We are getting grease or something leaking into the wash. Any ideas?
  • 116 Answers
Could be a seal in the gear drive box or a bearing.
Posted on Oct 05, 2009
Hoover 700lc is putting grease on clothes
The only part of the washer that has oil or grease is the transmission. This is a very bad sign because it says the transmission is leaking and the center seal is also letting the oil grease come through. I would start looking at new machines because it wont be cost effective to repair if you pay a service comapny and if you've never done one its not something you want tot learn on.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 28, 2012 | Hoover Washing Machines
HOW DO I REMOVE THE AGITATOR TO FIX THE PROBLEM OF GREASE /TRANSMISSION FLUID GETTING ON THE CLOTHING DURING THE WASH. IS THAT THE SOURCE OF THE PROBLEM?
The top blunt end of the agitator is threaded and when removed allows to agitator to come off. Lots of lint and old soap accumulate there and can pretty much "glue" the agitator in place. Once gone, you will see the drive shaft from the gearbox sticking up. I think you need to pull the gearbox to get to the seal. The gearbox is filled with nasty surpy "blackjack" grease and can be reused. You might get the repair kit from the manufacturer. That will include all the seals and "O" rings needed to keep the tub from leaking and the grease inside the gearbox.
Dec 13, 2011 | Washing Machines
Kenmore washing machine - 7 years old - is leaking grease under the front right side of it. What could be the cause of this?
The only part that has gease is the gearcase. It is a sealed system and you can not fix it,you need a new gearcase. You should just replace the entire washer. Sorry
Jun 11, 2011 | Kenmore 24032\24036 Top Load Washer
GE WSXH208FWW washer leaving spots on clothes
If you are getting round dark spots on your clothes after washing, the problem would be cause by a bearing seal leak. What happens is water leaks pass the seal into the bearings, and the grease leaks back into the wash water. To fix it would require the machine to be literally taken completely apart to get to the bearings. Very costly to repair. Sorry.
Aug 24, 2010 | GE WSXH208A Front Load Washer
Sometimes there will be grease streaks on the clothes after wash.
the main bearing and seals on the drum side are faulty. this should be under warrenty
Dec 29, 2009 | LG WM-2077C Front Load Washer
The washing machine leaked out transmission oil when it was tipped. Now it is sqeuking.
If it leaked oil or grease out for any reason, this is a serious problem and it's time for this machine to be replaced. It has grease in the transmission that is sealed with no way to leak unless it is worn out. If it leaked then this grease will get inside the drum and your clothing will be contaminated.
Oct 09, 2009 | Washing Machines
Grease on my freshly washed cloths
This sounds like a seal problem in the base of the agitator. This seal is what keeps the water inside the machine and the grease out of the wash basin. It is not something that should be attempted to repair if you are not mechanically inclined.
To get the grease out of your clothes, use an engine de-greaser which can be bought from any automotive parts store. You just spray the de-greaser on the area where the grease is located and rub it in by hand. You will need to use lots of soap to remove the de-greaser from your clothes, and might have to wash the item twice, to get rid of the de-greaser smell from the clothes.
Note, the de-greaser will break down all oil stains and grease stains, and is an oil by-product. This has worked for me on many occasions, but I have only used it on denim jeans and cotton shirts, with excellent results.
Aug 14, 2009 | Fisher Washing Machines
Grease Leak
Unfortunately not. In addition to replqacing the blet, the transmission must be replaced. It is the only item in your washing machine that contains gear oil. It's a tough job for the do-it-yourselfer...If I can help further, I am here.
Eric Campion
Mar 03, 2009 | GE WBSE2090A Top Load Washer
Brown marks on white clothes
Hi yoginiji,
The black mould might have something to do with the marks - I think it builds up if you only ever use low-temperature programmes. I believe that running the machine on a hot wash cycle - perhaps with some proprietory cleaner (but with no clothes in it) might help to get rid of it. I would suggest first removing as much as possible by hand.
Another, more serious possibility is that the drum bearing seals are leaking grease into the wash tub. If nothing is done the bearings will fail and result in a nasty repair bill. If your machine is under warranty, now is the time to contact the repair people.
Does this help? If not please give any more details you have and I'll try to think of something else :-)
Jun 29, 2008 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
