Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
The three colors are sereating,, like the spcetum is coming apart
Sounds like the converge has gone out. 2 parts that blend the colors together. I am looking into fixing mine by myself this time. They say if you can solder and follow a schematic, you should be able to fix it.
Posted on Oct 10, 2009
According to the description, the color wheel went out. Loud humming noise, color distortion. I got a color wheel and first, by mistake opened the back of the screen, tilted it out a little way and...
did you install the correct color wheel? Most of the samsungs had retooled bearings in some color wheels and often a jumper has to be installed for the color wheel to work properly. Your wheel should be a BP96-01103A another thing that can happen is the thin brown ribbon cable can get plugged in backwards and will prevent the color wheel from working also. That ribbon only has contacts on one side of the ribbon. I would double check that if the correct color wheel was received for your model.
Aug 08, 2011 | Samsung HL-R5668W 56" HDTV
Lost the reciever to my NXX9000 wireless keyboard
I have not known of them being sold sereately
May 06, 2010 | Lenovo Keyboard
Grenn yellow tent
the color filters are burned from heat there are three small glass filters one is red one is blue and one s green They are in the light engine.I know I have the same tv and the same problem.you have to take the light engine apart or you could replace the light engine.a lot of plugs and screws to take out just to change three colored glass plates
Feb 18, 2010 | Hitachi 42V715 Rear Projection Television
Trying to turn on tv and no picture. bought new
Rulds2008 is probably right. I had the same problem, but have no TV repair shop near me. So since I have experience fixing computers, I decided to repair the TV myself. I initially repaired the Lamp, but the TV still flashed all three lights. Called Samsung and they told me that I might need to replace the ballast, but it would be best to bring it to a repair shop. The repair shop offered to come out and look at it for $150 or bring it in for $120, even though they were about 30 mins away. Ordered both parts on www.Samsungparts.com and got them in three days. Still had the three flashing lights. Took apart the entire TV (googled it on youtube) and vacuumed and dusted the TV and took apart the color wheel (about 20-30 mins). It was completed busted. Found out that if the color wheel is broken, it will not send a signal to the ballast to tell it to start up and power the lamp. So if you have replaced the lamp and/ or the ballast and it does not light up, it is more than likely that it is your color wheel (buy it on ebay or amazon, got it in three days versus a 3-4 week back order on company sites). Also, make sure the power switch on back is being pushed upwards and not downwards or the TV also will not start. Total parts cost me ($400) versus having someone else fix it and charge me double with labor and parts. TV is better than ever. Hope this helps.
Sep 29, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Color wheel broke apart replaced that put in a new lamp and it still wont tyrn on. Lamp light blinks for a few minutes then all three front leds come on steady where should i look next
Ok so first of all regarding the color wheel, did you identify if it was one with silver or gold bearing, because if you boguth the wrong one, it's not going to work... second of all... So if you bopught the right color wheel, here's the next thing, it might be an issue with your ballast, which is also part of the light engine system, so if it's not working you will not have an image, actually if I were you, discountdashmerchantdotcom ask for the free troubleshoot, that way you can explain every detail to those guys, but like I said, if you got the rigth color wheel, it's most probable that the issue is with your ballast
Jul 24, 2009 | Samsung HLP5067W Television
No picture on my TV just audio.
sounds like the lamp is burnt out
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 21, 2009 | Mitsubishi WS-55513 55" Rear Projection...
RED, BLUE COLORS DONT WORK
two components are concerned for that type of action,
i a tube plays apart
ii on the neck of a tube, are three transistors for colors
iii color producing IC
the work is quite much take your tv to a shop, its not difficuilt to repair but involving, thanks
Mar 26, 2009 | Televison & Video
How do I replace the "color wheel" in this T.V.? (I have new one)
First you have to remove the Optics Engine itself, Locate the lamp housing and remove the lamp, the color wheel is attached to a large grey or black heat sink looking device, with two screws holding it in place. Look for a copper colored flex cable, and a small three wire plug connection to a Aluminum container. Trace these wires form the container which is by the way called the DMD Module. Tracing the wires will lead you directly to the color wheel assembly. Remove tthe two screws holding the color wheel in place and lift up gently, their is also a rubber seal around the color whee housing that needs to be replaced also but should come with the new wheel.
Mar 14, 2009 | Samsung HLN507 50" Rear Projection...
My colors are out of alignment, I can actually see three different ones they are about an inch apart on the screen and there are 3 color lines draped across the top. I get a high pitched squeal, it has had...
Convergence. very common. First question when you go into the customer menu under setup do you have the convergence option. If you do not suspect the convergence fl231 fuse problem. i hove wrote instructions under the tips and trick section. The bowed picture and line definatley indicates a loss of convergence power. There are three seprate cuircit boards that controls this convegence power, convergence amplifer and the small signal board.. the small signal board would have to be replaced by tech. as there is special equipment requird. the other two you can do. If you have convergence option try the autoconvergence option and watch to see what it does
Nov 18, 2008 | RCA HD52W59 HDTV Projection Television
Grandchild scratched large tv screen with sereated knife
It is not repairable..A new tv will have to be bought.
Nov 09, 2008 | Sony Televison & Video
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
83 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
