Question about JVC GR-D250 Mini DV Digital Camcorder
Will not load tape battery full - JVC GR-D250 Mini DV Digital Camcorder
  • 2 more comments
  • georgefan Aug 30, 2008
    I have a JVC GR-D240 I loaded a brand new cassette and now the tape holder will not close back into the machine to load it. We have tried numerous fully charged batteries and even had it connected to the power~ nothing. It will re-open the inner holder so we can remove the tape, but refuses to sink back inside the machine.
  • Whoops266 Jan 02, 2009
    Yes Ihave the power supply plugged in and I have tried 4 different tapes, none of them will load. Without a tape the load bay closes down fine.
  • Jodie S Jan 10, 2009
    My cassette holder will not rise. THe battery is full. When we have the LCD Monitor on and the cassette holder cover open, it says Safeguard Error Code 2 but when you remove the power, Error code disappears, and when you shut the cassette holder cover, the error code works but i still cannot get a tape into it.
    Please help - I have only used the camera once.
    Cheers
  • countrypet Feb 19, 2009
    The tape holder will not close back into the machine to load it.
  • 156 Answers
EXPLAIN MORE ABOUT THE PROBLEM
Posted on Dec 25, 2007
Sony dcr-trv270e camcorder not loading the tape
problem resolved by .... 1... switching power off, removing battery and the after reconnecting battery power on + pressing the reset button on camera. This process done a couple of times.
2.. cleaner tape then loaded successfully.... ran this for a minute. 3.. camera now loading tapes as required.
Jun 16, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
Mini DV Tapes Won't Play
Please give the model and the make
Apr 16, 2008 | Sony DSR-11 DV / Mini DV VCR
Tape will not eject / Battery full
while the eject process is trying to happen remove the battery and replace it. keep initiating the eject process and removing the battery and it should finally eject. If you attempt to use the camera again put in a new tape so you don't lose a tape that contains footage you may want to save.
Dec 07, 2008 | Canon ZR100 Mini DV Digital Camcorder
DCR-HC42 will not load Mini DV
Have you all tried using a new battery? It happened to me before where I would try and load the tape and the motor just hung and wouldn't allow the tape to fully go in. I tried to recharge the battery to see if that was the problem and even left it plugged in but camcorder appeared to still be weak. I think went to Wolf's camera and asked if I may if a bigger batter would feel weird with my current camcorder (I just said that so I could see if I could borrow a new battery and see if it would fix the problem). When I installed the new battery, it loaded the tape with no problems.
Try it and tell me if it solves the problem.
Nov 22, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Installing correction tape
This tape comrs in two small cassettes the full one loads on the L. side of the printer the tape goes across lower than the ribbon and wraps on the R. cassette.
DickyO
Aug 28, 2008 | Office Equipment & Supplies
Loading tapes
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
Mar 23, 2008 | Sony Handycam HDR-HC3 HDV Digital...
Loading Media
Same problem with Backup Exec 10d and Superloader 3 LTO-3.
This is not my first problem with this Superloader. I think it is garbage and will likely be in the garbage very soon. Very expensive garbage unfortunately.
Mar 05, 2008 | Quantum SuperLoader 3 LTO-3 Tape Drive
Panasonic AG-DV2000 Mini DV loading problem
the "dv sensor"is actually a mechanical lever built into the cassette housing that moves the reel tables to match the reel spacing on mini or full-size DV tapes. check to see if this assembly is free to move. if it binds up, the reel tables may not move as far as they need to, and can cause problems similar to the one you're seeing. to inspect the mechanism, you need to remove the cassette housing. if you don't have a service manual, get a tech to help -- it's a delicate procedure for the inexperienced.
Oct 11, 2007 | Panasonic AG-DV2000 Mini DV VCR
DV tapes will not load
the "dv sensor"is actually a mechanical lever built into the cassette housing that moves the reel tables to match the reel spacing on mini or full-size DV tapes. check to see if this assembly is free to move. if it binds up, the reel tables may not move as far as they need to, and can cause problems similar to the one you're seeing. to inspect the mechanism, you need to remove the cassette housing. if you don't have a service manual, get a tech to help -- it's a delicate procedure.
Tape won't load
probobly some problem withthe load motor/ The first thing to look for is to see if the heads are spinning - or at least see if they *try* to spin, because unless they *are* spinning the tape will never load. Also, the heads *shouldn't* be spinning with no tape inserted - if they are then this suggests that the dew sensor has been activated (the heads are made to spin under this condition in an attempt to dry things out). If this gives no clues, the next step would probably be to dismantle the thing and attempt to load a tape by hand (looking for signs of jamming mechanism, etc. Anything more serious than this is one for the workshop
Mar 14, 2006 | Canon ES50 8mm Camcorder
Open Questions:
Audio drop out and/or static sound Thanks to anyone who has taken a look at my issue with audio cutting out. JVC has always been a brand I have confidence in, and I believe I picked this camera up when those recording to an internal hard drive were out of my range. Last summer, I received a fantastic deal on some JVC Evarios, so GR-D250 duo would be used only as back-up, BUT, I have a ton of old Mini DV tapes -- never recorded over anything. I would find the heads needing cleaning solution highly unlikely. The first 250 recorded the bulk of those 150 or Mini DV's and worked like a champ. Because of legal depositions for lawyers and like, who may not want for me to call time-out in a deposition to switch tapes and the fact that eventually my first was going to give out, having a back-up and eventually multiple seemed like the thing to do. Having a couple of friends film some sports events I could my mix radio play-by-play I could with dual camera angles was cool. This same-year model second buy had sat in storage; The original tape the who sold it to me with 10 minutes of footage came with it. I could tell the battery was so much stronger after a full charge than my old one, but this newer D250 has maybe had 1/10 the recording time as my original. Whether listening to the camera speakers, piping the sound from the rear A/V jack or importing via firewire, it's the same. The video may not be perfect and may "spark" or "flicker" in unison with the audio that drops out,but not always. At times, the video seems just fine but the audio drop-out is akin to a loop and I could probably time it, which was what I termed as cyclical. Could one of my friends have dropped it or tipped over a tripod and not told me? Sure, but I would think they would have told me. One night, follow some high school hoops I was importing, excited at the prospects of some two camera angles mixing. Thought I may have had a bad tape, but ruled that out right away through trying multiple tapes in bother cameras. Apologies for my loquacious follow-up; I suppose if worse comes to worse, I could check eBay for a secondhand model. I've "misplaced" my original, but it will turn up; it's simply a matter of desiring to import all that footage, since 2008, with superior editing software and skill than what I possessed when doing so initially. Thanks so much!
Apr 13, 2014 | JVC GR-D250 Mini DV Digital Camcorder
See all JVC GR-D250 Mini DV Digital Camcorder Questions
JVC GR-D250 Mini DV Digital Camcorder Logo
53 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
