Question about Samsung BL103 Digital Camera
I have a sumsung bl103 and when ever i take a picture the picture come's out very white and blurry and it has lines evenly throught the picture i am very positive that this is a result of finger tips on my lens.I have tried different things to try and clean off my lens but nothin works.
5 Suggested Answers
SOURCE: samsung bl103 will turn on and beep 3 times then
Mine does the same thing. I open the battery door and close it back up. Then I push the power button and the lens will retract. When I turn it on afterwards it works fine. Mine does this quite often.
Posted on Jul 22, 2009
  • 102366 Answers
SOURCE: tried to clean lens now pictures are blurry
If you're very lucky, you can repair the damage with proper lens cleaning fluid, which you should be able to get from any good camera store (along with lens cleaning tissue). If you're unlucky, or simply not very lucky, the alcohol ate away some of the lens coating. Or perhaps the Q-tip scratched the lens.
In the future keep alcohol and Q-tips away from your lenses.
Posted on May 21, 2010
ssemul
  • 202 Answers
SOURCE: My Samsung BL103 was dropped by my daughter and
There is Lens adjustment out you need to fix this problem by opening your set and Lens block to readjust.after that it will work.care fully handel this.
Posted on Oct 30, 2010
  • 11967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 17, 2011
My camera is always blurry even before i take the picture i need HELP
Hold the shutter button half way before firing. The camera might be a little laggy with the focus. Also try cleaning the lens. Sometimes fingerprints or grim can screw up the auto-focus.
Mar 14, 2011 | Samsung BL103 Digital Camera
Blurry lense and dont know why
Good day,
Please follow the link to my tip:
http://www.fixya.com/support/r7044247-blurry_photos
The tip has some basic instructions to prevent blurry pictures.
Please feel free to let me know if the methods worked for you!
Regards
Nov 13, 2010 | Samsung BL103 Digital Camera
My samsung BL103 was taking black and white pictures. I was trying to get it back to color. I went to settings hit format, said yes or no? I hit yes and now have no pictures on my memery card. Can those...
Format completely erase the memory card with no hope of recovery. You need to dust off your manual and read it to find the correct setting for color pics.
Oct 26, 2010 | Samsung BL103 Digital Camera
I have owned an emerson tv for two years now. All of a sudden the picture has become very blurry and white. It is not the cable connection and a DVD is also white and blurry. Even the input channels are...
you must open the back cover of tv, and then things you should do is set "SCREEN" adjustment on the flyback transformer. you must turn it counterclockwise to reduce and decrease the level of screen brightness. turn screen adjustment gradually until the horizontal blanking lines disappear from the screen. and blurred images will be sharp again
Aug 11, 2010 | Emerson EWF2004 20" TV
Horizontal line pictures
am getting experience the same problem - horizontal white lines on blurry still pictures - after 2 years. But the video is working properly.
Aug 03, 2009 | Canon PowerShot A430 Digital Camera
White Lines and blurry Pictures
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
Can't repair by yourself.
It's need repair camera machine shutter.
more detail CASIO Exilim EX-Z700 overexposure
Mar 23, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Pictures too white and blurry
more detail casio ex-s600 overexpourse
Nov 09, 2007 | Casio Exilim EX-S600 Digital Camera
Casio Exilim s500--horizontal lines in picture and autofocus creates blurry pics
This is a CCD failure. Go to the Casio Tech support team. There has been an issue with a batch of CCD's and a recall on certain models of all makes This may be one of them
Jul 16, 2007 | Casio Exilim EX-S500 Digital Camera
Camara won't take pictures, screen shots look black and white blurry
Hello, please try to reset the camera and check your settings according the user manual. If you need more info please advice. Arpi
Jun 14, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Samsung BL103 Digital Camera Logo
29 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
