Question about Samsung SGH-i900 Omnia Unlocked Cellular Phone
If i for got my password how can i get into my fone
  • 52 Answers
Please you go mobile menu setting than password ok
Posted on Oct 05, 2009
I have downloaded the f secure to my mobile phone and locked my phone by mistake. now i can't unlock my phone because i don't have the default password.
Had same problem with Nokia N8. I removed SIM card & held on/off button & menu button(bottom right hand corner front of fone) for about 15secs until fone switched off. I then reinserted SIM card, switched on fone, entered my SIM (not F-secure) password & haven't had a problem since ! P.S. I also removed the micro sd card til fone was working correctly so as not to risk losing any data. Hope this helps...
Dec 21, 2010 | F-Secure Anti-virus Client Security...
I forget my password to access my memory card on my fone,pls how can l access the memory card.l dont want to loss any data on the memorycard.my email is pharmzeph@yahoo.com,my fone number is...
dear you not clear which password do you want? i mean phone security password or memory card password?? if your phone password then your default code is 12345. but if memory card password then format it from dos. but if you format from pc then your all data will be lost.
Oct 09, 2009 | Nokia 6300 Cellular Phone
I forgot my password for samsung behold
contact customer care and they should be able to supply you with a code to unlock your password
PLZ RATE THIS IF YOU FIND IT HELPED YOU IN ANY WAY TANKS.
Jul 20, 2009 | Samsung SGH-e315
My n73 phone starts with installation and says application not supported everytime.
just update ur fone firmware OR hard format ur n73... by following method:
(note : b4 u do any of the above solution remove the password of memory card and also take the backup of ur memory card through Nokia pc suite not by using cardreaders....)
hard format :
remove memory card
switch off the fone
now press call key(green) + 3 + * key
keep on pressing all three keys and switch on the fone ... dont release the keys untill the fone boots on....
the fone settings will be restored to its default... also all d security codes of fone will be retored to defaults....
now ur problem is solved .... put ur memory card back.... n if it still asks for memory card unlock password ... then jus format it .....through fone..... it wont ask again.....
regards
Bhumit
Feb 03, 2009 | Nokia N73 Cellular Phone
Function code not working
well zarshad lets solve ur first issue MEMORY CARD.
so like u told dat uve set a password to protect ur memory card from unauthorised access right?but bro the password set on that is working perfectly fine. it will prompt u the password when u will insert that card into a MEMORY CARD READER SLOT( IN LAPTOPS,DESKTOPS ETC) and IN ANOTHER N73 OR N73ME fone.so dont worry abt the card password. u can access it but not on other device except ur N73ME.
and ur next issue. THE KEYPAD LOCK. LETS GO STEP BY STEP and confirm the same steps that im telling u,u make the changes in ur fone settings ok?so here we go:-
1.Goto ur fone menu and select the SETTINGS icon,where ever its located or where ever u moved it.
2. Select the option that says SECURITY with a lock in front of it.
3. Select the option that says PHONE AND SIM.
4. select the option that says AUTOLOCK PERIOD. By default it would say NONE.
5. When ull select this,it would say NONE and USER DEFINED. So select USER DEFINED.It would Say "Lock after (minutes)". Mention the number like 1 for 1minute or 2 for 2 minutes or whatever time u want ur fone to autolock it self "1 minute" veing the least time. u can't select the time in seconds.
6.Next it would ask u for the code. By default the code is 12345 IF u haven't changed it as per ur wish.IF u've changed 12345 to other number ull have to input that number vich would be a 5 digit number.
VOILA!!!!! uve set ur fone for autolock. and ull have to input that code everytime u want to access ur fone.NOBODY n i meant it NOBODY can access ur fone after this. IVe followed the same steps n ive set up my fone to lock itself in 1 minute.IF U WANT TO LOCK IT MORE EARLY MANUALLY,PRESS THE POWER BUTTON ONCE AND THEN SELECT THE OPTION "LOCK PHONE"
WHEN U SET UP THIS AFTER LOCKING UR FONE A KEYLOCK WOULD APPEAR ON THE SCREEN.
OK?so follow these simple steps n im very sure that ur issue would resolved
Oct 03, 2008 | Nokia N73 Cellular Phone
Sgh e900
take ur sim out of ur fone turn it on and enter *2767*2878# it will reset ur fone
Sep 17, 2008 | Samsung SGH-E900 Cellular Phone
My fone is lock and i forgot the password motorola slvr lc7 metro pcs
take the phone to a mobile service center and have them reset teh code for you.
Jul 01, 2008 | Motorola Mobility SLVR L7 Cellular Phone
How to unlock privacy code t-mobil sidekick slide
all u have to do is while the fone is on take the battery and sim card and or sd memory card out. then put only the battery in and turn the fone back on while holdin down the r botton the fone will then reboot it-self twice then let the r botton go and allow the fone to turn it-self on. the fone will then turn on to the main menu screen and u will not be able to do anything wif the fone till u re-register the fone.
Mar 14, 2008 | Cell Phones
Reset password
well wen ur fone is locked u cannot turn it off so manually take the batterry out the put it bak in. after that hold the UP button while turning the fone off it will ask u to reset fone (if u do this all content WILL b erased but u cannot retrieve this information threw active sync) -also! contacts that have not been stored on sim card will b erased- use this as a last resort
u could also try typing 0000 or 1111
Dec 04, 2007 | Samsung Blackjack SGH-I607 Smartphone
Samsung SGH-i900 Omnia Unlocked Cellular Phone Logo
27 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
