Question about Bose Cinemate Digital Home Theater System Speaker
Cinemate bose home theatre system
LED green light is not turning on but ready light is steady
  • 7 more comments
  • Anonymous Dec 25, 2007
    Unplug it and wait for 1 minute. System will reset and be back to normal.
  • Zapimez Feb 07, 2008
    I too have the same problem. And I have unplugged the system,waited a couple of min. replugged it into the spike arrest strip.
    And the system will not power on.
  • drblues Feb 07, 2008
    I have the same problem. I unplugged the system and waited to reset but no luck.
  • JTR4016 Feb 10, 2008
    System is getting a signal...turned off system for about 5 minutes...still no luck. Could the remote need to be reset?
  • wnl7454 Feb 22, 2008
    The bose univ remote will activate the tv but not the cinemate. Makes me think the interface is defective. Shows steady red led but will not come on.
    Can the interface be replaced?
    I did unplug the unit. Replugged and still not coming on.
  • Big Daddys Mar 16, 2008
    LED green light is not turning on but red light is on.
    And the system will not power on. New Batteries, new remote still no green light. Checked fuse its good, transformet is hot. When I first plug the unit in the green light light will flash then just the red light will be on.
  • eagle1980 Jun 28, 2008
    Unplugged and waited for an hour. Changed remote batteries. Still just a steady red light on the interface.
  • joed322 Nov 23, 2009
    have a samsung led television and my bose 123 system wont work how do i fix the problem
  • Zapimez May 11, 2010
    If my system is not recieving a signal,could the problem be as simple as weak batteries in the remote ?
    I will change the batteries in the remote,to check. ( I ) should have started there first...
Called bose they said to unplug the actual reciever piece from the back of the sub and to wait 60sec and plug back in and turn on. they also said that sometimes a surge protector can cause the remote to foul up
Posted on Jul 16, 2008
  • 138 Answers
Its becoz your System is not getting signal!
Posted on Dec 23, 2007
That was great thanks!!
Posted on Dec 26, 2007
Trying to program charter remote with bose cinemate home theatre speaker system. Does any one know the codes?
Using Universal Electronics Charter Remote OCAP 4 Device, I was able to get the volume control to work using the final code in the code listing, 31933
Aug 22, 2013 | Bose Cinemate Digital Home Theater System...
I am having a Bose Cinamate Digital Home Theater. Original remote of this was lost and bought a new Bose Solo/cinemate system universal remote. It doesn't function with the interface. Will it real
If you can't get this to work, I suggest you try to return the remote and buy and harmony remote. For me it worked very well with everything including old audio amps and you can configure your own activities.
Oct 20, 2012 | Bose Cinemate Digital Home Theater System...
Bose Cinemate green led won't come on.
Do the same thing by unplugging the power, but also unplug the interface module (box with red/green LED light) from the sub woofer / bass module, and wait 30+ seconds. Plug the interface module back in first, and screw it in as tight as possible. Then plug the power back in and try the remote. This should fix your problem. :)
If this doesn't fix it, you will have to purchase/replace this module through Bose. (anywhere from $40-$60 if not under 1-yr warranty.) If you're still under warranty, it's a free replacement.
Jun 08, 2009 | Bose Cinemate Digital Home Theater System...
No sound coming from Bose cinemate when connected to tv.
maybe you're doing something wrong? Not familiar with how it hooks up (RCA from adio out behind tv to the input of the cinemate?) You can always contact bose directly as they seem to be good as far as customer service. I would also suggest thoroughly reading the instruction manual a few times. And if all else fails, then return it.
Mar 16, 2009 | Bose Cinemate Digital Home Theater System...
No green led light on bose cinemate system
I had the problem, after a lightning surge through our house, that destroyed item connected to the telephone lines. The Cinemate interface unit stayed red (powered), but could not get green light to come on, and obviously no audio. Found through Bose tech support that the the units are failing from surges "too often". They are trying to find out why and fix the longterm problem. Tell them you had a power surge (which you likely did), the green light won't come on, but the remote works with TV, etc. They will send a UPS Return Tag for you to send back the small interface unit (only). Upon receipt, they will 2-day air you a new one. It solved the problem.
Jul 13, 2008 | Bose Cinemate Digital Home Theater System...
Bose Cinemate home theatre
The Bose codes for Comcast remotes for both the Cisco (labeled Xfinity) and Scientific Atlanta (labeled Comcast) DVR remotes are 31229 and 31933. 31933 worked with my Bose CineMate Series II
Jan 09, 2008 | Bose Cinemate Digital Home Theater System...
Need Universal Remote Code for Panasonic DVD Home Theater Sound System
Need a remote for a Bose CINEMATE Digital Home Theater Speaker System. Where can I find one?
Dec 26, 2007 | Bose Cinemate Digital Home Theater System...
Bose Cinemate Digital Home Theater System Speaker Logo
1,155 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
