Question about Hampton Bay 24750 Huntington III Ceiling Fan
Hampton bay Mod. # 587-186
Where is the dip switch located?
Remote will not operate.
  •  Jack Jr
    Jack Jr May 05, 2012
    Every ceiling fan that has a remote (even if it's mounted in the wall) will have dip-switch settings on the transmitter. Most receivers (in the fan) have the same switches and they should be set the same. Newer systems still have the dip switches on the remote but not on the receiver in the fan. In these cases you must "burn in" the code to the ceiling fan to teach it the setting you have selected.
The dip switch is on the receiver box which is located inside the housing on the ceiling, inside the remote control, and inside the wall switch if you have a wall switch made to control the fan.  All must have the same dip switch settings.
Posted on Jan 07, 2008
Hampton Bay ceiling fan quit working. No lights, no fan operation at any setting. Replaced remote battery and checked dip switches for correct position. Wall switch is on and has power through it (c
IIt sounds like there is not power to it, so it could be a loose wire nut on the "hot" side of the circuit inside the fan junction box. That's going to be a pain to get to. If you have power there and the connection is faulty, that's the problem. If you have power there and the connections are good it should operate manually without the remote. If not, I would suspect the fan is DOA.
Nov 30, 2014 | Hampton Bay 24750 Huntington III Ceiling...
Hampton bay uc7078T remote with uc7083T receiver ?
read your instruction manual download from www. fitness.manualsonline.com or www. retrevo.com
God bless you
Jun 29, 2012 | Universal Remote Control Hampton Bay...
Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
Sep 10, 2011 | Televison & Video
Cannot set remote code for fan/light(dip switch)
The remote dip switch setting must match the fan receiver dip switches. Set them both to 2 on
Jul 04, 2009 | Hampton Bay 52 In. White Redington...
I bought a hampton bay ceiling fan model uc7083t but i didn't
hi there i can help. There is a "dip switch" on nearly all fan remote units, much like a garage door opener has. To keep all the fans in your home from operating at one time, each fan needs a seperate "code". To use your other remote, you need to locate the receiver unit in the fan, usually in the "canopy". This is the bowl looking piece against the ceiling. then note the "code" which is the position of the switches. For instance, most have a block with 4 switches, and if the first is "on", and the remaining are "off", that is it's set code. This "code" can be changed to any combination of "on , off" that you like. BUT, you must also open the remote control and set it's switch to the exact same "Code", or order of "on off" as your Fan receiver. (Usually the control "Dip switch" is in the battery compartment.
Jun 19, 2009 | Hampton Bay 24002 Ceiling Fan
Need code for remote to ceiling fan
There is no set code from the factory; usually all the dip switches are in the same direction. In order to find the code, you will have to take the fan down, pull the remote out far enough to observe the dip switches, and then set them the same way on the remote.
May 19, 2009 | Hampton Bay 13087 70450 Carousel II...
Hampton Bay Windward II dip switches
The CODE SWITCH RECEIVER should be located in the CANOPY (the bracket hanger). !!WARNING!! YOU ARE ENTERING A HIGH VOLTAGE ELECTRICAL ZONE!!
It will be tucked in among the electrical wiring and inside the hanger bracket.
Simply pull it out and you will see the CODE SWITCHES. There are 16 CODE combinations that can be used. Both the REMOTE and the RECEIVER MUST be set with the SAME CODE.
Good luck. :)
Apr 19, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Two ceiling fans, both remotes control the same fan
Most likely the dip switches on the remote receivers don't match (on the second fan, the one that doesn't work). While the remote dip swithes on both remotes match the working fan. You can simply reset the dip switches on the second fan receiver to match the one working remote, i.e. you don't need to have a second remote, one can work both fans as long as the codes (dip switches match). If you want you can make all the remotes the same, that way you have two remotes, or if you want them independent each remote and remote receiver must have unique codes (dip switch settings).
Nov 30, 2008 | Universal Remote Control Hampton Bay...
I need the default code for a hampton bay fan
I checked the hampton bay site and unfortunately whatever dip switch setting on the fan is, the remote needs to be matched to it. better get out the ladder!
Sep 11, 2007 | Hampton Bay 48670 Flemish Pewter Finish...
Hampton Bay 24750 Huntington III Ceiling Fan Logo
659 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
