Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Side by side configuration - Microsoft Windows Vista Home Premium with Service Pack 1: Windows
    Novelist:
  • 171 Answers
The easiest and safest way to have a side by side windows configuration is to use a virtual machine.
on your computer install Windows, then install VirtualBox not the OS version but the full pack - its free for non-commercial use.
Then on the Virtual box install Windows again. You can have both versions running at the same time if you want :D
Posted on Oct 05, 2009
Can the management IP address of an ONT be configured?
ONT management IP addresses are classified as LAN-side management IP addresses and WAN-side IP addresses.
· The LAN-side management IP address can be configured. To do so, choose LAN > LAN Host Configuration from the main menu on the web page.
· The WAN-side management IP address is based on WAN port configurations.
§ If the WAN port statically obtains an IP address, the WAN-side management IP address can be configured. Ensure that the configured management IP address can communicate with the upper-layer device.
§ If the WAN port obtains an IP address in DHCP or PPPoE mode, the WAN-side management IP address can only be obtained from the DHCP server.
May 16, 2016 | Computers & Internet
I need the norstar modular dr5 to ring at my desk
This requires configuration programming with knowledge of how to navigate and program on the configuration side and not the administration side.
Best to call a tech/vendor in for line programming.
Mar 07, 2013 | Lands Phones
How can configure trunk
not sure about the 3COM side, but on the Cisco side... go to the configure prompt, then the port that you need to trunk (int [interface name and number] and enter)
Once you are in the interface, use the following command:
switchport trunk encap dot1q
switchport mode trunk
Then make sure that the interface is not shut down, connect the switches together and (hopefully) the 3COM will negotiate to trunking... if not you will need to manually configure the 3com.
Hope that this helps!
Jan 07, 2010 | 3Com Switch 4500 PWR 26-Port...
ASHES 2009 PC GAME incorrect configuration
you must have microsoft .net framework 3.5 to be installed in your system for this game to run in yor computer.do this and your game will run fine. copy paste the followng link for download.
http://www.microsoft.com/downloads/details.aspx?FamilyId=333325FD-AE52-4E35-B531-508D977D32A6&displaylang=en
Sep 21, 2009 | Video Game Consoles & Games
TRENDnet TEW-432BRP router cannot obtain IP through DHCP
it seems that ur PC & cable modem configuration is ok, now the problem is with ur router WAN interface configuration. the problem would be one out of 2 - first to check whether ur router wan interface is configured properly to obtain IP address from DHCP (if possible, u can give the static ip address with same series as cable modem) second to check with ur ISP.
Mar 19, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
Can I use a WD3200AAJS as a slave drive. If so what is the jumper configuration.
Hello!
The drive you have is a SATA drive, and has no master/slave configuration as such.  There is a connector block on the back to configure other options such as spread spectrum clocking.  Normal configuration is a jumper between pins 1 and 2 (all the way on the right side, facing the back).  A picture of the other configuration options is shown below.
Hope this helps you out,
Ken
Jan 07, 2009 | Western Digital Caviar WD1600 (1600YD) 160...
Can't Access Web configuraton for Cnet CWR-854 Wifi router
Have you try to update the firmware by any chance?
Let me know
comier957
Aug 10, 2008 | Cnet CWR-854 Router
Side-by-side configuration
The "side-by-side" component is associated with the Vista Windows Resource Protection (WRP). You may have a corrupted file in the SxS folder.
To resolve this issue, use the System File Checker tool (SFC.exe) to repair these files.
To do this, follow these steps:
1. Open an elevated command prompt. To do this, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as Administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow/Continue.
2. Type the following command, and then press ENTER:
sfc /scannow
(The sfc /scannow command scans all protected system files and replaces incorrect versions with correctMicrosoft versions.)
This may take some time to run, so be patient.
Hope this fixes the problem.
Apr 07, 2008 | Acer Aspire 3680 Laptop
i assume you are running vista, that particular application eror seemd common with microsoft visual studio, but is mentioned with other applications, try installing Vista SP1, seems to do the job..
Nov 29, 2007 | Acer Aspire 3680 Laptop
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
