Question about Yamaha RX-V795 Receiver
Won't stay powered on
My Yamaha rx-v795a will not stay powered on. It immediately powers down after powering up. You see the screen flash on and then nothing. Any suggestions?
  • 1 more comment
  • Spotter12 Dec 29, 2007
    I have the same exact problem. Now it won't power up any more. I was told it was probably a bad power supply, but it hardly seems worth it to fix. If you find a fix let me know. alex@pathfinders.com
  • Anonymous Feb 19, 2009
    Did anyone come up with a solution for a RX-V750a suddenly shutting off? It appears that this model is no longer on the Yamaha list of products, but it is encouraging to see that other people have the same model I do with the same problem. But I don't see a solution. ????
  • mlmtko Jun 25, 2016
    25/06/2016 SOLVED - SOLVED - SOLVED!!!!!!!!! In the first approach I found some damaged components in the MAIN BOARD: They were Q527A (2sa1492) + Q526A (2SA1358) + Q516 (2SC2240) + R585 (330ohms) + R631 (0.22ohms x 3W) and the MAIN relay of the power sub-board. Now finally I also changed both input capacitors C518, C521 both 100µf x 16V. Now I stopped to get the messagge DC PRT 0% and I'm listening music again!!!!!!?
There is a relay right next to the fuses on the inside dg1u it says on the top. I cleaned it and pressed down firmly on it and it seem to have fixed it. It fired up for the first time.. The relay might need to be replaced if this doesnt work for ya.
I found a solution at: http://www.diyforums.net/forums/domestic-electronics/11098-yamaha-rxv795-receiver-shuts-itself-down-after-some-time.html
Posted on Dec 29, 2007
Yamaha rx-v795,fail to start.I hear a clik,the fan starts,the volum weel moov a beet? then it all fail.
Posted on Nov 09, 2009
Yamaha rx-v663 how to set and lock sound program
once you set the audio program for an input, it should stay set even if you power the unit down. As far as locking that program so that it cannot be changed - no there isn't a way to do that.
May 07, 2015 | Yamaha RX-V663 Receiver
My yamaha rx-v795a works fine but the display is showing jibberish. What is causing this problem?
There is a Microprocessor(computer) that controls the display. This Micro can be bad, the display can be bad, the connections between the two, as well. For more information, please visit my website at audioserviceclinic.com. Thank you.
Sep 18, 2013 | Yamaha Rx V795a 5.1 Chan 425 Watt Home...
Yamaha RX-V595 receiver won't stay on
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .
if it stays on whit no wires attached than u have short connection at speaker wires .
if doesn`t come on then try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode happened to me on RX-V592
Dec 23, 2012 | Yamaha RX-V595 Receiver
Hi I'm George. my yamaha rx-v795ards after an hours playing or when a loud sound comes, it turns off. you turn it on and then goes off again
Hi George,
Here is something that you can do , or have someone to assist you.
Disconnect all speakers.
Power it On, If it turns On completely , Be glad.
Put back speaker one at a time to find the cause.
If for instance , it doesnt work ....
It may need servicing.
Let us know what you find out or post back if you feel you can DIY.
Oct 06, 2012 | Yamaha Rx V795a 5.1 Chan 425 Watt Home...
Rx-v363 powers on then immediately off
The Yamaha receiver is going into shutdown because one or two channels have shorted audio output semiconductors, first check all speaker wires for shorts, if okay! all parts that are effected will need to be replaced.
Apr 04, 2012 | Yamaha RX-V363 Receiver
Hello: I have a Yamaha RX-V863 Receiver for 3 years. I try to on my receiver, but he start on, only for 2 or 3 second and then turning off immediately. I verify the wall outlet and the power in my house...
There is a load on the system, turn receiver off, disconnect speaker wires from the back, power on and turn volume right down. If the system stays on it means there is a short in the wires or one or more of the speakers. But if turns off with"wires and speakers diconnected" there is a short in one or more of the audio output ic's in the receiver and will need a professional to find out the extent of the problem.
Feb 10, 2011 | Yamaha RX-V863 Receiver
My Yamaha RX-V661 shuts off at moderate volumes.
Try to disconnect speakers one by one and see if any of them causes the problem.
Nov 05, 2009 | Yamaha RX-V661 Receiver
Yamaha Receiver RX-V630 not working (resets itself immediately)
This maybe an easy one. Have you unhooked all the wires going in to the stereo. "SP wires" means you have wires to the speakers are touching and the stereo is shutting down to avoid overloading. Hope this helps...
Jun 05, 2007 | Yamaha RX-V630 Receiver
Yamaha RX-V795 Receiver Logo
1,780 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
CHP6PH1
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
