Question about Dryers
Model mde3000aya, runs but no heat. was wondering about tests to perform to figure out exact problem.
  • 82 Answers
You need chek:
1-thermalfuse
2-heater element.
3-hi-limit sw.
4- temp sw.
5-electronic control.
6-cycling th'st.
Posted on Oct 06, 2009
Kenmore Elite model 11863032101, dryer runs but no heat
could be the thermocouple or the heating element failed . only the proper testing will determine exactly what has failed
Jul 16, 2016 | Kenmore Dryers
Heat pump with High head pressure
HFC-134a ? Critical pressure is 588.9 a . With a 93 LL temp and 575 head, I would suspect 1. Air in system or 2. Ref. has gone critical.
With a 110 psig suction/85 deg.F and a LL temp of 93 deg.F/125 psig
Jan 13, 2013 | Ruud Heating & Cooling
My frigidaire model is GLTF2940FE0 front loader will not start
I was wondering did u ever figure this out i have same code ...but mine will run a little water then drain and never spins but got the code E5E too
Dec 15, 2012 | Frigidaire Washing Machines
Electric oven not heating
Hello would you happen to have the make and model number of your electric oven? There are many differences in many different units and I always try to be exact on my solutions to the customers specific appliance instead of just giving a general solution. Check the oven tempreture sensor and perform a ohms test on the sensor at room tempreture the sensor should read between 1000-1100 ohms. If it were less then this then you would replace the sensor. You can also perform a continuity test on your element as well which would assure that there are no break spots in the element. I await your reply
Thank you
Rick
Oct 27, 2011 | Ovens
Dryer runs but no heat.
If your dryer is running but you have no heat being produced from the unit this could be caused by several reasons. In your unit there are are thermistors which allow the unit to run and act as safety devices so that the unit does not overheat and cause a fire or overheat causeing extensive damage to the unit. Your unit also has a hi limit and a low limit thermistor in it as well which tell the unit to shut the heater off due to it being to hot or turn the heater on due to it not being hot enough. In order to test these thermistors you would perform a continuity test on them using a multimeter and any that were to fail you would replace. You can also perform this same continuity test on the heater as well to assure the heater is functioning properly as well. If you are able to produce your model number I most likely will be able to find your schematic to your unit showing you where the thermistors are that you would test in the unit. Also if you have any other questions message me those back as well.I await your reply Thanks Rick
Jul 10, 2011 | Dryers
Can i get manual for maytag neptune elec dryer model number mde3000aya
You can obtain a FREE copy of the user's manual at managemylife.com. Type in the model number "MDE3000" under their "Manuals" link and you will find a manual available in .pdf format. Here is a direct link:
http://www.managemylife.com/mmh/owner_manuals/11455/MAYTAG-Residential-Dryer-L0807349?brand_name_search=mde3000
I hope this helps you.
May 05, 2011 | Maytag Dryers
Maytag dryer Model MDE3000AYA intermittently won't start. Interior light does illuminate when door is open. Normally when the timer knob is set a soft audible ticking sound is heard. When the dryer...
could have a bad timer,when it stalls try tapping on the timer or wiggling the knob to see if it will start,there's a little motor on the timer that you hear ticking and it could fail.
Jul 10, 2017 | Maytag Dryers
I have a Kenmore refrigerator model number 25358685894. The defrost does not working. I have changed the heating element once about a year ago and thought it might be the same issue again. I notice when...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 04, 2010 | Kenmore Refrigerators
Kenmore microwave model 665.68681891 runs but won't heat
Test the high voltage capacitor, the rectifier diode.or the magnetron. If all this are fine, test the control board.
If it additionally does not spin and no light, then check also the door switch and fuse.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Oct 25, 2008 | Kenmore 62622 Microwave Oven
Dryers Logo
51 people viewed this question
Top Dryers Experts
