Question about Toastess TT-200 Turnover Toaster
Wanting to buy a toaster
  1. Toasters,
I am looking ot buy a Toastess TT-200 Turnover Toaster. Can you help me find one please?
Thankyou
Evelyn
evelynleyte@hotmail.com
  • Anonymous Dec 29, 2007
    I checked on internet for the Toastess TT-200 and i did not find one.
    Can you help me to fin this toaster !?
    therrien_mariepier@hotmail.com
  • 4 Answers
Did you try Wal-Mart... or a good hardware store? They were selling this kind of toaster just a few years ago because it was some kind of anniversary. I have a new one and one that's over 30 years old (and that's pretty good for a small appliance!)
Posted on Jun 30, 2008
Toastess -TT 215P 2 slice toaster
if you can open it up the thing that holds the tab down could have been used up already.
tnx 4 using fixya.
drcool
Sep 09, 2008 | Toastess TT-215P 2-Slice Toaster
Spring on dpp2 toaster
The spring went on our dpp2 dualit toaster, when this happens the toaster stays On permanently. I would recomend buying a safer toaster rather than trying to fix this dangerously designed toaster.
Oct 07, 2013 | Dualit Kitchen Appliances - Others
I want to buy a new toaster, what should I look for?
Before you buy a toaster, think about what you need it for. Do you have a family? If so, maybe a four slice would be better than two. What color is your kitchen? Do you want any accessories on it, like a defrost function?
Decide your answers to these questions and it will help you pick a toaster.
Jul 16, 2012 | Franklin Machine Products BUSHING, DRIVE -...
Where do you buy the special screw driver to take the bottom ff the 44336 toaster as the toaster wont stay down on that side?
Well, I don't have that type of toaster. What do the screws look like? If they look kind of like allen but an allen wrench will not work, they would be TORX.
Feb 03, 2011 | Morphy Richards 44051 4-Slice Toaster
The toaster is only cooking on one side
u have a broken element on one side. You may be able to look inside and see the broken element. If not take the ends off it may be there. No matter it is a broken element. Keep looking for the broken element it may be slightly tacked to each broken end but not good enough to allow enough current to pass through.
Oct 07, 2010 | Dualit CTS4E 4-Slice Toaster
Repair manual for T2020WT
Hey annaway, all toasters are repairable, but that only determines what the problem is, If you google teh type of toaster, under the following
1. www.google.ca
2. type repair manual
3. toasters
4. look for your brand name
Dec 01, 2007 | Toastmaster T2020WT 2-Slice Toaster
Another problem comes up....
You definitely have a problem with the hold down circuit. You will need a DMM. If you don't have one they are fairly inexpensive now and with a little reading of the instructions you should be able to master their use. Look for a fusible resistor. It should be a small shiny canister, pointed on one end flat on the other, with metal leads on each end and inline on the wire to the hold down mechanism. Once you find this, with the DMM on resistance setting (continuity), check across the device. If the DMM says infinity, in other words it shows a 1 and the display never changes, this is your problem. Replace it with a new one. They protect the device from runaway heating and are set to open at predetermined temps. Replace it witht the same rated device. Available at most electronic stores. The rating should be in centigrade (such as 160, 180, ect). This should solve your problem. You cannot solder the thermal fuse in as solder will melt when the toaster gets hot. It must be crimped to the wire. Sounds like your almost there. Good luck.
Jul 20, 2006 | Toastess TT-415P 4-Slice Toaster
The level of the toaster doesn't lock
I doubt if you can fix this without taking the unit apart. Usually it is not that difficult to remove the cover. Unplug the unit. Turn the toaster upside down and remove the screws holding the outside case on. The case usually slides off or by springing the bottom of the sides out you should be able to remove it. Once the cover is off it should be easy and obvious to fix the problem you described. When you have the unit secured reverse the order to assemble the unit and you should be back in business. Good luck.
Jul 17, 2006 | Toastess TT-415P 4-Slice Toaster
TT 200 Toastess Toaster
hi 1)yes - aluminum: solder, plastis: epoxy 2)yes if you got special gear for it 3) NO BUY A NEW 1 IT WILL COST HALF THE PRICE!! GOOD LUCK
Mar 22, 2006 | Toastess TT-200 Turnover Toaster
Toastess TT-200 Turnover Toaster Logo
199 people viewed this question
Top Toastess Kitchen Appliances - Others Experts
ray gallant
Tom Chichester
Are you a Toastess Kitchen Appliances - Other Expert? Answer questions, earn points and help others
