Question about Garden
I have a leak in the water pump on my Kubota F2400 and also a oil/hydraulic fluid leak somewhere underneath the engine. I need to repair them. Help.
    Champion:
  • 205 Answers
Your rear seal (oil) pump and mybe your engine seal both are out. do you have water in the pump oil? if so your water seals are out too. need to get A comlete seal kit for the pump.
Posted on Oct 11, 2009
John Deere tractors no hydraulic operation
Hi, Check fluid level, look for leaks, Listen for new or odd noises.
Hydraulics are usually pretty low maintenance, even with leaks they will continue to run for years. The issue with hydraulics is that they run at very high pressures and great care needs to be taken as a pinhole in a pipe can cause a jet of hydraulic oil able to pierce skin and potentially kill you.
That said, Is the pump working? Are any of the rams or PTOs moving at all ? If the answer is no , and the Hydraulic oil is topped up ( make sure you use the correct oil) and the oil isn't hosing out underneath, Then the pump or the pump drive is the likely problem.
If some things work and not others, look for a faulty valve in the control assembly.
Hope this helps.
Jan 06, 2018 | John Deere Garden
Tip
How to fix AUDI steering oil owerflows from reservoir
Check up the hydraulic power steering pump.
See picture below for 1.6, 1.8 liters Audi (4 cyl.) engines:
If you find leaks and noise when runing, the hydraulic vane type pump is damaged. The pump inputs air inside and mix air with oil resulting foam. Therefore fluid volume inside steering instalation rises. Then pressure overflows oil from the reservoir. You need repair or replace hydraulic vane type steering pump.
on Dec 30, 2009 | Audi A4 Cars & Trucks
Where can I find underneath view of under hood of CD Vectra Auto?
The Haynes repair manuals usually provide an underside view of the engine compartment.
The oil spot you describe seems in an unlikely place, even if it is leaking from a brake component. Clearly the origin should be checked by someone qualified to do so, who can raise the car and look underneath safely.
If brake fluid is leaking out somewhere the level in the reservoir will be falling and that you should check. Standard brake fluid is glycol based and can easily be washed away by water so it should be simple to decide whether the new patch of a fluid is brake fluid or oil.
May 13, 2017 | Cars & Trucks
Power sterring is diffulcult, barely can turn sterring wheel.
Check the power steering fluid level.
If the fluid level is low, you obviously have a leak somewhere and it should be repaired. If the level is up, watch the power steering pump while the engine is running; is the pulley turning freely?
Power steering systems are hydraulic devices. The pump provides the pressure and the steering gear or rack and pinion assembly (depending on the vehicle type) applies pressure in the direction that you are turning the wheel to assist with the steering. When the hydraulics fail or when the internal components fail, your strength is the only thing turning the steering.
But start with the fluid.
Feb 06, 2011 | 2002 Chevrolet TrailBlazer
1996 Audi A4. On a very cold morning the power steering fluid overflows from the resevoir.
If you find leaks and noise when runing, the hydraulic vane type pump is damaged. The pump **** air inside and mix air with oil resulting foam. Therefore fluid volume inside steering instalation rises. Then pressure overflows oil from the reservoir. You need repair or replace hydraulic vane type steering pump.
Dec 30, 2009 | 1996 Audi A4
Hydraulic lift pump not lifting how to replace pump on a L245 kubota trctor
I have a Ford 1700 and the first time this happened I assumed it needed the oil changed (DID NOT read the manual). After changing the hydraulic oil for about $50... it ran no better. Read the manual. Bought the hidden oil filter. Bought new oil. Problem solved. The filter on this tractor sits in the bottom of the rear end housing and collect ever piece of junk. Good! But a pain to change the filter.
Nov 12, 2009 | Garden
Antifreeze leaking underneath the water pump
If you have coolant leaking from under the water pump,you will more than likely need a new pump. Water pumps have a bleed hole built in to show if the pump seal is gone. If it is not leaking from the bleed hole, it may be from the gasket that seals the pump to the engine or it may be leaking from somewhere above the pump and collecting at that point. Good luck Moe
Apr 24, 2009 | 1992 Chrysler Town & Country
Leaking Hydraulic Fluid
Power steering fluid is the only thing the car has resembling hydralic fluid. If you follow the rubber hose all the way around from the pump to the gear box, possibly with the car running and the wheel being turned back and forth by someone while you look, you should find your leak. This is assuming it is powersteering fluid. Check your pump. Is it low? Rubber hose probably turns to steel line somewhere along the path from pump to gearbox, hope that helps ya a touch.
Mar 22, 2009 | 1999 Oldsmobile Alero
My car is leeking antifreeze
I've had similar problems and had to have the water pump replaced.
Sep 24, 2008 | 1992 Honda Accord
Garden Logo
260 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
