Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
The compressors stops working sometimes and starts working again. What is wrong?
    Top Expert:
  • GE Master
  • 12,868 Answers
If doing it and their is no problem with temp unit working fine ---if not working fine either overheating or low freon overheating can b resolved most of the time by cleaning [ vacuum] the coils around compressor if problem continues after above will need to be serviced for either freon or elect controls
Posted on Oct 05, 2009
What causes compressor to work fine then shut down and not come back on for an extended amount of time?
Sometimes these AC's need to be removed and given a damm good cleaning with a spray hose, and any filters replaced. Clean the internal fan(s).
This can sometimes fix overharting of the compressor or misleading air temp sensing..
Jul 08, 2015 | Frigidaire FRA296ST2 Air Conditioner
Air compressor cannot spin up with pressure in tank sometimes
There is an unloader valve and a check valve on the discharge side of the pump. The check valve is not holding and the unloader is not dumping the pressure so the compressor cannot start. Since it is new, you may want to take it back. If not you are going to be replacing parts.
Mar 10, 2014 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
RS267LBSH The refrigerator stopped working. The technician came and replaced the compressor. It works for 1 1/2 month and failed again. He came the second time and replaced the evaporator. A month
your getting ripped off try the defrost timer sounds like it is getting stuck, it operates on a 24 hour basis cycling between defrost, and turning compressor on and fan to cool the fridge
Sep 02, 2012 | Samsung Refrigerators
Ge side by side tfg20jaww compressor stopped running
Try a hard start kit sized for your fridge compressor. Local supplier should have one in the $20.00 range fairly easy to install directions on packaging just need to pull the lower back panel. if it works save up for a new fridge as this fix will last a year or two at best.
Mar 02, 2012 | GE Refrigerators
Whirlpool American side by side fridge/freezer is making a clicking noise. Sometimes it lasts a few minutes and other times it can last over an hour. If I open the doors its stops and as soon as I close...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 17, 2011 | Whirlpool ED2FHEXN Side by Side...
Hello, I got this Kenmore 58585892 from a friend, who said that it quit working; he plugged it in and it worked, but then it stopped again, so he got rid of it. I fiddled with it and found that the fan...
The problem you describe is have to with electric parts and not mechanical parts. So it worth a lot to fix it since it is not an expensive part.
However the electric problems are peculiar and costand like yours and sometimes take time to be identify and be fixed.
The most possible in you case are:
1. the thermsostat it might becoming stuck since it have electric contacts so when the fridge whould stop working you must check these contacts if they stay open permanetly, thus to replace the thermostat.
2.If the thermostat is ok then you need to check the starting capacitor of the compressor or the starting relay of the cmpressor the two parts in the black box attached to the compressor which one of them and sometime both ot thm have overhetaed and sometimes stuck and they can not start the compressor.
In any case even if you replace all three then it worth the cost for this fridge.
Jul 07, 2011 | Refrigerators
Amana refrigerator/freezer started making a buzzing noise and stopped working. Inside lights do work, but nothing cools.
based on your description i would guess that the start relay on the compressor has failed or the compressor it self is the buzz you are hearing... if the noise would come and last for 5-20 seconds and then stop or click sound made then that is the compressor trying to start but kicking out on overload. it usually after sometimes a few minutes or sometimes in thirty minutes will try again once the compressor gets hot enought it may take longer.. you will have to gain access to rear of unit and on compressor is a relay that may have failed. make a drawing of the wires and remove sometimes (2) seperate pieces see if it rattles or smells burnt. if so get you a new relay and may have caught it early enough to not have done any other damage... repost with anymore questions good luck to you...
ps there are several web sites to order the parts online or go to a local appliance store...
www.sears.com hit the parts direct link up top of page then enter model number
www.repairclinic.com
www.apdepot.com reputable companies...
Feb 11, 2011 | Refrigerators
Freezer stops freezing, works for a while, then stops again. What might the problem be? It is a side-by-side. Sometimes the refriderator side also varies in temperature. Gregg Wakefield
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Oct 27, 2010 | Microwave Ovens
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
120 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
