need to turn more than one tap on (eg. if I want hot water at kitchen sink I must also turn a bathroom...
You need to have the flow switch looked at. The low flow of the water to the lavs and the kitchen sink, they all have as small demand next to t bath or shower,
Tom
Sep 19, 2011 | Bosch 425HN NG Tankless Water Heater
3yr old saniflo + started making loud vibrating noise and smells also small black particles come out - husband opened top and looks like a mesh thing has disintegrated. Toilet is at end of sink, bath /...
Unfortunately the systems are desiged to pump out. The disintegrated screen thing is part of the maceration end of the system. Your going to have to clean the thing out and replace the macerator.
Jun 20, 2011 | Saniflo 002/003/005 Saniplus Toilet with...
Why do we get a foul smels from bath and sink when empting bath
there might be a problem with the exhaust. you may also need to clean the pipes either with a dilute bleach solution
Nov 26, 2010 | Saniflo & Saniplus& Macerator Pump
Water from sink coming up into bath, pump making a lot of noise
You have a blockage BELOW the level of the bathtub. You probably need to snake the line to clean it out. It will be hard to use any other means and assure success.
Dec 20, 2009 | Saniflo Home
Can i discharge saniflo into bath waste
These usually have a larger drain line than a shower or bath. If you are draining into a smaller drain then there will be a considerable amount of backing up. This is not a good idea. hope this helps. Good luck.
Jul 31, 2009 | Saniflo Sanibest macerator with multiple...
Dirty Dishes after dishwasher has finished
You may be getting sand in from the supply lines. Fill a clear glass container from the sink a few times and look at the bottom for sand particles. You may be getting sand from a pool filter? Remove the filter from the faucet head (it should unscrew) and look for sand particles in it. You may not be getting them in the kitchen sink if the dishwater inlets are below the sink as the particles may be sinking to the bottom of the pipes. You may need to put a filter in the dishwasher inlet. Try filling the dishwasher by hand with bottled water once and then see if the sand is still there. If so, it probably comes in through the water supply.
Nov 14, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
