Had the same problem after a severely unbalanced load caused the washer to basically stop in the spin cycle. After rebalancing the load and finishing the wash, we found a strange little red plastic clip in the clothes and wondered where it came from. Then by chance we spotted the end of a spring attached to the top of the inside of the drum where it had not been visible before. We took the plastic lid off, popped off the two covers for the screws holding the top of the washer, removed the two screws, and lifted the top up at the front. There we found the one spring on the left front side had come undone. The red plastic clip fit into the top of the drum in a little slot that was obvious, and the spring attached to the clip. That was all there was to it. Repair and reassembly done in under five minutes. There is only one spring on the newer washers. Ours is only a few months old and I am not sure about the model number, but all the new ones look to be made the same.
Hi, I have a 601 model its about 14 yrs old, love it but now My hot and cold water are both...
(More)
Hi, I have a 601 model its about 14 yrs old, love it but now My hot and cold water are both trickling into the machine. The hot about 6 months ago and now the cold *** well. Someone suggested getting the soleniods replaced. The hot is cheaper than the cold one, so I was advised to use hot soleniods to replace both hot and cold what do you think? will it still work OK? ... Im desperately trying to save on money.
I have a fisher and paykel 601 smartdrive, it will not start, no lights come on, have spare parts...
(More)
I have a fisher and paykel 601 smartdrive, it will not start, no lights come on, have spare parts and changed board and switch panel but still it wont go . Is there some hidden switch. I have tried holding the lid switch closed but to no avail
hi,i have 5.5 smartdrive 9 excellence washing machine,it was alright,until i was about to start the...
(More)
hi,i have 5.5 smartdrive 9 excellence washing machine,it was alright,until i was about to start the second load,then the water supply is not filling up properly,long fill,then short fill a couple times then it stops and beep sounds with some lights comes on.the lights is the 3rd,5th,7th,and 8th on the wash progress panel.I have swapped over the solenoid for cold and hot,as i thought it was the solenoid,because i am never used the hot one.but the problem not solve yet.can anyone help me please,thank you!
F & P Smartdrive 708 has all lights showing when powering on, but will not start wash cycle....
(More)
F & P Smartdrive 708 has all lights showing when powering on, but will not start wash cycle. Have tried turning off at wall to re-set; taken lid off but still no go
