Question about HP Photosmart M22 Digital Camera
Not turning on
With batteries fully charged the camera will not turn on when you slide it to turn it on. This happned without any reason.Can you help me
  • cupoftea Dec 26, 2007
    I fully charged the Re chargable batteries and also tapped front of camera as instructed. I also checked that it was not off ther track.When I turned it on O my it came on,so we were over the moon as we like this camera very much.So I would like to THANK fix Ya very much for their help.
    Again Many Thanks
    Vinnie
  • Anonymous Jun 07, 2008
    with batteries fully charged the camera will not turn on. when I slide it to turn it on it do-nt. I did not drop my camera it was work good the last time i had it
It is a HP software problem.
Posted on Feb 22, 2008
    Scholar:
  • 57 Answers
Hi -
We have two of these cameras. If it has been dropped, it can affect the way the camera "reads" the case sliding. Please turn the camera over and check on the bottom, and see where the cover is sliding to. If it is off track, it will not read it properly.
Also, rechargable batteries don't really work in this model worth a hoot. It is a power user. We've found only ONE kind of batteries that really make this camera work smoothly - the energizer "e" batteries in the silver and BLUE packaging. I take a LOT of pictures, and have had these last up to a month. (I am always curious about battery life and date them with a sharpie when I put them in.) Even after they no longer power the camera, they have plenty of oomph left for powering other regular items. (Our hair trimmers have been running for two months on AA taken out of the camera.)
Also, please close the slider a couple times and reopen it, making sure it is going all the way over. It doesn't always lock into place, and the camera mis-reads it as still being closed. It is a pain in the rump, and something I hope subsequent models get a modification on!
Also, simple, but double-check your batteries, and be sure they are not inserted backwards. Oftentimes, this is the reason ours won't turn on - in haste, we've put one or both in the wrong direction! Ha!
Hope that is the only problem for you.
Posted on Dec 23, 2007
Nikon troubleshooting
so long as the battery is fully charged it should turn on, you can't take a photo without a sd card but you should be able to turn the camera on and navigate menus.
it sounds like you have a defective unit
Dec 23, 2013 | Cameras
My camera does not turn on with the battery in it. When it does turn on it stays on for less than a minute. I have already replaced the battery twice.
Welcome to FixYa.
Two reasons why the camera automatically switch off.
1. The battery is exhausted
- try to insert fully charged battery or replaced a new fully charged battery.
2. The camera stopped due to malfunction.
- removed/ re-insert battery and switch the camera on.
For more details and troubleshooting steps of your camera, here is the link for your free manual. Just click here
I hope this solution will help.
Feel free to send us your comments and suggestions if this solution is helpful.
Thank you for using FixYa.
Apr 07, 2011 | Cameras
My battery is fully charged but when i turn the camera on it shuts right back off
SOunds like your battery is bad. try discharing it :
  1. Place the battery in your camera until it itself turns off. In this situation, the battery is fully discharged.
  2. Take out your battery and slide it into your battery charger.
  3. Connect your charger with power to fully charge the battery. It is normal for a new battery that battery indicator shows 100% capacity in 10 to 15 minutes. Please keep charging until there is no time left for charging.
  4. Fully charged and fully discharged or "cycled" as much as five times to condition them into performing at full capacity.
Try it and see if it works? If the batteries are not rechargeable then the problem is in the cameras power supply and you need to take it in or replace it.
Jun 13, 2010 | Sanyo VPC-T1060 Digital Camera
I have a camera kodak af. But for some reason does not working. I tried to use different battery to use but it is not working.
In order to clearly determine the fault the model of your KODAK camera is needed
However hope this will help:
If your cam use AA batt.:
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
If your cam use manufactors rechargeble batt.:
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair or new cable.
Contact KODAK:
Nov 26, 2009 | Kodak 80-210mm f/4.5-5.6 Lens for Canon AF
I have tried several new batteries,and camera wont turn on.for some reason the batteries and flash button become very warm...
Here are the steps:
Contact KODAK:
Nov 18, 2009 | Kodak Easyshare C813 Digital Camera
My Kodak af 3x optical aspheric lens camera won't turn on. it was fine yesterday but today it wont turn on. I've charged it and everything but it doesn't do anything. Help!
Here are the steps:
If issue persists, call 1.800.235.6325 for repair.
Sep 24, 2009 | Cameras
Camera won't turn on, just beeps
first check the battery... charge or replace it... else reset the camera or repair
Sep 05, 2008 | Olympus Camedia D-510 Zoom Digital Camera
Not turning on
The batteries probably need to be replaced. Be sure that any batteries seat properly and tightly. You may have to tape the battery door shut with strong tape to keep the contact tight. This type of damage is expensive to repair compared to the cost of the cameras. You can take it in and have it looked at, but be sure to get an estimate and then you can make an educated decision on whether to repair or replace it.
Best wishes to you and Thank you for using Fix Ya!
Aug 23, 2008 | HP Photosmart 435 Digital Camera
Camera will not power on or off and battery is fully charged
The symptoms you describe sound very much like a failing battery. How old is your battery? Rechargeable batteries are only meant to last for a couple years, regardless of use.
Apr 03, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Camera will not turn on.
it need to be opened by an specialist... it is sure there is nothing you can do for it without open it.
Sep 05, 2007 | Olympus Camedia D-360L Digital Camera
HP Photosmart M22 Digital Camera Logo
95 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
