Question about Grindmaster Coffee Makers & Espresso Machines
I am looking for a plastic front cover for a cory coffee grinder model ccg3 and also gasket bowl seal for a jet spray beverage machine ae160-ai-144 also commercial if these are available i would like to know the cost of each thank you for any help you can give
SOURCE: How to remove spray paint from iron?
Try using WD-40 - no kidding! It works wonders for removing spray paint depending on the type and how long it's been on.
Posted on Apr 18, 2008
  • 26 Answers
SOURCE: Parts and Grind Selection
The current Kitchenaid A9 burr grinder glass jar is interchangable with the original Hobart/Kitchenaid A9 glass jar; therefor, the gasket should also interchange - contact Kitchenaid customer service to order a gasket.
Setting the grind is accomplished by grasping the body of the ginder in one hand and the grind-selector ring (collar that the jar screws into) in the other. Hold the base tight and turn the selector ring clockwise for a finer grind, counterclockwise for coarser. Be careful not to completely unscrew the selector ring; if you are not sure how much adjustment is left, screw it all the way clockwise until it stops (finest grind); then, back it off, up to one full turn to make the grind coarser.
The selector ring has the words coarse, medium and fine cast into it; these are rough postition markers. There is a triangle cast into the body of the grinder, just above the brand name, that can be used to diral in a preferred level of grind. I use a medium-coarse grind for drip coffee makers; to do likewise, position the selector ring so that the triangle is pointing midway between the words coarse and medium.
Posted on Jan 18, 2009
SOURCE: I'm looking for the user manual for an Estro Model
I have a copy which I'm getting ready to sell with the Grinder.
Posted on Sep 16, 2009
SOURCE: My Breville BCG450 coffee grinder won't turn on
I sometimes forget there's an on/off switch on the back of the thing, since I mainly use the button on the side.
Posted on Feb 04, 2010
SOURCE: KitchenAid coffee grinder
Apparently we must be the only two people on the planet with this problem. I have a Breville burr grinder that I received as a gift, and it magnetized the grounds directly out of the box. I am considering opening the casing up and grounding the motor through the plug. I would need to replace the 2-prong plug with a 3-prong plug. The casing is made of plastic and stainless steel, so they wouldn't need to ground the chassis, but if the electric current running through the motor or the burrs (attached to the motor) are the root cause then I would think that grounding the metal chassis of the motor through the plug/outlet should do the trick.
Posted on Mar 14, 2010
EA6935 krups powdered coffee inside grinder and coffee grounds noncompact
You will need to pull the grinder apart & clean it out. Most likely cause of the grinder blocking up is a leak somewhere inside the machine dampening the grounds as they exit the grinder. They bind up, won't fall out and there is your blockage. You will need to find and fix the leak, there are many, many places for the leak to be, it's a job for a Krups Service Agent. I have outer housings with cutouts in them so I can run them and look inside at the same time to find those troublesome leaks.
Feb 28, 2014 | Krups Coffee Makers & Espresso Machines
My machine says " fix
It says fit jets in central spout, not fix. The stainless steel cover over where the coffee comes out sits on top of the central jets. pull the dispenser down as far as it will go. Now pull it straight out to you. reach up and grab the black plastic piece that holds the central jets. pull it straight down. Now fit the central jet housing into the stainless steel cover. put the cover back on and push it firmly up into place. if it still says fit central jets, pull the stainless steel cover down and slam it up a little harder. there is a switch up inside that needs to feel the presence of the central jets so it doesnt spray coffee and milk everywhere. You should be cleaning those jets every 24 hours anyway. Get the manual out and go through the maintenance proceedures. that milk will start to turn into green cheese if you dont clean the jets and pipework every night.
Jul 14, 2011 | Miele Coffee System
KRUPS xp7225 LEAKS FROM THE FRONT
For mine, the solution, which also applies to other similar Krups machines, was to replace the seal at the bottom of the boiler. (#MS-5015004). This seal was torn. While in there, I also replaced the piston (#MS-0697072), which seemed like a good idea, since its O-rings seal the top of the chamber. I got my parts from Nelson Appliance.
To replace the seal (from memory, so there might be some details missing or incorrect):
1. Remove drip tray, coffee drawer, water tank, and side bin
2. Remove top metal cover and one screw underneath that holds down the plastic insert
3. Remove the one screw that holds the cover inside the bean hopper and carefully pop off the grinder adjustment knob. The hopper should now come off.
4. Slide the front plate (gray/silver plastic) up until it pops off. Remove the four screws underneath it.
5. Remove the screws from the top of the unit (two at front, one in a recessed hole in the back).
6. Remove the two screws under the water tank.
7. Pry/pop the top off, and pry the side/back cover off.
8. Unplug the grinder from the circuit board, remove the two screws that hold it in place, and remove the grinder.
9. Remove the coffee line from the piston. Remove its clip and then remove the two screws underneath it.
10. At this point, you will need to disconnect most of the other wires from the circuit board or the components they go to, and you will need to unbolt the piston carrier, so that you can remove the frame that holds the grinder.
11. Remove the three screws that hold the boiler to the base.
12. Holding the shaft from underneath, remove the screw that holds the screen in the middle of the plunger in the boiler.
13. The plunger and shaft can now be removed.
14. The seal goes in the hole at the bottom of the boiler that the shaft runs through. I used a toothbrush handle to push the new one into place from the bottom. Make sure the lip of the new one is fully seated in the opening (look at it from the top of the boiler and work it into place while apply pressure from below). Once it's properly seated, there should be noticeable drag on the plunger shaft when it is moved inside the seal.
15. Reassembly is the reverse of removal.
Jan 05, 2011 | Krups XP7225 Espresso Machine
Cannot remover the coffee grinder from machine.
Remove Coffee Maker's top cover. Slide coffee bean container off (after emptying it of coffee beans). Remove fixing screws (normally philips) securing the bean container platform. Remove grinder's bean intake rubber seal. Unscrew the grinder's fine/course selector, paying close attention to where it was originally fixed, from factory. 4 rubber bushing are anchoring the grinder in place, which can be seen from the front of the Coffee Maker (w/ door opened). Wiggle each rubber bushing through, as you pull grinder from the top. Grinder should come loose, after unplugging wires. - Good Luck
Nov 13, 2010 | Miele Coffee System
How do i reset my gaggia titanium, the gears are in the wrong position
Are you talking about the coffee brewing system? Or the coffee grinding system? You said "gears" so it sounds like you took the coffee bean hopper out and the adjustment knobs come out with it. So if you are trying to line those gear teeth back up correctly, Here is the complete instructions for cleaning the grinder (from wholelattelove.com). You only need the last few steps for lining up the gears.
You do not need to clean the grinder as often as you may think. Usually we do not recommend cleaning the grinder unless there is a problem with calibration or a clog. Avoiding oily beans, flavored beans, and beans stored in the fridge or freezer will typically prevent issues.
If you do experience issues with your grinder, cleaning it is the most common solution. To clean your grinder, follow these directions:
1. Remove the water reservoir, turn off and unplug the machine.
2. Take the cover off of the bean hopper and vacuum out the beans.
3. Remove the 3 Phillips head screws that are in the bean hopper.
4. Lift up the bean hopper and set it aside.
5. Open the machine's service door and remove the drip tray and the brew group.
6. Remove the rubber gasket from the top of the grinder area.
7. The grinder is made up of 2 pieces. The inner piece has 4 tabs that the rubber gasket sits on. The outer piece has teeth in a ring on the exterior covering ½ the circumference.
8. Rotate the outer ring 180 degrees counterclockwise. You should be able to lift off the inner ring. There is a red spot on the outer collar which should now be facing the 9 0'clock position when you are at the front of the machine.
9. Vacuum out all of the beans and ground coffee.
10. If possible, use a small pipe cleaner to get grounds out of the "pathway" going to the front of the machine. It is located on the floor of the grinder at about the 5 0'clock position.
11. Above where the brew group would be located, there is a gray triangular tab attached to a door on a hinge. Pull down on the triangle - coffee grounds may come out.
12. Look above the trap door and you will see the other end of the chute. Vacuum out the chute and clean with a pipe cleaner.
Reinstalling
1. Drop the inner burr onto the grinder with the tab that has the red and blue marks facing the right hand side of the machine at approximately the three-o'clock position.
2. Rotate the outer collar so that the red mark lines up the red/blue marks on the inner burr.
3. Reinstall the rubber gasket that goes over the grinder. The slots in the gasket line up with the four tabs of the outer burr.
4. There is a straight piece located directly to the right of the grinder. This is your dosage control. There is a piece that can slide backwards and forwards on this dosage arm. Push this arm all the way to the back of the machine.
5. Set the knobs in the bean hopper to #0 on the grind setting knob. Set the doser knob all the way to the plus setting. Now place the hopper back into the machine.
Note: You may have to rotate one or both of the knobs, a small amount, to get the bean hopper to set down on its supports.
6. Install the 3 screws.
7. Replace the water reservoir.
8. Fill the bean hopper with a cup of beans.
9. Plug in and turn on the machine.
10. Reinstall the brew group and the drip tray.
11. Once the machine warms up, press the small coffee button. When the grinder comes on set the grind setting to 6.
Note: You may have to press the small coffee button twice or 3 times before the machine will make a cup of espresso.
Sep 24, 2010 | Gaggia Titanium Espresso Machine
The plastic shield in the coffee container on my saeco incanto de luxe broke yesterday and fell directly onto the beans, but I was still able to make my coffee this morning, but this afternoon, the...
Vac out the bean chamber, then remove the 2 or 3 screws and carefully lift the bean hopper off the machine, then continue cleaning the grinder, careful not to lose the gasket around the top of the grinder. When done reassemble and try to brew but do not add beans to hopper as yet. Until you are sure all the plastic pieces are out.
Sep 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
Continue to get beeping after taking out basket, emptying water, re-inserting basket and making certain lid is clicked shut. Thoughts?
All the parts have to be in place, including both the removable grinder unit and its clear cover, even if you're using pre-ground coffee.
It also requires that both the top lid and the front "door" (to the basket area) are clicked shut, and that the basket and its cover are both in place.
One thing to check carefully is the clear cover to the grinder unit. There's a rubber-like "nub" that seems to actually control the switch, which tells the machine that the grinder unit is properly installed. If that rubber-like nub is missing (and unfortunately it IS possible to remove it, particularly during cleaning) ... that could be causing your problem. If you see a hole in the top of that clear cover... you're missing that "nub".
Sep 14, 2010 | Cuisinart DGB-600 Coffee Maker
Hi. I have a Krups XP7245 combination espresso/coffee maker that leaks when I make coffee. This is a recent problem. It's out of warranty (of course), and I'd like to disassemble it to try to resolve...
I had the same problem with the XP7240. The rubber seal in the plunger that pushes out the coffee cake after brewing is worn or dirty. You need to romve the cover by taking of the top (screws in the bean collector and cover tray for cleaning tablet). You have to be rough because parts are clicked together. The face of the machine comes off by pulling it upwards (it is just clamped with plastic nudges). Once that is done you remove the 4 screws that were hidden by the stainless steel face. Then remove the electronic board (leave connections on except for bean grinder and boiler). Grinder can then be removed followed by the cream cover. Remove the 15mm steel nut on top of the arm. Remove the front and display. Then use a torix on top of the brew plate and an allan key on the bottom of the plunger. Unscrew, remove spring and seal (very small cup). Let me know if you need more instructions (take a rainy sunday afternoon to do this)
Aug 13, 2010 | Krups Small Appliances Espresso Machine
Full of Beans
You have to mount a resistance on the power card.
/Mirran
Aug 24, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Coffee Makers & Espresso Machines Logo
70 people viewed this question
Top Grindmaster Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Grindmaster Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
