Question about Sharp AR-M237 Copier
CAN'T REMEMBER (LENT OUT THE MANUEL) HOW TO ADD FAX NUMBERS. CAN YOU HELP?
  • 63 Answers
The the bottom right of the display panel there is a button that reads "Custom Settings" Either on that screen there should be an option for address control or you may have to log into the Key Operator section.
Posted on Oct 12, 2009
I would like to pre program a new fax #. add it
1. Press function 64 set to print out a directory.
2. Press function 72
Choose 1 touch
set
press the next available number with the small yellow numbers such as 02
enter fax number
set
enter name
set
Continue or press STOP
Mar 27, 2010 | Panasonic PanaFax UF-8000 Laser Fax
How can i block a junk fax number in a hp j3640 thanks in advance
Set the junk fax mode
By default, Block Junk Fax mode is turned On . If you do not subscribe to a caller ID service through your phone provider, or do not want to use this feature, you can turn off this setting.
To set the junk fax mode
Press Setup .
Press the right arrow to select Basic Fax Setup , and then press OK .
Press the right arrow to select Junk Fax Blocker Set Up .
Press the right arrow to select Block Junk Fax the press OK .
When prompted, press 1 for Yes or 2 for No .
Add numbers to the junk fax list
There are two ways to add a number to your junk list. You can select numbers from your caller ID history, or you can enter new numbers. The numbers in your junk list will be blocked if Block Junk Fax mode is set to On .
To select a number from the caller ID list
Press Setup .
Press the right arrow to select Basic Fax Setup then press OK .
Press the right arrow to select Add Number to Junk List , and then press the right arrow to select Number and then press OK .
Press the right arrow to scroll through the numbers from which you have received faxes. When the number you want to block appears, press OK to select it.
When the Select Another? prompt displays, do one of the following:
If you want to add another number to the list of junk fax numbers , press 1 to select Yes , and then repeat step 4 for each number you want to block.
If you are done , press 2 to select No .
To manually enter a number to block
Press Setup .
Press the right arrow to select Basic Fax Setup press OK .
Then press the right arrow to select Junk Fax Blocker Set Up and then press OK .
Press the right arrow to select Add Number to Junk List press OK , and then press the right arrow to select Enter Number .
Use the keypad to enter a fax number to block and then press OK . Make sure you enter the fax number as it appears on the display, and not the fax number that appears on the fax header of the received fax, as these numbers can be different.
When the Enter Another? prompt displays, do one of the following:
Remove numbers from the junk fax list
If you no longer want to block a fax number that number can be removed from the junk fax list.
To remove numbers from the junk fax list
Press Setup .
Press the right arrow to select Basic Fax Setup then press OK , and then press the right arrow again to select Junk Fax Blocker Set Up then press OK .
Press the right arrow to select Remove Number from Junk List .
Press the right arrow to scroll through the blocked numbers. When the number you want to remove displays, press OK to select it.
When the Delete Another? prompt displays, do one of the following:
If you want to remove another number from the list of junk fax numbers , press 1 to select Yes , and then repeat step 4 for each number you want to block.
If you subscribe to a caller ID service through your phone provider, you can block specific fax numbers, so the HP Fax does not print faxes received from those numbers in the future. When an incoming fax call is received, the HP Fax compares the number to the list of junk fax numbers you set up to determine if the call should be blocked. If the number matches a number in the blocked fax numbers list, the fax is not printed. (The maximum number of fax numbers you can block varies by model.)
Thank you.
Sep 17, 2009 | HP J3680 Officejet All In One Printer
I need to add a pause to a dialed number when sending a fax because I need to add the extension. Any Ideas on how to do this, someone suggested I use a coma but how?
a comma is used on a computer based fax/modem to insert a pause between numbers or commands.  A # should solve your problem, and insert a pause as your numbers are dialed. This will only work for stored numbers, not when manually dialing.
Mar 25, 2009 | Brother IntelliFax-2820 Laser Fax
BLOCKED CALLS
specific fax numbers so the device does not print faxes received from those numbers.
When an incoming fax call is received, the device compares the number to the list of
junk fax numbers to determine if the call should be blocked. If the number matches a
By default, Block Junk Fax mode is turned On. If you do not subscribe to a caller ID
off this setting.
▲ Some models have a Block Junk Fax button. Depending on the model you have,
Block Junk Fax button: Press the Junk Fax Blocker button, select the Block
Junk Fax option, and then select On or Off.
Color display menu: Press Setup, select Basic Fax Menu, select Junk Fax
Blocker Setup, select Block Junk Fax, and then select On or Off.
your caller ID history, or you can enter new numbers. The numbers in your junk list are
blocked if Block Junk Fax mode is set to On.
Feb 11, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Add and delete names and numbers from broadcast
How do I change the name and phone # on my fax machine. Sharp UX-510
Nov 25, 2008 | Sharp UX 510 Plain Paper Thermal transfer...
Adding to an established Group Dial list
In most fax machines you cannot edit a GROUP, you can only delete it and create a new group.
Nov 24, 2008 | Canon LC-3175 Laser Fax
I need to store a lot of fax numbers and every monday send out a mass fax to all of these numbers. How do I do this?
Press Function 72
Choose ONE TOUCH
Put the numbers in one touch positions 01...02...03...etc.
Press Function 73
SET
Choose GROUP
Press PROGRAM 1 on soft pad and name it. Press SET
Add the one touch numbers into PROGRAM 1 by pressing their numbers on the soft touch pad.
01...02...03...etc. SET....STOP
Nov 17, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
How do I do group faxing from my Canon L80 fax ?
Click here and download the user guide. The process is on page 6-13. You will most likely have to set up the numbers of the group in a "One touch speed dial" or "coded speed dial" before you add them to the group. Remember to leave the "one touch key" that you want to use for the group dial blank. Hope this helps....
let me know if you need anymore help.
Nov 13, 2008 | Canon FAXPHONE L80 Laser
How to add fax numbers and edit
User tools, system settings, admin tools, address book management. It is in that area.
Feb 19, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
How to Add Speed Dial Numbers -- Can't find menu
The easiest way is to use the intranet interface. Enter the IP address of the fax machine into your web browser on your computer (on the same network) and you will get the interface. Select the administrator role (hopefully the password will still be blank), and then go to the address section. You can enter speed dial numbers there.
Jan 30, 2008 | Canon LaserCLASS Fax 710 Printer
Sharp AR-M237 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
