Question about Hotpoint  14.9 Cu. Ft. Top-Freezer Refrigerator
Water leaks from the bottom frequently. I thought it did not have a pan.
  • 448 Answers
I would think that the only sources of water would be heavy condensation draining (which would go into the pan, if you had one) OR a possible leak in the inlet line, IF you have an ice cube maker. I would check the inlet line which probably connects to your refrig at the bottom to a magnetic valve (which sometimes leaks and can be replaced pretty inexpensively) and also the line (usually clear plastic) that runs from the valve up to the back of the freezer. It can also crack and/or leak.
Sometimes, if the refrig is too close to whatever is behind it, that will cause heavier condensation. Sorry I can't tell more from your description of the problem.
Posted on Oct 05, 2009
Found water in the pan under bottom of my 60 gal Rheem Marathon model CMR 75245 electric hotter tank. There is no other source of water goes in the pan. Tank is only 4 yrs old. Is the tank leaking?
Is it sitting in the pan or is it elevated over the pan? It is hard to see the leaking if it is sitting flat in the pan. Check all the connections, top and bottom. Wipe them dry and then run your hand over the connections and feel for water. Also check under the heating element covers for leaks. Good luck!
Dec 07, 2016 | Rheem Water Heaters
Frigidaire dishwasher fault code i30
Good Afternoon Friend,
I understand that you are receiving an i30 error code on your Frigidaire dishwasher. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and start your dishwasher. If this does not correct the i30 error code, I suggest you contact your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire Dishwashers
I have a 2001 oldsmobile alero 2.4l twin cam the car is leaking water.the water is leaking from the bottom its comming from behind the transmission pan i thought it was a hose comming off the thermostat...
Rather then playing the guessing game an replacing part's that doesn't fix the problem , do yourself a favor an take it to a qualified repair shop.
Dec 03, 2017 | Cars & Trucks
IDW450 dishwasher starts working then after about 7 minutes stops - beeps about 6 times and stops completely - the dishes are wet but the dish washer tablet door is not open . - can anyone help - then on...
There is probably a leak under the tub., Water drips into a catch pan and sets off the beeping. Take the kick panel off the bottom front and see if there is any water in the pan. If there is you can drain it or blot it. BUT this is an indication of a bigger problem. You might want to run it after you dry the pan and see if you can spot dripping water when using a flashlight.
Jun 06, 2013 | Dishwashers
Portable haier air conditioner drainage. Cannot find drain hole and unable to tilt ac. Water is building up in the bottom of unit.
Here is a thought, received by me from a AC mechanic recently. Window ACs no longer actually drain concensate. Rather, the water is caught in a pan with the idea it will evaporate back into the outside air. The reason for this is the dripping water frequently resulted in the growth of algae below the unit resulting is unsightly stains and sometimes, slippery conditions. Evidently, there were a lot of complaints about being 'dripped on' also. So, AC manufacturers don't put drain holes in the bottom any more. If the pan over fills, it will spill out of many makes. If you want yours to drain, put a hole in the bottom.
Like I said, just a thought.
Thanks for your question @ FixYa.com
Aug 08, 2011 | Haier hwr10xc6 Air Conditioner
Water leaking from bottom of fridge onto the floor. Not a lot, but thought that the water pan might need emptying - can't find the water pan.
on some models the pan is made on the bottom of the compressor. the heat from it evaporates the water. if its cool in your house it may not get hot enough to do that so this could be where it is coming from.
keep a eye on the temp for a week or two in the fridge part. make sure its not warming up inside. if it seems to be fine your ok.
Dec 31, 2010 | Hotpoint HSS25GFP Side by Side...
Leaking water from bottom of inside unit while it is running
It's common problem due to non maintenance. Service your unit frequently, at least once in 4 months.Clean drain pan too.
Dec 06, 2010 | LG LA141CE Split System Air Conditioner
I have a bottom freezer french door mode. The
remove both crisper pans and check the return are duct opennings. next check if there's a built up frost/ice on the rear wall of the frzr. is you frzr fan blowing air? if so, there's a small window inside the refrig's freshfood side back wall towards the cieling, make sure that's open.the cover should snap off. if window/damper is open, go ahead an pour hot water down the return air ducts behind the crisper pans. they look like grill slots in one or both coners
Jul 14, 2009 | Maytag MFI2568AE Side by Side French Door...
Magic Chef Side bye Side freezer started leaking
the drain line may be the problem. check to see if theres water in the bottom of the drain pan in the freezer compartment.
Mar 30, 2009 | Refrigerators
Water leaking from bottom of refriderator
dear ricurtsmith..
your fridge has a water trap pan underneath it to catch the water from the drain line when your fridge automatic defrost.
either the pan is not in place proper or the pan may not be underneath, period. or pan could be stopped up/need cleaning. or if pan is made of plastic, it could be cracked.
it is located at the bottom of fridge where you see something loos like a grilled vent. remove that bottom piece to get to the drain pan.(it just slides out!!) good luck & hope i was helpful.
brbharo....
Dec 05, 2007 | Kenmore 52642 / 52644 / 52649 Side by Side...
Hotpoint  14.9 Cu. Ft. Top-Freezer Refrigerator Logo
111 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
