Question about Dell Dimension 4600 PC Desktop
External disk attached label
The external disk attached to my PC has changed from F: to G: How can I get back to F: directory
    Problem Solver:
  • 6 Answers
With the external drive connected and detected by your computer, go into the Control Panel and open Administrative Tools. Open Computer Managment and select Disk Management. Right-click on your external drive and select Change Drive letter and Paths. You can change the drive letter to any letter that is not already in use.
Posted on Oct 05, 2009
  • Dell Master
  • 8,404 Answers
Question: Why do you care if it is F: G: or Q: for that matter?
It is a simple process but there are a lot of words in the instruction. Please Google "change drive letter" for specifics.
Good luck with your reassignment
a
My drive stopped connecting. Green light blinking fast
Try plugging it in to a different computer.
If it still fails, then the problem either is:
* power-supply (most external drives that have a 3.5-inch disk-drive inside require a power-supply; most that have a 2-inch disk-drive inside draw power from the USB port),
* adapter inside the external case (convert USB interface to SATA interface of the disk-drive) is failing,
* disk-drive inside the external case is failing.
Your best hope is that the disk-drive is OK.
Remove it from inside the external case,
and attach it as a "slave" disk-drive inside some desktop computer, and copy the files.
May 09, 2015 | Computers & Internet
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
I can't copy files from my Seagate External Hard Drive. The light is blinking but I can't open the hard drive from my computer. Earlier I was able to see the files but I can't copy them to a new hard...
Click "Safely Remove Hardware" in your tooltray (one of those little icons on the lower right
of your screen across from the START button - its a green arrow over a PC board). That'll
remove it from the system, then re-attach it (Windows Plug-n-Play will find it and re-mount
the drive).
Then, deep-scan your anti-virus software on your entire system - the possible cause of loss
of directory structure on your external HDD.
Then, run CHKDSK on your Seagate External Hard drive - to make the directory structure sane again.
How-to-do-this: START> Run > (type in) chkdsk
Then, download (free) "Recuva" software from http://www.piriform.com to recover anything lost in
making your external HDD's directory/file structure sane again.
Run Recuva in this mode:
Recuva > Options (button) > Actions (tab) > Scan for non-deleted files (for recovery from damaged or
reformatted disks)
Feb 13, 2011 | Computers & Internet
My PC cannot see the hard drive
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 06, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
My usb external Buffalo ministation is not been recognised on my pc and the LED light is flashing green and orange
* USB cable
Nov 04, 2010 | Buffalo Technology 320GB MINISTATION TURBO...
My PC failed to detect the transcend external hard drive. My name is Edwin Kakulu
* USB cable
Nov 04, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
1 tb external hard disk. Will not back up, won't get off cleaning up or indexing backup. No noise, but when I touch it, it fells like something is rubbing inside.
* USB cable
Nov 02, 2010 | LaCie Design by F. A. Porsche 160 GB Hard...
I see only one out of meny dir's in seagate freeagent go ext disk
It sounds disk I/O is creating problem refershing the contents in hard drive.
You can try changing the drive letter on your hard drive, might help.
http://www.wikihow.com/Change-a-Drive-Letter-in-Windows-XP
Also, if any kind of corruption, you can try disk error checking scandisk
http://www.pctechguide.com/tutorials/HDDMaint_Chkdsk.htm
If nothing works, there is other way to see your data in cmd
go to Start->run->type "cmd" and hit enter
To go to your External drive's letter you should know the drive for eg, if your external drive letter is D Drive just type D: in cmd and hit enter. Now you will see he prompt D:\, type dir to list the directories and files in that directory/folder
If you are able to see your files in CMD, you can still back them up
Try following link for more information
http://dosprompt.info/
Jun 02, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How do I play and/or connect to my iTunes from and external drive
LeftField,
Attach your external drive.
Create the directory on that drive that you want Itunes to store your music.
Open up Itunes.... go to the edit menu and select preferences.
Go to the advanced tab. there is an option there for change my preferred directory. Change this to the directory you created at the beginning of this instruction.
Now copy all of you songs from your music folder on the laptop to the one on the external drive.
Confirm that ALL of your songs transferred OK then delete them from the laptop.
You should NOW be all set to enjoy music from your external drive. (Be sure to always have your external drive attached when you open Itunes.... If yoou don't Itunes will look for the external, not find it and revert BACK to the default directory)
Hope this helps you
Dave
Nov 16, 2008 | Computers & Internet
My laptop vista
Have you tried powering down the laptop, and rebooting with your recovery disk in the drive? If that doesn't work, try rebooting again with an external keyboard attached. If the external keyboard works, then it's not your OS.
Nov 09, 2007 | Microsoft Windows Vista Ultimate Edition
Dell Dimension 4600 PC Desktop Logo
Alun Cox
