Question about Boating
I just got a minn kota endura 55 and all the forward speeds work but none of the reverse speeds work - were can I get wire diagram or manual or just help to fix this
    Guru:
  • 597 Answers
Http://www.minnkotamotors.com/products/trolling_motors/freshwater_transom_mount/endura.aspx
This is the web page for this type of trolling motor. Sounds like they have a good warranty. I would suggest contacting them. If you have forward but no reverse then one of the switches isn't working right and tearing it apart yourself may void the warranty.
Posted on Oct 18, 2009
Minn kota trolling motor has forward but no reverse
Don't know what Minn Kota you are talking abut but my 55 pound Thrust one does NOT have a Reverse.... When I want reverse I swing the Prop all the way around so it is pulling the boat backwards..... I just checked it to refresh my memory......
May 08, 2014 | Minn Kota Boating
My minn kota endura 55 is three years old is making a grinding noise when in operation..
I had this problem with my MinnKota Endura 35. The gear teeth that turn the prop are off center and need to be realigned. You need to take it to a service depot as trying to open the casing yourself may do more damage. Plus when it it put back together you need to ensure that it is water tight again.
Cost me around $85 at the local marine mechanic...
May 22, 2011 | Minn Kota Endura 55 42 In Trolling Motor...
I have a 5 speed forward minn kota only 3 speeds work ,I replaced the speed control box but have the same problem
Check the Relay's these will be found in the control module, Most likely totaly sealed, test or replacement may be required
Aug 26, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
MY MINN KOTA 30LB THRUST MOTOR HAS DEVELOPED A NOISE IN THE LOWER UNIT LIKE A LOOSE BEARING.IT SEEMS TO BE WORSE IN REVERSE
Hi!
Here is a schematic for your motor:
Endura 30
It sounds like the motor has leaked water into it and wil need to be cleaned up, have the brushes, seal kit and bearings replaced.
Best of luck!
Mike
Jul 09, 2009 | Minn Kota Endura 30 Freshwater Transom...
I need a truster speed for a Minn Kota Endura 46
Hi!
Here is a scchematic with part numbers and service center listing as well:
Endura 46
Best of luck!
Mike
Jun 21, 2009 | Minn Kota Endura 30 Freshwater Transom...
MinnKota Endura 50 Runs only in high speed in forward and reverse
the coil pack is likely bad especially since you changed the switch. call minkota and get the bench tast info (very simple) and then order and replace the coil pack about 26 dollars. be very careful how you put the magnet assembly back together and mark the position of the case on the outside before disassembly. order a new seal kit and use locktite on the shaft again when reassemling to seal the shaft tube for water. dont run motor uout of the water much as it uses the water to cool the shaft and you can damage the seals. good luck.
Jun 18, 2009 | Minn Kota Endura 30 Freshwater Transom...
Motor on ly runs on high speed
Hello rhett700, you have crossed a wire connection on the switch or your reostat is shorted/bypassed. If need be contact 'www.minnkotamotors.com/index.asp' ask for ext#406 ask for Dave. Have your model & serial # on hand. He is a good guy. Merry Christmas.
Sep 01, 2008 | Minn Kota Endura 30 Freshwater Transom...
Boating Logo
291 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
