Question about Samsung 226BW Monitor
Samsung syncmaster 245b plus
I have a samsung syncmater 245b plus but sometimes it works and sometimes it dos not work at all.
i saw some people have the same problem with there monitor and it's all samsung.
my monitor has been at samsung but they did not find any problems and back home the same problem again.
hope someone can help..
thanks..
  • GFBusiness
    GFBusiness May 11, 2010
    Can you provide more info on the problem? When it works it does so after warming up, or fails while it's working? Still under warranty? You willing to open up unit?
  • 34 Answers
Oct 23, 2009- This is how it went for me..I have a Samsung SYNCMASTERsamsung syncmaster 245b plus - 2.gif 2053BW. I leave my monitor on and let it hybernate when I shut down PC. I'm 3 months outside of my warranty. Two weeks ago something started happening. I boot PC and video doesn't come up for 10 minutes, and when it came up it worked perfect. VC/Monitor/MB?? It became 20 minutes and ...now..I have the analog/digital box in top left screen, power light on monitor flashing, no menu available on monitor and none of the other buttons work for anything. I test the monitor on Laptop..nothing(same as above)..I break out the old(working) monitor from deep within the closet. Plug it in and I'm up and running. So...
HOW TO OPEN A SYNCMASTER 2053BW
NO SCREWS!!! Assuming that the stand mount has been pulled out..The seam around the screen frame is where you start. The frame has the prongs, the back cover has what the prongs slip over.The frame is coming off first! I got the side to open by finger, then used a small standard screwdriver to pry ever so gently(lifting frame from rearcover). Leave the power button assembly on the frame, pull wire only a little to relax any tension..you get about 3/4" in extra taped to panel. The hard part is done.;) Still holding the frame...Now lift the panel (where the power button assembly wiring goes under panel) with the power housing that is under it as a whole and you will see where the powerbuttonassemble detaches.Remove frame. Now..holding edges of panel into back cover, lift and flip the whole thing over and place panel face down on a perfectly flat surface..a towel on my desk works. Lift and remove back cover.Your now looking at the back of the board housing. The ribon is simple, on the panel end of the ribon, squeez the outer clips together and slide it away against the panel..The secondary tin plate is removable, two clips super close to where the sets of wires come around the housing and into the panel.Unhook the 4 plugs(pink inside/blue outside)...Now lift the power housing off of the panel. The big board has the power. One screw to remove a ground plate first. Two screws to remove power board. Pics from phone.56ec44b.jpg
samsung syncmaster 245b plus - aae8fab.jpgttp://i.fixya.net/uploads/images/aae8fab.jpg" alt="aae8fab.jpg" class="h_mi" />
Reassemble but DO NOT re-snap the frame into place....yet... Test it! There is a reason the caps got hot in the first place, therfore it has a good chance of happening again. This is not fullproof...but.....mine has been on now for close to 6 hours with no glitches whatsoever. So I have resnapped mine back together. I hope you can too. Oct 23, 2009- I must also add that this is one of the best producing monitors I have ever seen...in 60hz. The clarity is top notch. If you purchase one get the extended warranty. FYI...I paid $4.00 for those caps.
Posted on Oct 24, 2009
Have a Samsung SyncMaster 2232bw monitor that the power button flash is there a reset button on this monitor
I have another model of Samsung Syncmater monitors.
According to the manual, press the Source button then a key on the keyboard.
http://downloadcenter.samsung.com/content/UM/200707/20070721174815531_BN59-00585T-01Eng.pdf
According to http://www.tomshardware.com/forum/267699-33-samsung-syncmaster-906bw-display try pressing Source and Power or Power and Auto button at the same time.
Per Tomshardware.com, if these things don't work then the monitor needs an electronic repair(detailed in forum) or, if you are unable to get it fixed, replacement.
Please check http://www.fixya.com/support/t255653-syncmaster_paower_button_blinking_no for additional information.
Mar 24, 2016 | Samsung Computers & Internet
Samsung syncmaster 245b lights up and then turns black...
more than likely your video card has gone bad .. try to get a new video card and install it or take computer to your computer shop and have them replace it for you
May 17, 2017 | Samsung SyncMaster 245BW Monitor
Hello, I've got a S. Syncmaster 245b, but the powerbutton light is on, but the screen stays dark black. Not even the note of it searching for digital or analog signals. What would be the most...
The power supply is not feeding the 24vdc to the inverter board, or bad backlights inverter board, those are the two boards you need to check.
Examples of failed SAMSUNG:
http://s807.photobucket.com/albums/yy352/budm/SAMSUNG/
Also read my guides:
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 23, 2011 | Samsung SyncMaster 245BW Monitor
I have the same problem with my samsung lcd, how much does it cost buying an invertor and is it difficult to replace it?
Replacing parts of SyncMater 740N 17" is not difficult. Acctually you wanted parts is IP board the inverter is included to this assembly. If you want to buy this, get the code no. ex. BN44-00130A
Oct 02, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Hi, I'm alan . when I try to connect on my macbook using syncmate by wifi connection,syncmate software ask for the IP address or hostname of my device,I ave no idea where to find those info on the omnia...
Hi, once you launch SyncMate driver on your mobile device you will see this information. You will find all details in this article http://wiki.eltima.com/user-guides/syncmate-macos/synchronization-with-devices.html
Sep 25, 2010 | Samsung SGH-i900 Omnia Unlocked Cellular...
Syncmaster 245b - no backlight
First, the caps can look OK but they can have high ESR (http://s807.photobucket.com/albums/yy352/budm/Bad%20capacitors/)
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Service manual:
http://elektrotanya.com/?q=showresult&megnev=SAMSUNG megnev2 =% 20 & 245B & Category = & kat2 = all
Jun 06, 2010 | Samsung 226BW Monitor
Samsung 245B Cracked screen
Hi...there,
Don't bother replaced with a new screen panel. B'cuz it will cost you lots more... Better buy a new one for Xmas, It saved you the $$$....
Dec 15, 2008 | Samsung SyncMaster 245BW Monitor
Samsung 245B
Call Samsung. The unit sounds faulty.
Dec 14, 2007 | Samsung SyncMaster 245BW Monitor
Open Questions:
See all Samsung 226BW Monitor Questions
Samsung 226BW Monitor Logo
2,617 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
