Question about Maytag Dryers
Dryer does not stay lit
Glows orange and then ignites but doesn't stay lighted. Which part is the most likely to be the culprit ? ie: what should I replace first?
  • Maytag Master
  • 3,361 Answers
Gas valve coils. There are 2 on the top of the gas valve,about $20 for the set.
Remove the front panel and the drum to access the gas valve. Turn off the gas and unplug the dryer.
Pay attention to the coil orientation on the valve.
Posted on Oct 05, 2009
Why is gas furnace in igntion lockout due to recycles (8 blinks). likely causes?
Check the thermocouple (heat sensor) on the pilot light...it tells the control unit that there is a lit flame...otherwise, the control unit won't let the gas valve open...does the pilot light stay lit after you've held the button down 30 seconds?...
Jan 01, 2015 | Dryers
Igniter starts to glow for 3-5 sec while making noise every minute or so
Check the thermocouple it is going bad or already has and that is why the gas valve is not staying open.
Jul 08, 2017 | Whirlpool GGW9200L Gas Dryer
No heat checked all vents and gas lines. don't know whats next?
A gas dryer uses a electric igniter that glows orange to light the gas burner. If the igniter does not glow orange when the dryer is started..replace it.
Jan 12, 2011 | Kenmore 74602 Gas Dryer
Maytag Model # LDG510 - Dryer burner will not stay lit. Electric igniter glows but will not lite gas. Igniter cycles on and off.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 10, 2010 | Maytag Dryers
Maytag neptune dryer will not stay lit. It starts up, lights, stays lit for about 1 minute and then goes out
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Aug 09, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Have a Maytag gas dryer, model#:LDG7314AAE serial#:16068237QF, and the flame will not stay lit. It warms up ignites and then after 15 to 30 seconds it shuts off. It repeats the cycle but the flame stays...
Did you change the igniter, or glow coil as it is sometimes called? If it is orange in colour instead of white it needs to be replaced as it is not strong enough to ignite and stay lit. Hope this helps.
Nov 19, 2009 | Cars & Trucks
Sears kenmore gas dryer 417.92052101does not stay lit.
Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
Jul 11, 2009 | Dryers
Flame goes out in 15 seconds
check these: Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
May 17, 2009 | Dryers
My dryer is not heating up, what is the problem
If the igniter glows white hot then change the coil pack if it only glows yellow or orange then change the igniter (glo bar).
Dec 29, 2008 | Roper RGX4634KQ Gas Dryer
Pressure of flames in Cannon gas oven
HI thanks for your question. the part that's at fault, is the igniter. it glows but not hot enough to ignite all the gas. replace the igniter. thanks the appliance doc. please rate my answer. thanks.
Oct 09, 2008 | Ovens
Dryers Logo
79 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
