Question about Hitachi 60DX10B 60" Rear Projection Television
My son bumped into the tv, now the red color is all distorted. How can this be fixed?
  • 178 Answers
When your son bumped into the tv he probably aggravated a common fault with these televisions. The convergence ic's have a tendency to break loose and cause distortion on one of the crt's in your case it was the red crt.
Don't blame him he just exposed the problem that was learking. The repair can be an easy one if the tech just solders the bad connection this may fix the problem and the tech is done. But the tech may have to replace the stk392 ic's there are two of them. If he needs to do this he may need to do a re-convergence of the tv to remove the problem. The labor to re-converge the tv will be the bulk of your expense. This repair typically costs around 300 to repair. Any tv tech worth his salt can perform this repair it is a fairly common problem.
Posted on Oct 10, 2009
  • 403 Answers
Sorry this is the best I could do for you. It sounds like one of your CRT tubes could be damaged, not seated properly, or off alignment. It's hard to say with these projection TV's without being there. It's looks like your going to have to call a tech.
To locate an authorized
HITACHI service facility
in the continental U.S.A.
only.
DIAL TOLL FREE
7 days a week, 24 hours a day
800 HIITACHII
(1-800-448-2244)
Try calling them and see what they can do for you. Is the TV still under warranty. There is so much that can go wrong with these units I recommend getting an extended warranty. Let me know if I can help you out with anything else.
JimmyC
Posted on Oct 05, 2009
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
TV has RED and GREEN colors distorting the color output of the TV. Can not simply adjust color and hue. Red and Green still remains controlling and dominant. How do I fix this?
If it does this on all inputs then it is the tv itself. You can try different sources and cables to see if the problem is not the tv. If the problem is the tv I would suggest having the tv repaired. It looks like a nice unit so it would probably be worth fixing. I would find a reputable local shop to take it to.
May 25, 2015 | Sony Bravia KDL60EX720 60-inch 3D LED TV
Mitsubishi RPTV has a blue shadow/image alignment problem
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 23, 2010 | Mitsubishi WS-65809 65" Rear Projection...
The colors on my TV are shadowing each other in different colors. Such as blue and red.
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 07, 2010 | Televison & Video
The color on our Sony tv is now distorted. The
if this is an older tv and your state might have changed to digital programming then i would suggest trying to look at the back of the set and see if you have anything to fix this problem or you might want to CHECK AND SEE IF YOU HAVE VIDEO ON or CABLE on or TV on. Sometimes if you have Antenna switch to cable then your channels would be red and picture distorted. change the antenna to air for tv. or from tv to cable.
Feb 24, 2010 | Televison & Video
Vertical Distortion fix for Toshiba 32 inch TV
You have bad capacitors and possibly a vertical IC that is going bad. And check for bad grounds in and around the IC and caps!
Dec 10, 2009 | Televison & Video
Distorted colors on my mitsubishi wd-73727
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Apr 02, 2009 | Mitsubishi WD73727 73" HDTV
Green/Blue distorted Colors
Color issues are harder to solve without seeing the problem. It sound like the red amplifier on the crt board is bad. Is there any red in the picture at all? If not, that will be you problem
Nov 26, 2008 | Televison & Video
Color off
Lol some people would pay good money for a doubling tv. Me myself I can think of all those beautiful women and those extra features........... Sorry first thing is to call out a technician because it sounds like the de-gaussing mechanism of the tv has gone haywire or that there is a fault with the screen itself. Either way its not one that can be fixed without technical knowledge. Good luck.
Sep 23, 2008 | Hitachi 42HDS69 42 in. Plasma Television
TV colors distorted
make a degosing coil or try to look for a website how to make it in the phillipine we only make it coz we can't buy or its not available in the marker ok thanks that is the only solution you can do k
about akai tv may be it just coldsolder in crt socket try to solder it thanks inform me
Sep 10, 2008 | Televison & Video
Hitachi 60DX10B 60" Rear Projection Television Logo
149 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
