Question about Magic Chef Kitchen Ranges
Drawer guide broken - Magic Chef Kitchen Ranges
Found true Model No. then ordered the piece.
Thanks, I will remember your help.
Posted on Oct 06, 2009
Bottom drawer of kenmore range rests on the floor when opened
At the back of your drawer, there should be 2 guide or glides. These glides have a slit in them.... Now pull out your drawer and look inside the frame of the range where the drawer goes. You will see a horizontal bar or or rail that goes from the front of the drawer area to the back, on both sides of the range. Those glides on the back of your drawer are supposed to "hug" that rail. Or to put it another way, that rail must go in the slot of the glides. Of course, if you are missing 1 or both of the glides, or if they are broken, then that is why the drawer falls to the floor when you open it.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 11, 2014 | Kenmore Kitchen Ranges
How do I replace a broken ice full guide?
The ice maker is easy to remove once you get the drawer off the slides. There are two plastic clips located near the back of the drawer that attach it to the slides. Pop those out and lift the drawer out. Pull off the plastic ice maker cover to expose the mounting screws. Remove the two screws holding the assembly to the top of the freezer, then slide the ice maker forward about 1/2 inch. It will drop down a few inches, allowing you to unplug the wiring connector and remove it as a unit. The ice full guide is then easily removed.
Sep 06, 2013 | Samsung RF265AA Bottom Freezer French Door...
I have a 4 draw Plano Tackle box as I have something stuck behind I can't close bottom draw,can you tell me how to remove draw as I've tried and cannot remove regards Sno
Use a long flat blade screw driver with a 1/4 inch blade. From either the right or left side, with the top drawer fully open, take the screw driver and place the blade between the inside of the outer casing and the drawer guide and gently pry the casing away from the drawer guide and pull the drawer open until you release the side catch on the drawer. You only need to free one side, and the drawer will sort of pivot out and the other side will be free at that point as well. Repeat for the rest of the drawers except for the bottom drawer which you will be able to access anything behind it as the upper drawers will not longer be blocking access when removed. I had a small bag of sinkers sitting on the bottom.
Feb 16, 2011 | Plano Four Drawer 757 Guide Series Tackle...
Top drawer won't shut all the way
Either the drawer has come off the rails or the door seal is broken and obstructing the movement of the drawer.
Either way you will have to get the drawer out and inspect the main housing. The door seal is at the top inside of the housing.
See page 7 step2 of the installation guide on instructions to get the drawer out.
Please post a comment to say if this helped.
Jul 13, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer doesn't 'seat' itself -- give error tone wont start
You need to take out the tube to see the 2 latches at the end of the 2 rails still has spring attached. The 2 latches keep the tunb in the place when it closed. They are replaceable
The white plastic guide is broken because of the the brittle plastic and it is OK.
Jul 31, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hp LJ 4 + will not load the first page from the drawer or (s)
remove the cassette and toner. turn the printer upside down and look for broken parts stuck in the silver covered guide.
Feb 13, 2009 | HP LaserJet 4 plus Printer
Need users manual, (f2) fault
Hi and welcome to FixYA!
F2 means the motor is not being sensed to be rotating. Lift off the wash arm and see if you can spin the blue impeller by hand. If it won't turn, it may be frozen of ajmed by an object like broken glass. Sometimes also if you let the drawer sit unused for a long time (some people only use the top drawer) the rotor will freeze up. The part number is a 525884P if you need a new one, it requires no tools to change it. As for the user guide, you can get one free here:
http://fisherpaykelparts.net/index.php?blockitemid=29
Dec 24, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Phaser 860 maintenance tray A stuck
1. The Maintenance Drawer will not come out. - Often times this can be overcome by waiting 2 minutes for the ?Hot Ink? timer to expire, then remove the Maintenance Drawer. 2. If the printers Maintenance Drawer is locked in place and can not be removed and there are no cleaning functions currently taking place then the Maintenance Drawer can be unlocked by removing the right side cover and move the Cap/Wipe/Purge belts evenly down to the home position. This will raise the sensor flag from I/O Left and disengage the locking pin that is preventing the Maintenance Drawer from being removed. 3. If either Maintenance Drawer Guides (Blue Plastic Rail guides) have been replaced or removed and reinstalled and this is preventing the proper insertion of the Maintenance Drawer then check on the outside of the chassis frame that both rear locking tabs for the rail guides are protruding through the printers frame and are properly seated and notched into place. ? If they are not properly installed and seated then remove the rail guides and reinstall and then test for proper insertion and removal of the printers Maintenance Drawer. 4. Obstructions or spilled ink (wax) may be covering the Drum Maintenance rail guides and preventing the proper insertion or removal of the Maintenance Drawer. ? Check the printers Drum Maintenance Rail guides for any paper scraps or spilled ink or leaking ink from the Printhead. Make sure that there is no spilled ink under the Maintenance drawer waste tray and that it is seated properly. TROUBLESHOOTING TIPS AND HINTS: In order to provide more clearance when removing the printers Drum Maintenance rail guides, use the X-axis gear to move the Printhead away from the drawer guide that you are removing/installing. Also raise the Cap/Wipe/Purge assembly to reduce interference. When a drawer rail guide is mounted, double check its rear locking tabs where they go through the chassis side frame. Both blue tabs should be visible on the outside of the frame of the printer.
Apr 28, 2008 | Office Equipment & Supplies
Ice maker drawer for sub-zero 632
Look at both those tracks on each side. its likely one or both are cracked or broken. Each one has 2 screws holding it in. To put the metal hange back in the tracks, you must get new tracks (if broken/cracked) then hold the2 tracks onto the bucket carriage...then stick thewhole thing in as an assembly, hen put the 4 screws back in. there are 2 more small screws way in the back (one on each side), but they do not have to be removed, only there to guide the racks in properly. these tracks are only about 7 bucks apeice, and shouldn't take long to chamge. Good Luck!
Aug 02, 2007 | Sub-Zero 632 / S
Kitchen Ranges Logo
47 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Sal De
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
