Question about HP DeskJet F380 All-In-One Printer
Hello. My printer keeps saying Offline. I try to change it to Online, but it won't change. The printer was working fine until I ran out of paper. When I put paper in the printer, it decided to put itself on "Offline" and quit working. I don't know how to fix this and it is frustrating me. Thank you.
  • HP Master
  • 8,404 Answers
You can fool with it and make it work ... I suggest you remove and reinstall the device for best results. If you dont have the software, go to HP.com/support and get it. They may even have updated version for you.
Good luck with this.
a
Posted on Oct 05, 2009
    Sergeant:
  • 310 Answers
Offline usually means not connected to PC or it is turned off. Check your cable connections and power.
Printer won't work says it is paused
Check your settings , & unpause it !
Mar 17, 2015 | Office Equipment & Supplies
Won;t print keeps saying offline
Hi
Try disconnecting the printer completely from power and from the PC.
Reboot the PC.
Connect everything again.
Clear any print queues.
Check for paper jams on the printer.
Now try printing.
Feb 23, 2012 | Canon Pixma MX420 All-In-One Printer
I made some copies last week and now my printer won't print. It keeps saying it is offline. I've turned it off, changed ports into the computer, shut the computer down, and tried most of the things I can...
  • Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.
  • Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
  • Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
  • Read more: How to Change a Printer from Offline to Online ' eHow.com http://www.ehow.com/how_4796279_change-printer-offline-online.html#ixzz16oE47d1K
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Nov 30, 2010 | Canon PIXMA MP780 All-In-One InkJet...
    Printer was working fine on friday, tried to print today(monday) and it says it's offline
    It is not a printer problem, you have to check in control panel, in printer and faxes because maybe you have made your printer offline, click with the right button and make it online, thats all
    Aug 16, 2010 | Konica Minolta Bizhub 222 Black and White...
    Vista says CANON MF4370dn printer always offline? IP addrs issue?
    first of all, download updated driver from software.canon-europe.com and install ( before install, remove old drivers and programs)
    and if appears again, change your network cable.
    Mar 29, 2017 | Canon ImageCLASS MF4370dn Laser All-in-One...
    Printer displaying paper out on on control panel
    You may be able to calibrate the paper out sensor to fix the problem.
    Set the printer to Offline.
    Press the Enter and Line Feed keys together and hold pressed until the alarm sounds (typically 3 or 4 seconds).
    You should have seen briefly displayed, Tech Access On
    The display will again say Offline.
    Press the Mode Key, display will show Offline Normal.
    Press either Arrow key until display shows Offline Test.
    Press the Forms/1 key.
    Press either Arrow key until display shows Test Diag.
    Press the CPI/2 key.
    Press either Arrow key until display shows Diag Prnt Cal.
    Press the LPI/3 key.
    Press either Arrow key until display shows Pap Out.
    Press Enter
    Follow the instructions on the LCD display, which will advise on removing and reinserting the paper.
    After you have compleated the calibration place the pritner ONLINE to exit the menu.
    And finally turn the printer power off, wait ten seconds and turn the printer power on again.
    If the problem still exits you may need to repalce the lower tractors or the main logic board.
    Sep 11, 2009 | Tally Line Matrix T6100 Printer
    Laserjet 5000 printing problems
    HP Laserjet 5000 Printer
    01.Try to install the catridge properly once again after rebooting the Desktop / Laptop along with this Printer.
    02. Check through CONTROL PANEL whether this particular HP laserjet 5000 printer is showing in the printer menu.
    03. If is there, try to remove offline and make online.
    04. If this HP Laserjet not available in the Printer menu, please insert the Printer driver cd and install this printer.
    05. Try to ensure your desktop or laptop not affected with Virus. There might be a change, if the machine is virus affected, Printer offline problem will be shown.
    Have a good day.
    Jul 17, 2009 | HP LaserJet 5000n Printer
    HP Printer D7260 Printer error
    i do not have areason for why the printer continuously goes offline but there is a way to put it temporarily back online. Go to printers in the control panel. right click on d7260 and click on use printer online. This only seems to work for one or two docs before you have to repeat the process.
    Nov 16, 2008 | HP Photosmart D7260 Printer
    I ran out of paper while printing. when i added more paper the printer went offline. i can't go online. i am in safe mode and had no problem with the printer until now.
    Hello sagold15,
    For some reason your printer went offline during the out of paper. Go into your printer section and right click the printer in subject and check it the "Use printer offline" is checked. If so, uncheck it and your printer will be back online. This will help your question.
    Good luck and thank you.
    Jul 20, 2008 | HP Office Equipment & Supplies
    HP DeskJet F380 All-In-One Printer Logo
    601 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
