Everything goes to my profile instead off the wall
    President:
  • 1,124 Answers
It is likely the way it is set in your setting - in "edit profile"..
If you cannot get the setting corrected yourself - contact customer support.. You will find the proper links for support located at the bottom right corner of the FaceBook home page..
Have a great day !
Posted on Oct 05, 2009
Why does my 94 chevy caprice knock when started then stops
it takes a while for the oil to get to the pistons threw the maze of oil distribution ducts. so when you start it. the pistons are almost dry. and you can hear the piston walls slapping the sides of the cylinder walls as the crank passes top dead center and the force of the piston's pressure switches from one side to the other
maybe it was run without oil once and wore out a little.. it might be close to the end. or it could go for another 200,000 miles depending on how worn out the pistons are.. thats why they make "high mileage" oil, it's thicker(higher viscosity higher sea number) so when the piston slaps the cylinder wall , it doesn't squirt the oil completely away and provides more lubrication.
an analogy might be to look at a worn piston as that the older and more worn out it is, it's profile changes from square shape to triangle shape(more like trapezoid shape). but upside down triangle instead of a square profile
Jul 23, 2017 | Cars & Trucks
How do I remove a Post on my wall?
Go to the top right of the post. In the corner, a small x will show up. You may have to hover your mouse around to find it.
When you click on it, a menu pops up giving you options regarding what to do with the post. You can remove it, hide it or report it if need be.
var geo_Partner = '1890d1e7-e721-4f9c-b474-1a19eda23e94'; var geo_isCG = true;
Aug 21, 2011 | Facebook Social Network
When my refrigerator goes into defrost mode (twice a day?) it melts everything in the freezer. My ice bin is just one huge block of ice now. There is no ice on the back wall either. I replaced the defrost...
It sounds like a bad defrost timer. See if you can find another unit and see if it defrosts the same as yours or contact the manufacturer to find out.
Good Luck,
Gilshultz
Nov 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I replace the glowbar on GE stove. However,
no. DOWN LOWD THE WIRING DIAGRAM FOR YOUR MODEL NUMBER BEFOR MOVING ON.
Nov 13, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
My pic's or comment's do not show up on the home page newsfeed
Ive noticed not everything show's up on facebook,mostly its the comments you write and pictures you put up they show up on other people's home page instead of yours.
And the ''what you doing right now'' shows up all the time on the profile page and the ''home'' page.
hope this helps..
Feb 03, 2009 | Facebook Social Network
Refridgerator top freezer exterior wall hot
Hi.........
Folow these steps. It's worth a try.
1.Pull the fridge out from the wall and unplug it.
2. Clean the dust and lint off the compresser and everything else.
3. Also clean under the fridge.
4. The frame around the freezer door should cool down.
If the cooling fan was stuck , that may also be a cause for your refrigerator wall becoming hot.Check that too.
Hope My info is useful....Bye
Sep 19, 2008 | GE Profile PSW26P Stainless Steel Side by...
Computers & Internet Logo
David Payne
David Payne
