Question about RCA P52960 52" Rear Projection Television
Television set wont turn on .
I have this 5 yo RCA P52960. A few days ago it started to shut off by itself. Finally it gave way and stayed off. When the power button is pressed it makes a clicking sound twice in short succession, as in when a tv is turned on and off real quickly.
From reading the previous posts, it would appear that I have a damaged flyback transformer.
Firstly I would like to know how expensive this part is and an average cost of fixing it.The relevant numbers are as follows:
MODEL - P52960
SERIAL - C295C50FB
CHASIS - PTK195Y06B
  • 1 more comment
  • chica_nv08 Jan 28, 2009
    i moved my tv to another part of the room, and tried to turn it on it clicked twice and nothing,its a mitusbushi wide screen,any suggestions
  • Anonymous May 05, 2009
    my tv clicks when is plugged into wall and it doesnt turn on anymore
  • Brianna Capper
    Brianna Capper May 31, 2016
    i plug my tv up and all it does is click, it does nothing else.
Labor and parts are around 200.00 us dollars.
Posted on Jan 11, 2008
My rca p52960 tv will not turn on at all. What can
I would disconect the front control panel you can do it by opening the back of the unit on top of the light box there is a couple plugs just unplug the one going to the front panel then try to turn it on with the remote
Jan 25, 2010 | RCA P52960 52" Rear Projection Television
Set wont turn on, Beeps.
Try Resolder all of the Big Diodes around power supply.
Feb 18, 2009 | RCA P52960 52" Rear Projection Television
Rca d52w23 convergence problem error code 84
consult the fl231 problem in tips and tricks section
Dec 15, 2008 | RCA P52960 52" Rear Projection Television
Problem with RCA P52960
unplug tv from wall then turn back on
Aug 14, 2008 | RCA P52960 52" Rear Projection Television
Rca p52960 wont turn on
Humming or singing can be Shorted horiz out transistor
and bad fly back transformer........need service # off back of
set for part #'s.........T.
May 12, 2008 | RCA P52960 52" Rear Projection Television
MODEL - P52960 RCA
You have a flyback and horz output bad,price for this repair should be around 150.00 to 175.00,you also may just have a loose connection on the main board,if so price would be much less,because the flyback would not need replacing just the output
Jan 20, 2008 | RCA P52960 52" Rear Projection Television
RCA 52 inch projection Model P52960
solder connections around the flyback most likely. That is a common fault with the PTK and CTC chassis. Hope this helps.
Dec 13, 2007 | RCA P52960 52" Rear Projection Television
NO VOLUME ON MY RCA P52960 52 in.
Sounds like you need to unplug the set for about 5 min. and let it reset,this should return your sound
Nov 19, 2007 | RCA P52960 52" Rear Projection Television
RCA P52920BL
i'd like to help.that model# looks familiar.but that chassis num you gave looks more like a serial num all my rca prints go buy chassis # is there anothe num like ctc197 exet or ptk19 doc
Aug 25, 2007 | RCA P52921 52" Rear Projection Television
RCA P52960 52" Rear Projection Television Logo
309 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
