Question about Motorola Mobility S9 Headphones
S9-HD headset wont turn on
After only a couple days of use, my S9-HD headset wont turn on anymore. when i plug them in to charge, i get two blinks of the indicator light (color varies, haven't figured out why) and then nothing. when i unplug the charger, it blinks once red. anybody got any info?
4 Suggested Answers
  • 5 Answers
SOURCE: S9 headset
i don't know if this will work of you guys..but mine did...I tried 4 different chargers and everything didn't work..even plugging into the computer didn't work...So i smack the battery part like how you smack a tv remote to work..and i saw light flash..So i plug it back in and it works....this charge problem happen to me 2 times and i did the same trick...i hope this works for you guys...
Posted on Mar 03, 2009
SOURCE: Motorola S9 headset won't charge batteries
This might work if you aren't using the ORIGINAL charger. I had this problem when my cat chewed through the original Motorola charger. I figured my Blackberry charger would work fine, but it didn't. I then discovered that my Blackberry charger was 700mAH and the broken charger was only 550mAH. When I found another charger with the proper power it charged. I also found that it worked when plugging it into my computer with a standard mini USB. I hope this helps.
Posted on Jun 06, 2009
vqcb43
  • 1623 Answers
Mobile Phones and Acessories
    Verified Fixya Pro
    SOURCE: My headset doesnt turn on, when I plug the charger the red light starts blinking
    Could be a combo of low battery and not yet being connected. Charge it overnight and check on it in the morning.
    Check out the
    Quickstart Guide
    Mark
    Motorola Support
    Posted on Dec 31, 2014
    Testimonial: "It´s been plugged since last night and still nothing"
    Wont turn on
    2 days old and defective return for refund or replacement
    Jul 12, 2017 | Motorola Mobility S9 Headphones
    Motorola s9 headset wont turn on
    Mine is doing the exact same thing. Does anyone know what the problem is? If so, what is the fix.
    Apr 27, 2012 | Motorola Mobility MOTOROKR S9 Wireless...
    Why does my Motorola S9-HD bluetooth only plays from left side when listening to my iphone 4g?
    I just had the same issue. I charge my headset every day so I came to the conclusion that the short was due to a small piece of metal shorting out a connector in the chargeing port of the headset. I fixed it by first opening the charging cover and holding the headset by the ears in one hand. I then lightly tapped the opening against my other hand to loosen the metal shard. After doing this a few times, the sound came back. I then used a can of compressed air to finally flush out the intrusive shard. I didn't see how large it was but now my S9-HD headphones work! I'll check the connections on my 2 chargers to see if they have any evidence of breakage because I did notice when I plug in the set, I have to jiggle the connector a little recently.
    Sep 30, 2011 | Motorola Mobility S9 Headphones
    How do I put the motorola s9 hd wireless headset in pairing mode for a iPhone 3G ?
    Starting with your headset turned off, press and hold the power button for some 6 seconds, until the indicator light flashes alternately in blue and red. It is in pairing mode now. Then, make your phone's bluetooth application search for new devices. After a while the S9 should appear on-screen. Make it connect. If a paring code (or PIN, or passkey) is requested, enter '0000' (four zeros). The indicator light will flash some times and enter stand-by mode.
    Hope it works for you.
    Regards, Carlos
    Sep 01, 2010 | Motorola Mobility MOTOROKR S9 Wireless...
    On my motorokr s9 the green light just stay on even when I don't charge it is there a reset button or anything?
    This is caused by a power surge. To correct, plug your headset into charge, and then plug into power strip. Trip the switch on the power strip to off. It will cause a drain and turn off your green light and then allow the headset to turn back on.
    May 06, 2010 | Motorola Mobility MOTOROKR S9 Wireless...
    They Won't Charge!
    Try to press the power boton in the same time you plug the charger, after this action mine is working and charging perfectly, maybe this is the "reset" solution... Hope this helps you.
    Nov 17, 2009 | Motorola Mobility S9 Headphones
    How do I reset s9....the green light stays on constantly and I cannot connect at all.
    If you guys haven't found a solution, you might want to try this out. Have your S9 charger hooked up to the unit and plug the charger into a surge protector. Flick the main switch of the surge protector on and off a few times and it should turn off the unit. Then turn on and pair if need to and it should be fine. Hope that works for ya!
    Cpl. Ramos
    Jun 24, 2009 | Motorola Mobility S9 Headphones
    Cannot get S9 to connect to phone or computer
    From Falvey86: Hold the headset start button for about 10 to 20 seconds, the lights will start flashing red and blue, then the search for Bluetooth devices from phone and it will appear as: S9. press "connect", a window will appear, place the password "0000", that should do the trick!!!!
    Feb 27, 2009 | Motorola Mobility S9 Headphones
    Motorola Mobility S9 Headphones Logo
    394 people viewed this question
    Top Motorola Mobility Audio Players & Recorders Experts
    Motorola Mobility
    Motorola Mobility
    Vladimir Frolov
    xiangnia
    xiangnia
    Are you a Motorola Mobility Audio Player and Recorder Expert? Answer questions, earn points and help others
