There is a round plastic bit that wont come out of bottm
  • 835 Answers
If u can reach it, find something then and narrow, put some tape on the bottom of it, where it sticks to the stick, but also has the sticky part out. just push that down inot the bottom, and try to pull it out that way.
if that doesn't work, and you wanna take the lost, just leave it in their, its plastic, it shouldn't hurt anything just sitting in the bottom.
Posted on Oct 05, 2009
Got widgets on face of main screen can't get them off
Press and hold the widget, then a garbage can will appear at the top of bottm of the screen. Drag the widget there. It doesn't delete the widget, just moves it off that pagd.
May 09, 2014 | Samsung SGH T139 Hard Plastic Case Flower...
Hotpoint dryer wont go round and round
Sounds like your drum belt has snapped, worn out or slipped off. It's a long belt that goes round the drum and a small motor. Have a look underneath - it might be hanging loose. Switch off at the plug first. Easy enough fix with some basic tools and a bit of time. Buy the belt off ebay when you are sure that is the problem. Vac all the fluff out of the machine while you are in there too.
Feb 17, 2013 | Washing Machines
Door is locked, wont open
remove bottom acces panel 1/4 screw sometimes torx bit ubplug washer reach in on non hinge side against doorshould be door lock latch assymbley, bottom of latch assymbley is a round plastic end thats spring loaded ,pull downward and open door replace door lock assymbley
Jan 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How to remove the rear seat headrests
on the top of the seat on one or both of the metal rods is a round plastic sort of guide ,well one or both have a plastic bit that you pull out and then it will come out
Jan 13, 2011 | 2005 Ford F-150
Plastic round clip for rubber seal on zwx 1605
that is the retainer for the rubber seal you will see a ring mark where it goes back on. you will need some plyers to put it back on in the ring.
Jun 21, 2017 | Washing Machines
Washer is not agitating.
LOOK BETWEEN THE MOTOR AND THE TRANSMITION , SEE IF THE WHITE COLLECTER PRONS ARE BROKEN
Aug 31, 2009 | Washing Machines
Removal of ignition switch
remove the plastic covering on the column to expose the ignition, it will be a round plastic cylinder attached ot the backl of the ignition.
you will ned a t4 star bit with a nut driver handle to remove.
Nov 26, 2008 | Hyundai Excel Cars & Trucks
Zanussi jetsystem 1600
Could it be a blockage? Try pulling the dispenser drawer out, then dismantle the drawer and give the parts a good wash in a sink. Run water through any holes to clear them of hardened softener.
Sep 01, 2008 | Zanussi FJS1225W Front Load Washer
Hello can you help me??
pull it apart. carefully lever off the cover from the power switch, and remove the small broken bit of black plastic. (it's that broken bit that is your problem.) BE CAREFULL not to disturb the small round metal contact.
now when you poke the small round metal contact you should hear it click as it turns on and off.
to be able to do this when you've put the covers back on, drill a small hole in the back cover above where the contact is. Then you can turn on/off the player by poking a paper clip through the hole.
Jun 15, 2008 | Coby MP-C7085 MP3 Player
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
