Question about Coleman Powermate Premium Plus 6250W Portable Generator
How many pieces are inside the bowl in the carburater
I think theres a peice missing its getting too much gas and flooding.
    Top Expert:
  • Coleman Master
  • 13,735 Answers
Float and needle valve small clip to hold needle valve check float adjustment and that float not porous or sticking open
Posted on Oct 05, 2009
After starting, I lower the choke and it stalls
It is starving for fuel. The carburater is plug or dirty inside. You will need to take it apart and clean it or a rebuilt kit. Take the carburater bowl off. If you see any debris in the bowl or water. The carb is definitely contaminated and must be cleaned. Also check to be sure the fuel tank is clean and no water in it. Hope this cures your problem.
Sep 19, 2015 | Garden
The fuel is going straight through the carburettor and out of the exhaust pipe
Sounds like your float inside the carb bowl is tuck int the open " fuel flow position " you need to shut off or empty your fuel tank..and remove the bowl and do a good cleaning of the bowl and float area..it is a simple set up just pay attention on how to remove the float and valve seat..once you get the float out shake it and listen for gas inside it there should be none..but sometimes it develops small holes and will let gas in and will not shut the gas flow when stopped..If it does then tne float needs replaced..if none the your carb will need rebuilt..or replaced. Rebuild kits are available and inexpensive...Oh if this is a nearer engine I suggest checking your oil for gas..if it has gas in it..do another fixit post for a fix..good luck..
Apr 04, 2015 | Garden
I have a 1998 Yamaha 600 Grizzly.I was having a problem with gas coming out discharge hose off carburetor.Someone told me to tap bowl, that maybe float was sticking.It didn't work still leaked.He then
The suggestion you received of tapping the bowl is one that sometimes works. I think this time NO. Remove the carb bowl, and check to see if the float is plastic, brass, or foam (hard pressed plastic). Plastic and brass can leak gas inside weighing float down, shake float and listen for gas slushing around inside float. If you have one of those hard pressed plastic floats, they also absorb gas and become heavy and incapable of floating. In this case replace what you have, with a new float. Also check the needle valve tip, if broken replace. The quad will turn over, but not start because engine is flooded. Remove plug and let inside dry out, replace everything and you should start OK. GOOD LUCK FRIEND.
Dec 01, 2014 | Yamaha Motorcycles
New Troy-Bilt Self-Propelled TB230 will not start
You Screwed up, :) you left gas in it and it dried up in the Bowl of the carburetor, You should find 1 7/16 nut on the bottom of the bowl , if you loosen it up a little and tap the side of the bowl to attempt to remove the gasket in 1 piece, remove the bolt the rest of the way and you should see a Float inside with a needle valve, It's most likely Stuck from the dried gas that was lest behind, Clean with a little Brake cleaner and a few Q-tips and put it back together, "Be Sure the float is Not ADJUSTED unless you know how," But if float is low gas come's into carb, when the float is level the gas stops going in to prevent Flooding of engine. Add gas and Start it up.
Mar 15, 2014 | Garden
Sears mini tiller 10
it could be the bowl nut gasket or the bowl oring either could be dried out or in the case of the bowl oring could be pinched
Apr 03, 2012 | Craftsman Gas Mini - Tiller/Edger
Gas floods out of the exhaust manifold
Stuck float valve, letting too much fuel into the carb. Try taking the bowl off of the carb and checking to make sure that the float needle moves freely up and down. If there is evidence of gumming inside the bowl you will want to get some spray carb cleaner and clean everything in there thoroughly.
Mar 18, 2012 | Mtd Garden Tiller (Mtd)
I have a coleman 6250 generator the carb bowl keeps flooding and it wont start a spring was at the bottom of bowl i have spark and fuel pressure
If it is B&S he spring is to hold up the plastic float housing to keep a tight seal to base of carb. Sits in the center of the bottom of the plastic piece and the bottom of the bowl.
Apr 10, 2011 | Coleman Powermate Premium Plus 6250W...
Gas flows out of the carburater drain hose
Sounds like your carburetor floats are stuck to the bottom of the bowls. You can try to tap the carb bowl with a screwdriver and try to get them to pop loose, otherwise you will have to remove the float bowl (usually about 4 screws on the bottom of the carb). All you should have to do is pull it down about 1/4" or so until the floats pop loose and then put the bowl back on. This is pretty common on bikes that have sat for a few months, especially if you are good about draining the gas from the carbs when you're storring it.
Jul 13, 2010 | 2004 Honda CRF 150 F
Brand new 24MM MIKUNI CARBURETOR that floods out the bowl...
Carb's can be cleaned, hope you didn't throw money away on a new one for dirt.
You may have dirt in the gas tank getting to the carb. If you can, remove the bowl drain, (At the bottom) and see if there is sediment in it.(dirt)
Feb 11, 2010 | 2005 Honda CRF 150 F
Riding lawn mower keeps flooding
It sounds like the inlet needle seat is not closing all the way,allowing fuel to overfill the carburetor.The inlet needle seat may have dirt in it.You will have to remove the carburetor bowl and check for dirt or debris in bowl,if so remove the float assembly and check for a peice of dirt between the inlet needle and seat.If there is none you may have to replace the carburetor or rebuild it with a carburetor kit.You should also chang the engine oil because the overfilled carburetor drains to the crankcase,filling it with fuel,check the oil level and see if it is high,that would indicate fuel is in the oil.Hope this helps
Jul 28, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
47 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
